How to Determine Run At Rate: Steel Coil Processing
D.Scott
#11
Andrews
Assuming you are doing a PPAP on the whole process as one part, you would have to look at the stages seperately to determine your constraint. The constraint is the "bottleneck" that determines how many FINISHED pieces can be made within a given time. For example, if you find a constraint as the first process in line, you may be able to elevate the constraint by "stocking" an inventory.
In the case you outline, the last process appears to be the constraint. Your "run-at-rate" would be 200 nos./hr. If you did some streamlining and raised that constraint to say 500 /hr, then your constraint becomes #2 and the "RAR" is elevated to 300 nos./hr.
Dave
#12
I would sugeest you contact your customer for the particulars. Again, each customer has a slightly different requirement for their "[email protected]". Ford, for example wants overall equipment effectiveness (OEE) figured in to the results.
Bill Ryan - 2007
#15
Run at rate is also part of the Part Submission Warrant sent with PPAP
Dave,
Where on the PSW is a line for "[email protected]"? Are you talking about the "Declaration" section which asks for the production pcs./8hrs.? I only give our quoted capacity figure on that line - not the [email protected] figure. Typically, with our customers, the "official" (customer on-site) [email protected] doesn't even happen until after PPAP approval.
Just want to make sure I'm not missing something (not that hasn't ever happened!!!)
Bill
D.Scott
#16
You don't ever miss anything LOL :vfunny:
Yes, I am referring to the declaration section. You are absolutely correct, the run at rate is a study in its own and I probably shouldn't have used the term for this section.
We have found that many of our customers and our QS auditor refer to it as a run at rate so we just follow along.
Sorry for the confussion. :truce:
Dave
Dadzee
#18
Dave and Sam, Hello to you both. New to the boards today, and very happy to have found such a resource. I am just an hourly shmo with no Qual degree but work with PPAP, auditors and such every day.
I am looking at table 1.4.1 and of the 19 elements for submission I see no [email protected] I have never had any inside or outside auditor address this, but you never know what will catch their fancy some days as opposed to others.
Is the [email protected] perhaps contained within some of the required documentation such as the DFEMA ?
Will be looking for your knowledge to infect my brain. Thanks
Dadzee
Dadzee
#19
DOH !
OK found it in sec 2...shoulda peeked all the way into Sams post for the section....So this is simply stating that when Process Potentials,R&Rs and such are calculated they must be with parts run at and in real world conditions ?
Dadzee
H
Hermann - 2011
#20
In the part submission warrant you only state the production rate.l
Ford often require an Overall Equipment Efficiency analysis as part of their Launch Readiness Review (find the bottleneck operation and calculate/measure the production rate)
GM's [email protected] procedure is GP9.
Exactly what an STA or SQE will want to witness is up to him. Often, if you have worked with them before, they will take your word for it and move on to the next supplier! In any case witnessing [email protected] is after PPAP.
Hope this helps
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar How to Determine the Necessary Employee Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
