How to decide what characteristics need to be verified during incoming inspection?
silentmonkey
Hello fellow Covers,
I will start this thread with a high-level question to get the conversation rolling. I understand the decision needs to be based on risk of the part not meeting product requirements, as well as the supplier evaluation, but I have some more specific questions about the logistics of where and how to get the necessary information to feed into this decision-making process.
In general, what is the best practice for documenting and making the decisions on what needs to be verified at incoming inspection?
William55401
Critical Feature Identification (CFI) done in a cross functional manner. Yes, alignment to Risk Mgmt is key. You need design, mfg, and the quality (or other function) responsible for the RI process to identify these features. It is best if the features are coded / flagged on the specs so that the supplier is aware also. Think about critical to safety (user & patient) as well as critical to function. Mfg may have key features important to the process
silentmonkey
What does this look like on paper? I envision a document very similar to a FMEA where each feature of a part is analysed to determine the effects of each defect which are then somehow rated to determine criticality?
yodon
Here's one case that demonstrates the challenges, I think. We developed a system to treat pain with lasers. Everything was working as planned until the diode manufacturer made some changes resulting in less power to deliver the same energy. Part number didn't change and nothing on the labeling changed. Devices started delivering too much energy and causing (luckily only) mild burns. We finally found the change buried in the spec sheet. So, yes, the FMEA provided support but the change drove an update to how incoming inspection reviewed / accepted the parts.
William55401
There are many options to getting this on paper. FMEA model is common. Spend thoughtful time aligning your severity definitions (or better yet, adopting) the severity definitions in your existing risk management process. These assigned severity levels will drive your level of assurance (read as sample size) at RI.
Edit: A direct model where Design Outputs (specifications) have the critical features marked as part of design process is simplest.
Edit 2: While RI is important, also think about process control at your supplier. The best material controls leverage what your supplier is doing. RI, for the most part, can be viewed as non value added. Process control at the source will better serve the business. IMHO.
Sidney Vianna
Post Responsibly
Do not forget past performance and history. All of what has been offered above is good advice, but focus and frequency of characteristics to be examined at receiving inspection should also be adjusted for history/performance during the device life cycle.
Also, supplier's stability and performance could/should lead to adjustments. How many horror stories do we have about product conformity headaches due to suppliers changing sub-suppliers without customer awareness?
S How to decide which medical device symbols go on label and labeling? US Food and Drug Administration (FDA) 5
J ISO 9001 - How to decide if a company needs or will benefit from certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
T Can we remove a quality objective if we decide it is not measurable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B How to decide on a sampling size for Xbar-R charts Statistical Analysis Tools, Techniques and SPC 2
J How to decide work-stream in scope of Quality - Roles and Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
D Service Identification - How can we decide if X is a service or not? Lean in Manufacturing and Service Industries 4
R How to decide a suitable contact time from table 23 of IEC 60601-1:2005 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
C Medical Device Manufacturing in Controlled Environment? How to decide? Other Medical Device Regulations World-Wide 1
M Statistical Method to decide Threshold Value from a Data Set Statistical Analysis Tools, Techniques and SPC 1
P Gauge Design Tolerances - How to decide tolerances for gauge design? General Measurement Device and Calibration Topics 3
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Lean or Six Sigma or TOC (Theory of Constraints) - How to decide Lean in Manufacturing and Service Industries 6
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
M CAPA Rankings to decide if action is required Nonconformance and Corrective Action 7
D Who should decide on my salary and adjustments? Career and Occupation Discussions 9
P How do you decide what is an acceptable Internal and External PPM number? IATF 16949 - Automotive Quality Systems Standard 17
M Overhaul QMS or start over? How do you decide? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
P How do you decide what is a Process, a Procedure or Work Instruction? Document Control Systems, Procedures, Forms and Templates 89
J To Decide Which Factor has the Highest Influence on the Results Using Minitab Software 3
K Regulatory Requirements for ISO 13485 - Which country to decide? ISO 13485:2016 - Medical Device Quality Management Systems 6
B How to decide the ?U? to calcuate DPU and "opportunity" of DPMO Six Sigma 8
L Is the EPA is going to decide if the SPCC deadline is to be extended? Miscellaneous Environmental Standards and EMS Related Discussions 1
M CA (corrective action) or Continuous Improvement? It's hard to decide. Nonconformance and Corrective Action 19
M how to decide the submission level for PPAP APQP and PPAP 2
Y How do we use SPC or other stat tools to decide product spec? Statistical Analysis Tools, Techniques and SPC 5
D On-going capability - Can we decide for ourselves how often to measure cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Definition of Characteristics Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Customer specific characteristics symbols Customer and Company Specific Requirements 2
S Defining special characteristics beyond customer drawing FMEA and Control Plans 11
N 8.3.3.3 Special characteristics - Auditor said we are required to create our own, if no customer char. exist. IATF 16949 - Automotive Quality Systems Standard 10
G Critical Characteristics/Dimensions of PCBAs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
Casana Mentioning Special Characteristics in SOP FMEA and Control Plans 4
C Pass through characteristics on PFMEA FMEA and Control Plans 3
A Critical Characteristics - Sheet metal stamping APQP and PPAP 9
J Aerospace Product Key Characteristics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Characteristics related to safety - format of documentation ISO 14971 - Medical Device Risk Management 3
S SOP Identification of Special Characteristics IATF 16949 - Automotive Quality Systems Standard 8
Techilady Ford Special Characteristics Communication and Agreement Form (SCCAF) provides production requirements? FMEA and Control Plans 4
R Critical Characteristics & Special Characteristics FMEA and Control Plans 2
M Critical Characteristics APQP and PPAP 2
J 1.11 Preliminary Identification of Special Product and Process Characteristics APQP and PPAP 4
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 2
K PSA Special characteristics Customer and Company Specific Requirements 0
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 2
