How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action)
L
LesPiles
The same old problem, we, quality guys, are facing every day in our systems. :(
For Upper Management, or the rest of team we're part of, their simple solution is "categorize them" by priority, and or by the gain we should have from their resolution.
In this friday afternoon we're all tired from this extra busy week, do some of you would like to share their methodology of evaluation or, better, their evaluation template ?:confused:
Thank you in advance ! :):)
dwend
Re: How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Act
My solution is to use this the CAR process as judiciously as possible so as to not have high numbers of CARS open at one time. For internal audits, we have a "corrections" process that will allow minor tweaks without invoking the full process. From there it is anything that directly affects product conformity, customer related, system failure, down to documentation errors as a lower priority with time open a consideration as well. I manage our CAR process but sending out documentation to individual owners who have the responsibility to request team help if needed. We put up a Rolling Action Item List every 2 weeks for review in front of upper management who then can turn up the voltage on their prods if needed. Ultimately its a resource decision which usually falls in the domain of upper management. Bang for the buck is hard to calculate. Be interested in what others have to say.....
Q
QCAce
Don't write so many. Combine related nonconformances into one CAR.
Jen Kirley
Quality and Auditing Expert
Not knowing the issues these CARs were written for, it is hard to advise. But if there are many, many CARs I wonder if they are being issued for trivia or if the CAs are effective?
I do agree that nonconforming issues can be combined into one CA. But if multiple incidents of the same thing need to be respond to, I wonder if there isn't a systemic issue that the typical CAR would handle. Just a thought...
ssz102
the urgent CAR will be first done
and then you should be find out the root cause to results these too many CAR
P
p1stonbroke
Raise opportunities for improvement which do not invoke the whole process
If they have not been actioned next time you audit, then they get the full Non-Conformance.
In terms of PARs, it depends how you view this...
one view:
preventive as in preventing something which has never happened yet but which might happen...
or
Root cause - preventing a recurrence of something that went wrong
I tend to condier that witth a CAR, comes a PAR (second variant) and that genuine opportunities for improvement can be documented as PARs, as well as those which might come out of (for example) FMEA
Yet another option is to permit persons to resolve audit findings before the end of the audit, prove they have solved the problem, write the finding up in the audit, but recording the fact that it has been resolved, without formally raising them as CARs - this approach is offten well recived and means that they take the ones you feel obliged to raise formally much mroe seriously.
If you raise too many CARs/PARs, or too many of them are open/outstanding/late, then they won't get the focus they should and the net result is less than if they are raised for issues that really need resolving, with a less formal approach for those with reduced implications
silentrunning
If you write too many CARs they will become meaningless and be ignored by everyone except the poor soul that has to close them out.
Steve Prevette
Deming Disciple
What is "too many"? What would be "too few"? Why?
I do a lot of work for my employer with their Corrective Action Management system. Questions include:
1. Are these self discovered, or a result of external sources? Note that if you stop looking, CAR's will go down. If you change for some reason to look harder, CAR's will go up.
2. What does the control chart show - is the rate of self assessment increasing or decreasing or staying the same? Is the rate of CARs increasing or decreasing or staying the same?
3. How do the data split out by subject area, by severity? A combination of Pareto Charts and Control Charts may help here.
4. What sort of causal analysis is done? Only on a case by case individual basis? Or by logical groupings of CAR's?
Mikishots
I'd start by deciding which CARs are actual findings and problems, and determine if there is any value added in resolving them. Next I would categorize the main types of CARs, create a pareto chart and split the top three nonformance types into separate charts. Then assign a team to tackle the top offenders.
The most common cause for having too many CARs is writing them for trivial matters or situations that can be dealt with easily. If all the ACRs you have right now are truly deserving of corrective action, categorize and deal with the top offenders first; dont tackle everything at once.
I would look deeper and may be there are:
1. Systematic issues or process issues which question process design in the first place.
2. Training of the people involved in issuing those CAR/PARs.
3. Are these CAR/PARs repeat? may be Root Cause was not determined correctly or actions implemented.
As you can see there are so many questions based on your post.
First there should be analysis of CAR/PARs issued.
