How to Control Documentation
buterfly
Hello everyone.. :bigwave:
i'm newbie. hope all of you can give me some guide.
this new thread is 'how to control the documentation'.
anybody expert can sharing all about this topic.
as keen as mutard to know what is document control task,
what is master copy, controlled copy, uncontrolled copy, obsolete.
what is flow task for document controller and etc.
thanks..sharing is caring :D
Marc
These are very basic document control questions which have been asked and answered many times.
My suggestion is that you read through some existing discussion threads and then if you have specific questions start a new thread.
This should start you out: Document Control
buterfly
ohhh..thanks for your information mr marc..
i will open that link..
anyway, nice to know u.. :thanx:
harry
................ this new thread is 'how to control the documentation'................................
To answer your question on 'how to control documentation' - check your document control procedure. What you are supposed to do is outlined inside.
If you are new and unsure of the terms, get a copy of the ISO 9001: 2008 standard for reference. A good read is this excerpt from Craig's book: Excerpt from ISO 9001 in Plain English (Cochran).pdf . Better still, get a copy of this book or any others recommended here: What are the Best books and sources for those new to Quality?
buterfly
thanks harry for your reply..
already finished my DC procedure. but in several things, i still can't understood how to manage the document impressively.. :confused:
qusys
If you have a specific question , on specific theme, it could be useful to focus on response and help, by sharing ideas and experiences.
buterfly
hye qusys..
okay.. i will make specific..
let say, i have to control an internal & external drawing..
it is not a problem to manage an internal drawing..
but, i have a lot of problem when received an external drawing..
without po, without po number, with hand drawing, and so on..
it is confusing me..
what should i do when i receive an external drawing from customer?
how to identified?
:thanx:
qusys
Hi Butterfly,
how are?
Hope to be useful with my post. This is my idea and would like to share with all Covers that could add other experiences and thoughts.
As per your question, this is a clear point to be dealt with in your control document procedure.
ISO does not state How, but only What , so each organization can organize to meet the clause, demonstrating that the process in plkace is efficient and effective.
To manage external documents ( and in particular external drawings you asked for) , for example, the managers who are in charge of receiving customer provided documents and other documents of external origin could establish effective control systems to ensure changes are received by the organization , recorded and implemented in accordance with external requirements established with Customer .
In the absence of such defined requirements , you could implement a process defined in your document control procedure.
For example, each responsible manager will establish and maintain an electronic or hard copy external document change control log, utilizing a certain format. The log will identify the new/revised external document received, date received, person/function to whom it was sent, and date the change was fully implemented. N
New/changed external documents are usually issued/reissued in their whole content and obsolete/replaced documents removed from points of use and destroy or placed in archives. The responsible manager will determine, document and communicate to affected personnel/functions other applicable instructions. Where appropriate, the responsible manager will determine the need for and coordinate the provision of training needed to effectively communicate/implement any changes.
This is only a suggestion, but it could be ok based upon my experiences.
In case of ISO TS certification, you have also to manage engineering specification changes.
Hope this helps
regards:bigwave:
hye qusys..
how to identified?
:thanx:
buterfly
Hi Butterfly,
how are?
am good.. :)
thanks for your detailed explaination..
okay..so far i understand..
but, i still had a question to asked you
may i?
normally, when audit, is it auditor would check that external document?
thank you very much..
F PPAP Documentation Control APQP and PPAP 8
K Out–of–control versioning - Struggles with documentation Document Control Systems, Procedures, Forms and Templates 8
V Design & Documentation of Control Systems and Procedures Document Control Systems, Procedures, Forms and Templates 11
M Control and Identification of ISO/TS 16949:2009 Documentation. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Documentation Control Software for small companies on a Budget Quality Assurance and Compliance Software Tools and Solutions 10
T Is there a Professional Documentation Control Certification Document Control Systems, Procedures, Forms and Templates 2
A Control Plan Content Requirements - GDP (Good Documentation Practices) APQP and PPAP 3
J What things go in Design Control Documentation for a 510k of Class II Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Controlling Documentation - Which procedures to control Document Control Systems, Procedures, Forms and Templates 12
D Revision Control of Marketing Documentation Document Control Systems, Procedures, Forms and Templates 17
T Documentation Pyramid - Transitioning from one document control system to another Document Control Systems, Procedures, Forms and Templates 8
H Visual Aids - Documentation in our Specification System or Local Control? Document Control Systems, Procedures, Forms and Templates 2
A Customized AQL Table - AQL Documentation Control AQL - Acceptable Quality Level 2
S Using Agile for Quality System Documentation Control Document Control Systems, Procedures, Forms and Templates 5
C Design control documentation provided in special 510(k) + FDA response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
G Making everyone follow documentation (document control) policies Document Control Systems, Procedures, Forms and Templates 24
S ISO 9001 - Documentation Control - Letters / Letter Templates Document Control Systems, Procedures, Forms and Templates 4
Z Process Mapping Documentation Location and Control Process Maps, Process Mapping and Turtle Diagrams 5
M QSi Document Control Module and Documentation (examples requested) Document Control Systems, Procedures, Forms and Templates 11
R General Questions on Documentation Control Document Control Systems, Procedures, Forms and Templates 2
M Training Documentation - Control of Signed Training Documents e.g. Training Logs Training - Internal, External, Online and Distance Learning 10
E Linking of Process Control Plans To Process Documentation FMEA and Control Plans 6
D AS9100A Documentation Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Documentation Out of Control - What classifies as a Controlled Document? Document Control Systems, Procedures, Forms and Templates 23
Marc Design Control 4.4 - Design Engineering manager has no structured documentation Design and Development of Products and Processes 11
B ISO 9001 Documentation Control Document Control Systems, Procedures, Forms and Templates 13
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
C UDI Questions on Control Units Other US Medical Device Regulations 6
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Control-self assessment Internal Auditing 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
