How to copy a Minitab graph template
F
FAndrade
I'm looking for an option to do different graphs (same variables but different data), but keeping the same graph layout (number of ticks, titles, colors, etc). I have different worksheets for different data, but everytime I do a graph, I have to manually change all layout again. Any help would be great.
best regards.
After customizing your initial graph and with this graph still active, go to Editor > Make Similar Graph... This allows you to replace the original variable with a new variable while keeping all formatting the same.
F
FAndrade
Hi Miner,
thanks for your answer. The problem is that I have all info on different worksheets, and that option can only allow me to select variables of the same worksheet.
The only other option that comes to mind is to generate the graph using Session commands and subcommands then copying those into a macro.