S How to deal with customers requesting documents as being in the role of distributor? EU Medical Device Regulations 5
L How to deal with the model number symbol for X-RAY PRODUCT Other Medical Device Related Standards 1
F Circuit board FAI reports- How do you folks deal with these? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
L How to deal with an ISO 13485 Supplier Audit nonconformance ISO 13485:2016 - Medical Device Quality Management Systems 17
MDD_QNA How to deal with FDA after not reporting anything for several years Other US Medical Device Regulations 14
M Informational Update from GOV.UK – Regulating medical devices in the event of a no-deal Brexit – UK Responsible Person Medical Device and FDA Regulations and Standards News 0
A How to deal with changed shared components in 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Informational UK – Contingency legislation covering regulation of medicines and medical devices in a no deal scenario – Human Medicines and Medical Devices (Amendm Medical Device and FDA Regulations and Standards News 3
M Informational EU – Medicinal products and medical devices: Coordinated approach in case of a withdrawal of the United Kingdom from the Union without a deal Medical Device and FDA Regulations and Standards News 0
M Informational UK – Regulating medical devices in the event of a no deal scenario Medical Device and FDA Regulations and Standards News 0
M Informational UK – Businesses supplying medicines and medical devices – what to expect on day one of a ‘no deal’ scenario Medical Device and FDA Regulations and Standards News 1
M Informational Design for new product safety marking for the no-deal Brexit scenario Medical Device and FDA Regulations and Standards News 1
M Informational UK – Contingency legislation covering regulation of medicines and medical devices in a no deal scenario Medical Device and FDA Regulations and Standards News 1
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
M Medical Device News MHRA releases response to consultation on EU exit no-deal legislative proposals Medical Device and FDA Regulations and Standards News 0
M Pharmaceuticals News UK – Further guidance note on the regulation of medicines, medical devices and clinical trials if there’s no Brexit deal Medical Device and FDA Regulations and Standards News 0
M Medical Device News Letter to the health and care sector: update on preparations for a potential no-deal Brexit Medical Device and FDA Regulations and Standards News 0
supadrai Indemnity Letters - What's the Deal? Other Medical Device and Orthopedic Related Topics 5
M Medical Device News MHRA to consult on EU exit no-deal legislative proposals EU Medical Device Regulations 1
D How to deal with user needs when it is obvious the design meets the user need 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Quality Assurance and Quality Control - Which clauses of ISO 9001 deal with each? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O How to deal with Multiple Datums - Position with respect to Multiple Datum Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
R How to deal with CONFIDENTIAL documents Document Control Systems, Procedures, Forms and Templates 2
N Interesting Discussion How to Deal with Suppliers Who Refuse to Complete our ISO Survey? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 51
L How to deal with resistance from auditee(s) Internal Auditing 20
P How to deal with a Recruitment Consultant Career and Occupation Discussions 3
AnaMariaVR2 3 Ways To Deal With People Who Play Office Politics Against You Coffee Break and Water Cooler Discussions 7
J How to deal with incomplete forms Nonconformance and Corrective Action 14
R How to deal with the RM requirement of clause 17 Electromagnetic Compatibility? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T How to train employees to deal with external auditors? Internal Auditing 13
S Training on how to deal with Regulations, Rules, Regulations Conflicts, etc. Training - Internal, External, Online and Distance Learning 6
M Mobile Medical Platforms - How to deal with Supplier Hardware/Software Changes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S How to deal with non-compliant company after take over of them IEC 27001 - Information Security Management Systems (ISMS) 6
C If my location does not deal with GM - Firewall - CS1 & CS2 Question IATF 16949 - Automotive Quality Systems Standard 3
I How to deal with Behaviour Problem in the work place? Human Factors and Ergonomics in Engineering 20
J How to deal with Mental models IEC 62366 - Medical Device Usability Engineering 1
BradM Deal? Or no Deal? Coffee Break and Water Cooler Discussions 25
Marc Looking for a good deal on a boat? World News 2
S How to deal with telemarketers Funny Stuff - Jokes and Humour 2
ScottK Giving training with a vicious cold - how do you deal? Training - Internal, External, Online and Distance Learning 9
Marc Delphi to close, sell most plants under deal World News 0
J How to deal with an employee who has a bad attitude? - Employee Attitudes Coffee Break and Water Cooler Discussions 15
D X Bar Chart - How can I deal with missing values in subgroups Statistical Analysis Tools, Techniques and SPC 12
E Lets Make a Deal... The TV show - A statistical approach Coffee Break and Water Cooler Discussions 8
M Dock to Stock - How to deal with inspection status requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Marc Delphi, GM and UAW reach broad buyout deal World News 1
I How to deal with and track Customer Specific Requirements Customer and Company Specific Requirements 6
J How to deal with operators who fail to follow work instruction? Misc. Quality Assurance and Business Systems Related Topics 52
