How to decide which medical device symbols go on label and labeling?
SGquality
This question is always in my mind - the ISO 15223 has so many symbols but how to decide which medical device symbols go on product, product label, primary packaging, and so on?
Ronen E
Problem Solver
Moderator
First, identify what information has to be on/in each of the labelling elements. This is mostly driven by applicable regulatory/statutory and customer requirements.
Then you may consider using symbols - for space considerations, translation avoidance or other reasons.
Last, use applicable standards to identify the correct symbols and use them in a compliant manner.
You don't have to use any symbol unless the regulations explicitly require it.
Specific question in regards to single use labeling - is single use labeling required? For example a class 1 medical device that practitioners routinely clean, sterilize, and re-use although the labeling may not specify "single-use only" or "multi-use" Is it acceptable to not make either single use or multiuse claim on label?
Ronen E
Problem Solver
Moderator
If the device requires reprocessing and this is not clearly stated in the labelling it's a safety issue, most likely unacceptable.
Adding to what Yodon has mentioned, it's up to the manufacturer to decide how much is enough. The standards for e.g. IEC 60601-1 layout the principles/context of application, some of them depend on the device. Most importantly before asking “how many”, manufacturers should do a risk management of the application as stated in ISO 15223-1. For e.g., if the device is intended for home use then depending on the user profile a symbol may be misunderstood/ignored leading to an adverse event (AE).
C Medical Device Manufacturing in Controlled Environment? How to decide? Other Medical Device Regulations World-Wide 1
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
J ISO 9001 - How to decide if a company needs or will benefit from certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
T Can we remove a quality objective if we decide it is not measurable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B How to decide on a sampling size for Xbar-R charts Statistical Analysis Tools, Techniques and SPC 2
J How to decide work-stream in scope of Quality - Roles and Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
D Service Identification - How can we decide if X is a service or not? Lean in Manufacturing and Service Industries 4
R How to decide a suitable contact time from table 23 of IEC 60601-1:2005 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
M Statistical Method to decide Threshold Value from a Data Set Statistical Analysis Tools, Techniques and SPC 1
P Gauge Design Tolerances - How to decide tolerances for gauge design? General Measurement Device and Calibration Topics 3
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Lean or Six Sigma or TOC (Theory of Constraints) - How to decide Lean in Manufacturing and Service Industries 6
H How to decide AQL value? Sampling Plans AQL - Acceptable Quality Level 5
A Who to decide and select Internal Auditors and what are the criteria? Internal Auditing 18
M CAPA Rankings to decide if action is required Nonconformance and Corrective Action 7
D Who should decide on my salary and adjustments? Career and Occupation Discussions 9
P How do you decide what is an acceptable Internal and External PPM number? IATF 16949 - Automotive Quality Systems Standard 17
M Overhaul QMS or start over? How do you decide? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
P How do you decide what is a Process, a Procedure or Work Instruction? Document Control Systems, Procedures, Forms and Templates 89
J To Decide Which Factor has the Highest Influence on the Results Using Minitab Software 3
K Regulatory Requirements for ISO 13485 - Which country to decide? ISO 13485:2016 - Medical Device Quality Management Systems 6
B How to decide the ?U? to calcuate DPU and "opportunity" of DPMO Six Sigma 8
L Is the EPA is going to decide if the SPCC deadline is to be extended? Miscellaneous Environmental Standards and EMS Related Discussions 1
M CA (corrective action) or Continuous Improvement? It's hard to decide. Nonconformance and Corrective Action 19
M how to decide the submission level for PPAP APQP and PPAP 2
Y How do we use SPC or other stat tools to decide product spec? Statistical Analysis Tools, Techniques and SPC 5
D On-going capability - Can we decide for ourselves how often to measure cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Medical device name in different countries EU Medical Device Regulations 4
dgrainger Informational EC - Medical devices – online manuals replacing paper instructions - Feedback period: 27 April 2021 - 25 May 2021 EU Medical Device Regulations 0
V Medical Device Literature Translation Software ISO 13485:2016 - Medical Device Quality Management Systems 1
R "Medical devices" required in scope ISO 13485:2016 - Medical Device Quality Management Systems 2
R X-RAY Based Diagnostic Veterinary medical Devices Medical Device and FDA Regulations and Standards News 2
Z Over The Air (OTA) updates for medical device Other US Medical Device Regulations 1
H Tukery Medical Device Regulstion Other Medical Device Regulations World-Wide 0
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
A Brexit Mandate for EU Authorised Representative for non medical devices CE Marking (Conformité Européene) / CB Scheme 6
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 2
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 2
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Procedure packs with non-medical devices EU Medical Device Regulations 1
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
