How to define Expected life service life of medical device
Kuldeep Singh
As we manufacturing the Medical device class IIb having Expected service life of 10 years.
We are trying to justify the class on the basis of critical components include a justification for repairable parts as some of these components have life of 7 years.Its a long discussion with Notify body during audit.So what can we do for defining the expected service life of medical device.
Do you have any template or guideline for defining the service life of medical device.
Thanks in advance
Jean_B
Expected service life comes from IEC 60601-1.
In the 2005 (third) edition it is stated to be:
"maximum period of useful life as defined by the MANUFACTURER"
In its integral update (3.1 edition; currently valid in nearly all situations) it is stated to be:
"time period specified by the MANUFACTURER during which the ME EQUIPMENT or ME SYSTEM is expected to remain safe for use (i.e. maintain BASIC SAFETY and ESSENTIAL PERFORMANCE)"
With the note: "Maintenance can be necessary during the EXPECTED SERVICE LIFE."
Beware you note 'define' instead of specify. Are you following the appropriate edition?
Two key things then are:
  1. Specified by the manufacturer, meaning you state it.​
  2. During which it is expected to remain BASIC SAFETY and ESSENTIAL PERFORMANCE.​
These last two are risk management core principles.
In short: first do no harm, second do the (clinical) good you must do to avert (an increase of) risk.
Thus reliability of combination of components leading to either aspect remains important.
If you always fail-safe, you don't have basic safety concerns that affect expected life. [This is the main concern to prove for 'shorter than expected service life' replaceable parts; and you could make a case for preventive/predictive maintenance through replacement (think tires of your car) to also serve this].
If you have no risky absence of clinical performance you have no essential performance concern.
The twist comes when you do have some failure modes (both unintended/unexpected as well as intended/expected) that increase risk, and often a case can be made that such risks do exist (but might be accepted!).
Hence on it becomes a bit of a discussion and interpretation, where usually the reliably predictable absence & accepted presence of (unsafe) failure modes determines what is useful life. Needed is a mastery of the risk management report and where you decide what is and is not acceptable risk, and how you justify accepting unacceptable risk becomes key inputs in the cut-offs for this, taking note that given the 'right' state-of-the-art indicated by standards and competitors these need not be zero risk.
Widely understandable example: as long as your post-market surveillance observes the occurrence and severity of irreducible (if you want to maintain your main effect) side-effects for medication to not exceed the levels you set as acceptable (based also on your competitors/society requirements) for within-shelf life product, the occurrence of the side-effect does not mean you broke basic safety or essential performance.
Kuldeep Singh
thanks for your clear vision.
From your comments i able to understand that we have to involve the risk factor.
But i am bit confusing that, how we document the service life of our device.We agree that we placed the device in market along with residual risk with risk benefit ratio and also we done preventive maintenance of each and every device. but yet there are some cases where we get breakdowns which is a normal for a machinery (Like puncher in your car).
How can we specify the service life of device
We had some difficulties with our NB over service life.
We said 'its a box of electronics - it does not wear out so it does not have a service life'.
They said - you have to define it and show that information in the Operators Manual.
Fortunately, we came across a guidance document (internet search) that gave a list of different devices and an expected service life for each type. We use that now as our justification.
Link to the guidance document (it covers many types of device):
http://www.flinders.edu.au/medicine...LifeSpanofBiomedicalDevices-GuidancePaper.pdf
Jean_B
But electronics do wear out, in non-intuitive ways. There are cycle, environment and stress limitations on their components and by extension the total device.
Referencing a 15 year old paper partly based on a for the medical industry outdated risk management standard is a quickfix that shouldn't be condoned.
Even the 1960's type military component reliability compendia indicate that these are based on assumptions you need to check against your case.
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
M How To Define ISMS (information Security Management System) Scope IEC 27001 - Information Security Management Systems (ISMS) 18
S How to Define Importers under EU MDR / Brexit EU Medical Device Regulations 3
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
Q QI Macro Histogram - Can someone define *sorted data*? Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
I How do you define Risk (Medical Device)? ISO 14971 - Medical Device Risk Management 30
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R How to define QMS certification scope statement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Procedure to define Signing Authority for Procurement Limits ISO 13485:2016 - Medical Device Quality Management Systems 2
P Can a company define new quality standards for special industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Are there any requirements to define barcode requirements ? Misc. Quality Assurance and Business Systems Related Topics 2
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
H ISO 17025 - How to define a "Test Equipment" ? ISO 17025 related Discussions 2
J Where do you define Internal Auditor qualifications? Internal Auditing 9
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T Internal Audit - How to define the Importance of Departments and Processes Internal Auditing 8
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
C How to Define and Document Controls of Outsourced Processes Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K How to define the Acceptances Criteria for all equipment? Manufacturing and Related Processes 7
L Definition Program - How do you define Program with regard to ISO 9001? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
Q Where to define Authorities and Responsibilities in Documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Criteria to define QMS processes in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 23
S How to define New Equipment? Device is Returned, Refurbished or Repaired Misc. Quality Assurance and Business Systems Related Topics 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
K How to define PVC Pellet Quality Manufacturing and Related Processes 8
J How to define a Product's Realization Process and Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S How to define Permissible Error for Measurement and Test Equipment? Measurement Uncertainty (MU) 3
