How to conduct internal audits?
G
gooofii
#31
What does your Manager mean?
Auditing against a documented procedure?
or
Auditing the procedure (the practice) itself?
Stijloor.
wel, auditing the processes itself of each procedure to guarantee that it meets our requirements which are all in the QM ... does that make sense:notme:
#32
Goofii:
I'm a little confused by your descriptions and it's making me feel bad about what you're trying to do. In your posts, I'm reading 'process of procedure' or similar. This makes me feel like you're confused over the fundamentals (just being honest with a fellow Brit).
In my world, it's either a process (inputs, outputs, controls etc.) or it's a procedure - which may be a part of a process (I just know, someone's going to say they're the same thing!).
Can you clarify?
G
gooofii
#33
Can you clarify?
well, I have different QAP Quality assurance procedures, each one has alot of processes , for example: Design&Development Procedure is detailed in the Flowchart to alot of processes like (product planning, Design input, Output,BOM, Prototype, product verification....etc...)
thts how i meant actually:notme:
does this make sense to you
Jen Kirley
Quality and Auditing Expert
#34
Is this to be the first time these processes are being audited?
Has your organization yet registered to ISO 9001, and these are new processes?
If you are new to auditing and/or the processes are being audited for the first time, a gap analysis could be the right direction for you. They tend to be more thorough in nature, and ready-made checklists can guide you instead of your trying to think up what to ask. I did a search of attachments via the green Post Attachments List button in the header and came up with this list of gap analysis tools at your disposal.
I hope this helps!
#35
Not really, to be truthful!
Why not just call them processes? The D & D process, the D & D Planning process? The others you speak of seem to me not to be a 'process' per se. Design output (drawings, specs etc. isn't a process, BOM isn't a process!)
I'm really thinking there's a gap in fundamental understanding here. I'm not suggesting you're all 'hosed' here, just that in the Quality business we have to be sure (ourselves) what we're talking about, because others will screw things up - even the most fundamental ones - and you will end up with a mess.
A quick anecdote to demonstrate. My son (18) driving my truck calls after he'd had a puncture and changed the wheel. He says "how long's the alignment been off on the truck?" I freak out thinking he's hit some kerb or something! PANIC! He actually means the steering wheel isn't on 'straight' since I had the ball joints/tracking done!! Phew!
He didn't know what 'alignment' means - but it sounds good!
TQCon
#36
I've attached an "Internal Auditor Decision Tree" that hopefully makes sense to a new auditor trying to understand process auditing. Also, there's an example of a flow map which defines a company's key processes - by function. From these, audits can be assigned and turtles developed (if necessary) for each one. Please provide any constructive criticism. Thanks.
TQCon
#38
TQCon
An interesting post and attachments. BTW welcome to the Cove!
Do you use any additional criteria to help auditors make some of these decisions? Some of them look mighty subjective to me and, as we know from the ISO 9001 requirements, auditors and the audit process is intended be be impartial and objective!
#39
What are you seeing as subjective?
#40
In the process flow there are a couple of 'decision diamonds' which ask 'should it be?' - without criteria this would be based on the auditor's opinion. For example 'should it be documented?' is an opinion, without reference to some criteria.
Having taken a second look(s) at the flow, I'd rather doubt if it would assist any newbie auditor.........it doesn't follow any process of understanding the criteria or scope of the audit to arrive at some of the conclusions being described? Also, asking an auditor to decide if a process should be measured is a bit 'late' isn't it? As I said - subjective!
