How to correct these NCs?
lanley liao
Hi, everyone,
I am studying that how to deal with these NCs, which are as follows:
1) Facility sales order has not clearly specified product requirement ;
2)There is no hot work reduction range or forging ratio specified on the mill material certificate;
3) Facility`s procurement procedure has not defined that purchasing material/product specification; and, supplier issue material certificate has not specified spec/standard on this purchasing contract.
4) facility rolled thread WI has not set.
Give your valuable advice about these NCs, please.
Thank you so much!
Langley Liao
May 3, 2021.
Steve Prevette
Deming Disciple
Sounds like folks are not following the documentation requirements. So first need to determine why are they not following the requirements. Are the requirements unworkable? Are the people trying to fulfill the requirements not trained? Is management not making expectations known and holding folks (not just the immediate worker) accountable? Is there a routine observation program and/or peer reviews to catch these failures?
One you know the cause, then let's talk the actions to take to correct the cause(s).
John Broomfield
Correcting a nonconformity is putting the nonconformity right.
...perhaps by rework, repair (with design approval), use as is (again with design approval) or replace.
It is not corrective action.
So, 1) is specify the produc acceptance criteria, 2) specify the forging ratio, 3) update the procurement procedure and 4) issue the missing WI.
This is done before corrective action when colleagues may decide to invest in stopping recurrence of one or more of these nonconformities by determining and removing the root causes of each type of nonconformity.
For that you’ll probably need a cross-functional team from your colleagues who can investigate the possible root causes. This approach also gains essential buy-in to the corrective action they recommend.
lanley liao Would you helpe me that how to correct these NCRs? Oil and Gas Industry Standards and Regulations 6
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Are my Cpk and Cp Calculations Correct? Capability, Accuracy and Stability - Processes, Machines, etc. 4
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
C Correct Tool for Gage R&R - Assay Dilutions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B How to Correct Bad Employee Performance-Attendance and/or Tardiness Quality Manager and Management Related Issues 84
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
Q Latest ISO 9001:2008 Rev. E - Correct? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
