How to Control Documents of External Origin
N
naduksFJ
Hi
I work for a company who is registering into ISO 9001:2008 for the first time.I am assigned to be the document control co-ordinator.How do we control external documents for example - Non disclosure documents from customers & instruction manuals/operating software?
Stijloor
Re: External Documents
Hi
Welcome to The Cove Forums! :bigwave::bigwave:
External documents are information that you use in your quality management system but are not produced by you. They need to be controlled similar to internal documents. One of the challenges will be to ensure the availability of the latest version of such documents because content and revision status are not managed by you. So you must have a provision in your document control procedure to ensure that you always have the latest and greatest issues of these documents.
Hope this helps.
Stijloor.
Sidney Vianna
Post Responsibly
Jan, good advice, but don't forget that, SOMETIMES, the latest revision of a document (internal or external) is NOT the appropriate revision.
Instead of latest and greatest, I would say the appropriate and applicable version of the document.
Stijloor
Excellent points! :agree1:
"Latest and greatest" was meant in a figurative manner....:(
Stijloor.
bobdoering
Stop X-bar/R Madness!!
Sounds like a Microsoft issue. :lmao:
Its not just customer specs, etc. that can fall into that category. I have found when machine manuals, schematics, etc. were a part of the documentation system, they were finally easily retrieved by the departments that needed them. Prior to any attempt to control them, they were in a pile of dust and oil on top of machines, in tool boxes, or just gone. You might find a quality system minimalist that can develop a justification not to do it, but I do not recommend living like that. There is a better way. :cool:
To clarify Sidney's comment, sometimes the customer will specify a specific revision of an external standard. In this situation, the specified version of the standard is the applicable version. This may not be the latest and greatest version.
Raffy
hI,
This is how we control our external documents: DRCC Staff receive and register the external document on Document Registration Database. E-copy of the external document, if any, shall be saved in the network drive. DRCC Staff shall affix a receiving stamp on the front page of the external document immediately after registration. Use a Document Received Form to register all incoming documents that are not required stamped received on the first page, i.e. NDA from customer, Govt. related documents such as safety report, plant layout, certificate, permit, etc. Stamp shall be affixed on the form. DRCC Staff shall update the document master list within 24 hours. DRCC shall also acknowledge receipt of the document to the sender (if e-copy).
Hope this helps.
Best regards,
Raffy:cool:
Hi
This is a good basic system, but it is missing one important component. There needs to be a proactive component that periodically verifies the current version of these documents. For example, you certify your product against a certain UL standard and have that standard controlled in the system as you describe. How do you verify that the version that you have under control is the latest version released by UL?
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
M Control of External Documents such as customer manuals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 28
drgnrider Control of External Audit Notes and Documents Document Control Systems, Procedures, Forms and Templates 8
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
Q Control of Customer Documents (Documents of External Origin) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T External Document (Documents of External Origin) Control Template example wanted Document Control Systems, Procedures, Forms and Templates 14
L ISO 9001:2008 - Control of Documents of External Origin Document Control Systems, Procedures, Forms and Templates 13
N Control of External Documents - Best Practices for Control of External Forms Document Control Systems, Procedures, Forms and Templates 2
Q Suppliers info into my Documents Control (Documents of External Origin)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Control of Documents (External Drawings) and Marking Up Prints Document Control Systems, Procedures, Forms and Templates 5
T Identification and Control of External Documents - 4.4.5 f) of ISO 14001 ISO 14001:2015 Specific Discussions 5
A Document Control - Control of external documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Control of Customer Manuscripts (Manuals), Specifications - External Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
C Monitoring changes in ANSI standards - Control of External Documents Document Control Systems, Procedures, Forms and Templates 6
T Document Control at Suppliers - Control of External Documents ISO 13485:2016 - Medical Device Quality Management Systems 2
B How to control external documents like drawings and standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E Control of documents procedure and external documents? Document Control Systems, Procedures, Forms and Templates 4
K How to Control and 'Monitor' External Documents (Documents of External Origin)? Document Control Systems, Procedures, Forms and Templates 1
L Sample of Control of Document Procedure and Control of External Documents Document Control Systems, Procedures, Forms and Templates 2
P Customer Furnished Drawings Retained? Control of Documents of External Origin Records and Data - Quality, Legal and Other Evidence 4
V Identification & Control - Documents of External Origin - ISO13485:2003 Clause 4.2.3f Document Control Systems, Procedures, Forms and Templates 8
J Control of External Documents - How does one *gain* control of external documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A 4.2.3 Control of Documents - Need advice on Control of External Documents Document Control Systems, Procedures, Forms and Templates 3
M External Documents - How to control? NC over letter from registrar about use of logo Document Control Systems, Procedures, Forms and Templates 19
S ASTM specs - Control and Update of Documents of External Origin Document Control Systems, Procedures, Forms and Templates 20
M Control of documents of External Origin - Specifications from our customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
R TS 16949 - Clause 4.2.3 - Identification and Control of Documents of External Origin IATF 16949 - Automotive Quality Systems Standard 15
G Control of External Documents - Which documents are required to be controlled? IATF 16949 - Automotive Quality Systems Standard 10
F Documents of External Origin - Identification, Control and Distribution - 4.2.3 f) Document Control Systems, Procedures, Forms and Templates 13
A ISO 9001:2000 - Documents Requiring Control - Documents of External Origin Document Control Systems, Procedures, Forms and Templates 27
C Control of Documents of External Origin - Reference manuals and standards Document Control Systems, Procedures, Forms and Templates 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
qualityegghead ISO13485:2016 4.2.4 Control Of Documents - Lifetime of the Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
B Control of Duplicate Documents - Limited Scope (long) Document Control Systems, Procedures, Forms and Templates 5
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
S AS9100 Control of Documents and SAP Implementation Document Control Systems, Procedures, Forms and Templates 1
Gman2 Control of Documents and (FORMS) on a Computer Network ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Information Gathering Documents and Document/Record Control Requirements Document Control Systems, Procedures, Forms and Templates 9
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
U Do we have to have foreign legal documents? (ISO13485 4.2.3 document control) ISO 13485:2016 - Medical Device Quality Management Systems 3
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
C Document Control - Details to include on Documents Document Control Systems, Procedures, Forms and Templates 2