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R How do I conduct my API Q1, ISO compliant internal audits? Internal Auditing 1
C When is the Best Time to Conduct Internal Audits Internal Auditing 22
Sidney Vianna Can CB's (certification bodies) conduct internal and 2nd party audits? Registrars and Notified Bodies 12
A Does anyone conduct opening & closing meetings for their internal audits? Internal Auditing 19
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
P Can internal ISO 17025 Auditor conduct ISO 9001 Audit ISO 17025 related Discussions 7
Q Tips on how to conduct a good Internal Audit Opening Meeting Internal Auditing 19
J How to Write the Planned Interval to Conduct Internal Audit, Management Review, etc.. ISO 13485:2016 - Medical Device Quality Management Systems 3
V How many years of experience is needed to conduct the internal audit in my company? General Auditing Discussions 4
A Do we have to conduct tests during internal audit of ISO 17025:2005? ISO 17025 related Discussions 8
M How to conduct the first ISO 9001:2000 Internal Audit Internal Auditing 11
E To conduct ISO 17025 Internal Audit - Auditor Requirements ISO 17025 related Discussions 10
J Internal auditor conduct, unbecoming an auditor... General Auditing Discussions 19
D How to Conduct a TS 16949 Internal Audit - Can I Use a Check List? Internal Auditing 10
M Knowledge of test methods in order to conduct an internal audit to ISO 17025? ISO 17025 related Discussions 3
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
B Is it necessary to conduct product audit of entire product which is manufactured in the company as per IATF IATF 16949 - Automotive Quality Systems Standard 4
C How frequent to conduct Clinical / Performance Evaluation? CE Marking (Conformité Européene) / CB Scheme 4
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S CMDCAS ISO13485 - Bilateral agreement with SAI global to conduct Certification Audits ISO 13485:2016 - Medical Device Quality Management Systems 7
S Conduct Customer Satisfaction Survey for every submitted Bid? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Conduct a fractional factorial 2^13-5 experiment with Minitab Using Minitab Software 4
M Help me understand how to conduct a Chi Square Test Statistical Analysis Tools, Techniques and SPC 3
N How do I conduct Management Review Meetings? Management Review Meetings and related Processes 34
R Can our Supplier's Quality Mgr. conduct Supplier Audit on behalf of manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Tips, Guidelines and Checklist to conduct Audit of Supplier & Subcontractor Document Control Systems, Procedures, Forms and Templates 5
L How to conduct a Quality Audit based on ASME BPVC VIII-1 requirements Various Other Specifications, Standards, and related Requirements 4
Y FDA - Does anyone have conduct the validation on GR&R worksheet before? Qualification and Validation (including 21 CFR Part 11) 7
I Code of Ethics and Conduct wanted Document Control Systems, Procedures, Forms and Templates 3
D How to conduct a Gage R&R on DC Tools to Torque Bolts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G How to conduct a Toy Recall (College Question) Customer and Company Specific Requirements 2
N How do I conduct Risk Management for my company? ISO 13485:2016 - Medical Device Quality Management Systems 7
K How to conduct a QCC project Misc. Quality Assurance and Business Systems Related Topics 2
N Tyvek Pouch Seal - Pressure needed to conduct Vacuum Seal Leak test? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
R How to conduct the Threshold Test of Mobile Equipment specified in 3rd edition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 35
S How to conduct Capability Analysis for this data? Statistical Analysis Tools, Techniques and SPC 12
K Can auditors freely conduct confidential interviews, or consent is necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
P How to conduct ILCP (inter-laboratory comparison programme) to get ISO 17025 ISO 17025 related Discussions 3
M Do we need to conduct Vendor (Supplier) Evaluation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
K When, whom, how to conduct hazard analysis of PRP?s, OPRP?s and CCP?s? Food Safety - ISO 22000, HACCP (21 CFR 120) 1
S Can a suspended CB still conduct Surveillance Audits? Registrars and Notified Bodies 4
J My mentors insist I use hotel's employee manuals and codes of conduct for my... Service Industry Specific Topics 3
somashekar Sustainability audit per EICC Supplier Code of Conduct Sustainability, Green Initiatives and Ecology 14
Marc Apple Enforces "Supplier Code of Conduct" After Child Labor Discovery After Work and Weekend Discussion Topics 13
B How to Conduct a Review of Customer Order (Contract Review)? Contract Review Process 5
M ISO 17025 Audit check list to conduct horizontal and vertical audits ISO 17025 related Discussions 10
D How to practically-conduct, post production phase ISO 13485:2016 - Medical Device Quality Management Systems 1
S Multilevel Design in Minitab to conduct a DOE - 4 factors and each has 5 levels Design and Development of Products and Processes 4
