How to define R & D Receiving (Incoming) Inspection Plan
lisawxf80
Dear All,
I am in medical device line in R & D center. For our current new product development, my boss ask me to define a incoming inspection procedure or plan.
As what I know, the incoming inspection plan is the outcome of design output, I am not sure how to define upfront.
According to boss, the plan shall include inspection criteria, AQL, etc.
Can anyone advise me how should I draft this document.
Thanks!
Lisa
I assume this is for incoming inspection of raw material or components that will be used in the development and/or prototype builds?
In which case the R&D team may not yet know all of the important factors and their specifications but they will know some and will probaby have identified others through their design efforts even if they are not yet quite right. In thsi case the incoming material can be inspected for compliance of those factors to the specified tolerance limits.
In general, the incoming inspection can be based on the number of passing and failing units in the sample. (categorical or attributes data) Even if the actual insection is done by measurement (continuous or 'variables' data).
These plans work by specifying an AQL level (Acceptable Quality Level) or by specifying a RQL (Rejectable Quality Level) or both a AQL and RQL. In either case, R&D folks will benefit from having the continuous data of each unit inspected so that they know where the units lie in the specification range...there is probably more value in this data than in the simple inspection for pass/fail itself.
You can check out this spreadsheet to determine sampling plans based on RQL or AQL and RQL.
somashekar
Dear All,
Thanks!
Lisa
What is your role in the R&D center.
What ever it be, your broad understanding about inspection is pretty clear.
Your boss seems to be not in control of the current new product development.
Inspection criteria can be defined, however AQL is no business at R&D level.
In the various design review meetings, where bill of the materials are discussed, you may question each item about what is / are critical to product requirement and make your notes, to then include them into the specification. Prior to this, you will be good if you do some homework on getting to know more about each item in the BOM in relation to the selection for the new product, more so the custom design parts. You must even know about some regulatory requirements, RoHS if it applies, Safety mark on some components., and more. You must also get trained about materials, selection and application and be able to question them with the design team.
Good luck anyway Lisa ~~~
A clarifying question: are you developing the incoming inspection plan for when the new product launches into production or is this for materials that will be used during development?
Also what type of materials will bd indpected? discrete parts or batches of liquids or powders? The sampling plan will be different for discrete units than for batches...
lisawxf80
Thanks for the advise. Would like to clarify whether you are saying we should have to check each units for the raw material during development phase to gain enough data and then decide on AQL OR RQL? As of now, our raw materials come into different quantities, sometimes 50pcs, or 100pcs, my boss said that our incoming guy is not able to perform 100% check. However, I think we should do thorough study during R & D phase, as we do not know anything at this stage, should access in different ways. Am I right to say that.
Thanks & Regards,
Lisa
lisawxf80
This is the materials that will be used during development. Mostly are discrete parts without batch identification. Basically they were used for study purpose, as we are in the prototype stage.
lisawxf80
I am QA in R&D, not sure whether I should take the role to define this, as I have not enough knowledge on how to define the critical features of each materials. I agree with you that AQL is no business in design phase, what if we need to define in future production phase? my boss was asking the R & D guys will not know how to define AQL as design output.
somashekar
Who ever told AQL is a design output ...
At R&D stage you define requirements. It is upto the purchaser and supplier to determine what AQL can be agreed at.
AQL is a statistical term and gets applied after process capability estimation and organization's requirement for a particular part.
You are QA in R&D... I guess everyone in R&D must be a QA.
I am still wondering why your boss is stuck with AQL.
I
ISAN16
U can refer to AQL sampling plan, in AP 5442. draft in simple way by attaching the table as appendix. ( Eg. Table S-4, 1.0 %)
D FDA combo product-need to define direct & indirect impact regarding safety,quality & regulatory.Can anyone point me in right direction-SupplierMgmt 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B How FDA define a new variant/generation or a new device US Medical Device Regulations 11
FoGia How to define/identify emerging risks? EU Medical Device Regulations 7
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
M How To Define ISMS (information Security Management System) Scope IEC 27001 - Information Security Management Systems (ISMS) 18
K How to define Expected life service life of medical device Other Medical Device Related Standards 4
S How to Define Importers under EU MDR / Brexit EU Medical Device Regulations 3
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
Q QI Macro Histogram - Can someone define *sorted data*? Capability, Accuracy and Stability - Processes, Machines, etc. 7
hiepyeuh How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
I How do you define Risk (Medical Device)? ISO 14971 - Medical Device Risk Management 30
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R How to define QMS certification scope statement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Procedure to define Signing Authority for Procurement Limits ISO 13485:2016 - Medical Device Quality Management Systems 2
P Can a company define new quality standards for special industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Are there any requirements to define barcode requirements ? Misc. Quality Assurance and Business Systems Related Topics 2
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
H ISO 17025 - How to define a "Test Equipment" ? ISO 17025 related Discussions 2
J Where do you define Internal Auditor qualifications? Internal Auditing 9
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T Internal Audit - How to define the Importance of Departments and Processes Internal Auditing 8
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
C How to Define and Document Controls of Outsourced Processes Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K How to define the Acceptances Criteria for all equipment? Manufacturing and Related Processes 7
L Definition Program - How do you define Program with regard to ISO 9001? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
Q Where to define Authorities and Responsibilities in Documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Criteria to define QMS processes in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 23
S How to define New Equipment? Device is Returned, Refurbished or Repaired Misc. Quality Assurance and Business Systems Related Topics 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
