How to Define Scrap Metrics & Objectives - Stamped Cold Rolled Steel Fasteners
juliov
Attention Quality Pros:
My company stamps cold rolled steel fasteners to be used in bedding and upholstered furniture and some automotive seating industries, the clips are stamped from slitted strips of steel of about 1/2" to 3/4" in width and about .033 to .039" in thickness, the strips are part of slitted parent coils with about 12 strips per parent coil.
The issue we are having is how to define a metric for scrap, the pressess are small and are very efficient in the stamping, we are not sure as to what to call scrap, for ex: nonconforming material stamped can be classified as scrap, or set up of the presses and the material that is wasted in the set up process? We know the process naturally produces some by product due to the stamping it is not much.
Any ideas as to scrap metrics let me know.
thanks,
Re: How to Define Scrap Metrics and Objectives - Stamped Cold Rolled Steel Fasteners
thanks,
First you have to define what "scrap" means. In stamping there's always going to be scrap material left over, which includes all parts of the strip that are left over after the parts have been made. "Scrap" can also refer to "bad" parts that can't be salvaged through rework (for whatever reasons). The idea is to reduce the amount of material that doesn't wind up in the parts themselves to a reasonable minimum. This includes setup scrap--any part of the raw coil that gets thrown out before production actually begins, as well as bad parts produced during the run.
In general, it's best to classify scrap by process, such as setup scrap, production scrap, etc., and then by defect types--mis-hits, excessive burrs, etc., the object being to address the causes and correct them.
juliov
Hello Jim,
Yes, you are on the right track about the defining scrap, we had not seen it as such, it appears as an equation:
scrap = set up scrap + prod scrap + storage scrap + in transit scrap+ etc..
and the defect types can be defining factors to classify the what is scrap?
Ok, thanks for the input, any other ideas or comments let us know.
THANKS,
P
Pudge 72
As a Stamper myself - remember, check the quote, usually there are provisions for cost based on your strip layout that take into account the inherent scrap produced by the die.
Differentiate this from the scrap produced from the part.
You can however find out the inherent scrap and change that amount by potential redesign of stations, a program such as Logopress or Quickpress can tell you exactly what % of material you are producing / scrapping in slugs as a result of progressions.
Of course, the scrap produced by the process itself is then measured as the output of product that either conforms or does not - use that data to improve your process.
juliov
Thanks for the very valuable info Pudge, our mgmt team will integrate your comment during the evaluation of scrap meeting. By the way, how did your operators of the presses collected the scrap? where was it taken to for weighing? etc.
F How to define/identify emerging risks? EU Medical Device Regulations 7
A Define timeline for Major and Miner Audit finding General Auditing Discussions 4
T How do you define your Hazards? <a Risk Management discussion> ISO 14971 - Medical Device Risk Management 16
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
V Who should define and own the Design and Development Plan and how to maintain the updates and revisions. ISO 13485:2016 - Medical Device Quality Management Systems 2
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
M How To Define ISMS (information Security Management System) Scope IEC 27001 - Information Security Management Systems (ISMS) 18
K How to define Expected life service life of medical device Other Medical Device Related Standards 4
S How to Define Importers under EU MDR / Brexit EU Medical Device Regulations 3
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
Q QI Macro Histogram - Can someone define *sorted data*? Capability, Accuracy and Stability - Processes, Machines, etc. 7
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
I How do you define Risk (Medical Device)? ISO 14971 - Medical Device Risk Management 30
M SOP or template for a study to Define Storage Conditions of Orthopaedic Implants EU Medical Device Regulations 3
D Definition Client - How does the government define their clients? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 1
alonFAI How to define a Risk Based Approach for Supplier Management per ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
G How to define the scope of QMS as per ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
R How to define QMS certification scope statement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Review of "Key Data" for contract labs, but SOP doesn't define "key data". Problem? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
G Procedure to define Signing Authority for Procurement Limits ISO 13485:2016 - Medical Device Quality Management Systems 2
P Can a company define new quality standards for special industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
L Are there any requirements to define barcode requirements ? Misc. Quality Assurance and Business Systems Related Topics 2
X How to define Calibration Acceptance Criteria General Measurement Device and Calibration Topics 3
H ISO 17025 - How to define a "Test Equipment" ? ISO 17025 related Discussions 2
J Where do you define Internal Auditor qualifications? Internal Auditing 9
V Is there an approach to define the "must 'or' should" in supplier audits? US Food and Drug Administration (FDA) 2
T Internal Audit - How to define the Importance of Departments and Processes Internal Auditing 8
T Help me understand how to define Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
C How to Define and Document Controls of Outsourced Processes Food Safety - ISO 22000, HACCP (21 CFR 120) 5
S Please help me define training requirements for a Career in Regulatory Affairs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K How to define the Acceptances Criteria for all equipment? Manufacturing and Related Processes 7
L Definition Program - How do you define Program with regard to ISO 9001? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
A Supplier Evaluation SOP - How do I Define Major and Minor Suppliers? Supplier Quality Assurance and other Supplier Issues 14
Q Where to define Authorities and Responsibilities in Documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Define Energy Used/Delivered - Applicable to Electrical or Mechanical Power or both? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 820.50 (A) (2)Define the Type and Extent of Control to be exercised over Vendor Misc. Quality Assurance and Business Systems Related Topics 5
A Where to define Process Tailoring Form used in CMMI in the ISO 9001 Quality Manual? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Criteria to define QMS processes in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 23
S How to define New Equipment? Device is Returned, Refurbished or Repaired Misc. Quality Assurance and Business Systems Related Topics 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C How to define Process Special Characteristics (SC) FMEA and Control Plans 4
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
M Excel Templates for Plan & Define Phase in NPI Process for Tire Manufacturer Excel .xls Spreadsheet Templates and Tools 1
R Define Data from Taguchi to Response Surface Methodology in Minitab Using Minitab Software 2
K How to define PVC Pellet Quality Manufacturing and Related Processes 8
