How to define one sided spec or two sided spec for 70 +0.3
aoe110
I meet the problem for dimension 70 +0.3 which needs to study Pp/ppk.
How to define this dimension as one sided or two sided spec?
Thanks.
well, it depends...these things are almost never as simple as they may appear.
for this feature, is 70 a physical bound? in other words, is it possible for values to be less than 70? if not possible then the tolerance is one sided.
otherwise it's two sided.
BUT if the target is 70 and not 71.5, then Pp is calculated differently then one would do for a two sided symetrical toelrance.
If you can tell us more about the feature we can provide more specific advice...
aoe110
This dimension is for the outer diameter of a steel pulley.
The target is 70.0, and the spec on drawing is 70 +0.3.
So how to work it?
Thanks.
Statistical Steven
Statistician
So how to work it?
Thanks.
Maybe I make everything too simple. The specification is 70.0 - 70.3. Though you can get values less than 70, they all FAIL! This is where the confusion comes in. You can look at this problem as a two-sided specfication, but a perfectly targeted process with very low variability still gives you a minimum of 50% defective by the mathematics.
IF and ONLY IF you change the dimension to be 70.15 +/- 0.15 would you have a real two sided-specification. Though this gives a false target.
Since I am not a huge fan of the Ppk/Cpk paradigm, I just report out the PpU in this problem and explain that a target of 70 can lead to upwards of 50% defective for undersize.
bobdoering
Stop X-bar/R Madness!!
So how to work it?
As Statistical Steven stated, the specification zone is 70-70.3. Period. It may infer that the design preference is a target of 70, but that has no relationship whatsoever with the process and its tolerance or process target. It may be normal about the center-point, or it may be a uniform distribution at 75% of the tolerance, there may be a natural stop that causes the distribution to be Weibull or beta skewed towards (or even away from) 70...it is totally a function of the process, not the design target. Sorry for the designer's luck....but, we can thank them for inferring their desires anyway.
Rameshwar25
But my question is while calculating Ppk, we should take target of 70mm or 71.5 mm. In both cases the PPk value will be different because:
1. if we take a target of 70, closer the value of mean to 70, better the PPk value will be. eg. value of mean equal to 70.2 will show better PPk rather than 71.3.
2. if we take a target of 71.5, closer the value of mean to 71.5 better the PPk value will be. eg. value of mean equal to 70.2 will show poor PPk rather than 71.3.
Kindly help.
Rameshwar
Statistical Steven
Statistician
Kindly help.
Rameshwar
Rameshwar
What formula are you using? Ppk is min(usl-mean/3S;mean-lsl/3s). Ppk does not depend on the target.
bobdoering
Exactly, the point of Cpk is whether your distribution is centered within the tolerance. And it primarily applies to normal distributions of independent data. If your pulley is machined, it should not be independent, so that would also not make the Cpk correct or meaningful - even though it can be algebraical calculated.
Mr.Happy
Hi all,
I also have a question concerning one sided tolerance.
What if the specs ask a hardness off 63 HV minimal ? How should I put this in a SPC calculation?
Mr.Happy
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
M How To Define ISMS (information Security Management System) Scope IEC 27001 - Information Security Management Systems (ISMS) 18
K How to define Expected life service life of medical device Other Medical Device Related Standards 4
S How to Define Importers under EU MDR / Brexit EU Medical Device Regulations 3
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
Q QI Macro Histogram - Can someone define *sorted data*? Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
I How do you define Risk (Medical Device)? ISO 14971 - Medical Device Risk Management 30
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R How to define QMS certification scope statement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Procedure to define Signing Authority for Procurement Limits ISO 13485:2016 - Medical Device Quality Management Systems 2
P Can a company define new quality standards for special industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Are there any requirements to define barcode requirements ? Misc. Quality Assurance and Business Systems Related Topics 2
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
H ISO 17025 - How to define a "Test Equipment" ? ISO 17025 related Discussions 2
J Where do you define Internal Auditor qualifications? Internal Auditing 9
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T Internal Audit - How to define the Importance of Departments and Processes Internal Auditing 8
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
C How to Define and Document Controls of Outsourced Processes Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K How to define the Acceptances Criteria for all equipment? Manufacturing and Related Processes 7
L Definition Program - How do you define Program with regard to ISO 9001? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
Q Where to define Authorities and Responsibilities in Documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Criteria to define QMS processes in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 23
S How to define New Equipment? Device is Returned, Refurbished or Repaired Misc. Quality Assurance and Business Systems Related Topics 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
K How to define PVC Pellet Quality Manufacturing and Related Processes 8
J How to define a Product's Realization Process and Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
