How to determine Equipment Tolerance Variation - Product vs. Process Tolerance
Dongzkie
Product/Process Tolerance (conductor gram weight per meter) = +/-0.08g
Gram Scale accuracy = 0.01g
Test weights = Class F ( set of 50g to 1mg )
how to determine the tolerance during equipments verification.
Stijloor
How to determine the tolerance during equipments verification?
Can someone help?
Thank you very much!!
Stijloor.
BradM
Hello there!:bigwave:
Have you calculated an uncertainty analysis for your process? I would start with that. Then, go four times that much.
It would also depend on the previous history of this balance, what range it is being used at, precision, etc.
As far as the acceptance tolerance, again, depending on the history of the balance, I would set the tolerance at the process tolerance. The only time the user should be notified of a failure is when it will affect their process.
When you say .08g, the balance can be .07 grams off and not affect anything? Or do you need to take 1/2 of the .08grams, and state that .05g might affect the process? Does that make sense? Let me know if it doesn't. I'm asking if the .08 is .08 heavy and/or .08 light; or .04 heavy and/or .04 light. :)
G
Geoff Withnell
Product tolerance and process tolerance - which are we discussing? Process tolerance is usually set as the portion of the product tolerance "budgeted" for this particular process, the maximum variability we can tolerate for this process. The measurement variability is an inherant part of the process variability.
Geoff Withnell
Dongzkie
ex. process ==> conductor gram weight==> nominal:5.01g ; max:5.09g ; min:4.93g
GramScale readability is 0.01g ==> i want to know how to set a tolerance for the equipment with regards to the process.
BradM
I would suspect your uncertainty should not be a significant factor, but should still be calculated. I would set the tolerance for +/-.08 grams. I would adjust and such if there is any error observed. But only report if it exceeds process tolerance. However....
I have not seen anything about the balance capability. Not sure how it has been performing or what the mfg. tolerance is. You will be hard pressed to set a tolerance tighter than mfg. specification for it. :)
R How to determine Failure Tolerance Time of Laser Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 27
E How to Determine Tolerances for Equipment Verification General Measurement Device and Calibration Topics 18
D How to determine if equipment is GMP compliant? Qualification and Validation (including 21 CFR Part 11) 6
U Guidelines to determine which equipment to do MSA on Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
R Test & Measuring Equipment - Statistical studies to calibration determine frequency Calibration Frequency (Interval) 3
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
