Interesting Discussion How to Deal with Suppliers Who Refuse to Complete our ISO Survey?
NikkiQSM
Hello Covers,
I have recently ran into an issue I have not previously, with our Suppliers.
We have three suppliers that refuse to complete our ISO Survey. :argue: Its very basic, nothing complicated. All they have to do is check yes if they are ISO certified (which they are) and sign the second page.
This survey is required to be completed for the supplier to be on our Approved Vendor List. If they are not on the list, we can't buy from them.
So, I have three suppliers refusing to complete the survey for one reason or another - (I dont know - they wont talk to me).
I have tried contacting different people at the company, and even sending an email stating that we can not buy from them anymore with our Purchasing Manager clearly copied.
The problem with all of this, is that these three suppliers are the only suppliers on specific materials that we NEED. We can not change to another ingredient and no one else sells this stuff but them.
How can I handle this? It's audit season for me right now and I can expect getting dinged if the auditor sees that I dont have the completed documents that are required.
Thoughts?
Thank you,
Nikki
Sounds like your procedures have painted you into a corner. It is always the critical item suppliers that seem to do this, just because they can.
There are (and you should probably write into your purchasing procedures) a kind of 'exemption' for critical item or single source suppliers. If they cannot be replaced, and will not respond to you, then you must find some way to accommodate this state of affairs.
I would always be on the lookout for other suppliers in this case, because you really need some leverage to accomplish anything here. The leverage can be used to get a survey out of your existing supplier, or to 'introduce' a new supplier. Win-Win in that case. It could take a very long time though, something you do not have at the moment. We send out these surveys to our suppliers every three years (the renewal cycle for 9001) and like you, our first page gives them the option - simply send us a fax or your certificate, or fill out the survey. Most do it, but some always fail to respond, especially the single item specialty suppliers, who know you just don't have any choice but to purchase their item.
Tara Monson
We used to have this as a requirement and after noticing only a 30% reply rate, we developed a different system for approving suppliers.
We use a sample to evaluate suppliers. Basically, order what you need, if it meets conformance requirements and the shipping date provided, they get approved. We then monitor them on the same two standards (conformance and OTD.)
We work in a small business with few suppliers so this works well for us. I also know our Quality Director HATES filling out those surveys.
Good luck!
Ninja
Looking for Reality
Whoa...WOW...Ouch.
"We have three suppliers that refuse to complete our ISO Survey.
If you know they are ISO certified, what is the survey for? Get a copy of their current Cert.
"So, I have three suppliers refusing to complete the survey for one reason or another - (I dont know - they wont talk to me). "
Because it is one more useless piece of paper to fill out.
"and even sending an email stating that we can not buy from them anymore"
"The problem with all of this, is that these three suppliers are the only suppliers on specific materials that we NEED."
Why on earth would you tell a vendor that you NEED that you can't buy from them anymore?
"I can expect getting dinged if the auditor sees that I dont have the completed documents that are required."
Who cares about the auditor...can you stay in business? If you NEED the vendor and can't buy from them because of your self-defined need for this "survey"...the auditor is the least of the problem.
"This survey is required to be completed for the supplier to be on our Approved Vendor List."
Your company requires this survey. ISO does not.
You may want to revisit your process requirements for Approving Suppliers.
FWIW, I get asked to fill those surveys out all the time. I fill out ~5% of them and throw the rest out. I fill out the ones that might impact my business...most are just a waste of time and don't affect anything.
As the others have pointed out - how you approve a vendor can vary greatly. Using a sample is another way. Have several options written into your procedure, it is your procedure killing you, not the surveys.
normzone
We are a small organization (under 40 head count) and periodically I'll receive a wave of these things from our big aerospace customers. I have no choice but to fill out these forms.
Some are to the point, some are bigger than they need to be, and some are utterly ridiculous in scale and scope.
Yes, take a hard look at the requirements of your system and do what makes sense while making it as easy as possible for all involved. Actually, that is how all your systems should work.
NikkiQSM
Whoa...WOW...Ouch.
The 2nd page of the survey is a no change agreement - If they cant or wont follow our agreement - I just need them to list that on page 2. No change agreements are huge. If this is the reason why they wont complete it, I dont know - as I stated before - They wont talk to me.
It's not useless - we are medical and no change agreements are needed in our line of business.
Desperation and an act to get them to understand that the paperwork is important. This was suggested by another manager.
True. I agree. I just havent encountered this problem before.
Yes I understand ISO does not require it. Our current procedure states that it is a requirement. I will have to adjust my procedure, I see that, I just didnt know if anyone had any other suggestions besides changing the process.
Please see my notes above.
Project Man
Get your procedures changed immediately! There should always be multiple ways to approve a vendor (we have 5). We've had various auditors like or not like 1 or 2 of them but that doesn't matter and they can't ding you on whether they like it or not anyways.
P.S. Have you had your boss contact these companies? There are times when higher level conversations resolve issues quickly. Especially when it can dramatically affect your business but, for heaven's sake change your procedures!
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
S How to deal with customers requesting documents as being in the role of distributor? EU Medical Device Regulations 5
L How to deal with the model number symbol for X-RAY PRODUCT Other Medical Device Related Standards 1
F Circuit board FAI reports- How do you folks deal with these? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
MDD_QNA How to deal with FDA after not reporting anything for several years Other US Medical Device Regulations 14
M Informational Update from GOV.UK – Regulating medical devices in the event of a no-deal Brexit – UK Responsible Person Medical Device and FDA Regulations and Standards News 0
A How to deal with changed shared components in 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Informational UK – Contingency legislation covering regulation of medicines and medical devices in a no deal scenario – Human Medicines and Medical Devices (Amendm Medical Device and FDA Regulations and Standards News 3
M Informational EU – Medicinal products and medical devices: Coordinated approach in case of a withdrawal of the United Kingdom from the Union without a deal Medical Device and FDA Regulations and Standards News 0
M Informational UK – Regulating medical devices in the event of a no deal scenario Medical Device and FDA Regulations and Standards News 0
M Informational UK – Businesses supplying medicines and medical devices – what to expect on day one of a ‘no deal’ scenario Medical Device and FDA Regulations and Standards News 1
M Informational Design for new product safety marking for the no-deal Brexit scenario Medical Device and FDA Regulations and Standards News 1
M Informational UK – Contingency legislation covering regulation of medicines and medical devices in a no deal scenario Medical Device and FDA Regulations and Standards News 1
M Medical Device News MHRA releases response to consultation on EU exit no-deal legislative proposals Medical Device and FDA Regulations and Standards News 0
M Pharmaceuticals News UK – Further guidance note on the regulation of medicines, medical devices and clinical trials if there’s no Brexit deal Medical Device and FDA Regulations and Standards News 0
M Medical Device News Letter to the health and care sector: update on preparations for a potential no-deal Brexit Medical Device and FDA Regulations and Standards News 0
supadrai Indemnity Letters - What's the Deal? Other Medical Device and Orthopedic Related Topics 5
M Medical Device News MHRA to consult on EU exit no-deal legislative proposals EU Medical Device Regulations 1
D How to deal with user needs when it is obvious the design meets the user need 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Quality Assurance and Quality Control - Which clauses of ISO 9001 deal with each? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
R How to deal with CONFIDENTIAL documents Document Control Systems, Procedures, Forms and Templates 2
L How to deal with resistance from auditee(s) Internal Auditing 20
P How to deal with a Recruitment Consultant Career and Occupation Discussions 3
AnaMariaVR2 3 Ways To Deal With People Who Play Office Politics Against You Coffee Break and Water Cooler Discussions 7
J How to deal with incomplete forms Nonconformance and Corrective Action 14
R How to deal with the RM requirement of clause 17 Electromagnetic Compatibility? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
T How to train employees to deal with external auditors? Internal Auditing 13
S Training on how to deal with Regulations, Rules, Regulations Conflicts, etc. Training - Internal, External, Online and Distance Learning 6
M Mobile Medical Platforms - How to deal with Supplier Hardware/Software Changes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S How to deal with non-compliant company after take over of them IEC 27001 - Information Security Management Systems (ISMS) 6
C If my location does not deal with GM - Firewall - CS1 & CS2 Question IATF 16949 - Automotive Quality Systems Standard 3
I How to deal with Behaviour Problem in the work place? Human Factors and Ergonomics in Engineering 20
J How to deal with Mental models IEC 62366 - Medical Device Usability Engineering 1
BradM Deal? Or no Deal? Coffee Break and Water Cooler Discussions 25
Marc Looking for a good deal on a boat? World News 2
S How to deal with telemarketers Funny Stuff - Jokes and Humour 2
ScottK Giving training with a vicious cold - how do you deal? Training - Internal, External, Online and Distance Learning 9
Marc Delphi to close, sell most plants under deal World News 0
J How to deal with an employee who has a bad attitude? - Employee Attitudes Coffee Break and Water Cooler Discussions 15
D X Bar Chart - How can I deal with missing values in subgroups Statistical Analysis Tools, Techniques and SPC 12
E Lets Make a Deal... The TV show - A statistical approach Coffee Break and Water Cooler Discussions 8
M Dock to Stock - How to deal with inspection status requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Marc Delphi, GM and UAW reach broad buyout deal World News 1
I How to deal with and track Customer Specific Requirements Customer and Company Specific Requirements 6
J How to deal with operators who fail to follow work instruction? Misc. Quality Assurance and Business Systems Related Topics 52
