How to Determine Sample Size for Cp Cpk
RoscoeSplevins
#11
We are high precision machining. Very accurate, usually small, low mass. Capability per feature on those parts we have done studies is very high; 2.0 and better. Item in question is low sophistication. Simple geometry, managable size. We just don't study these.
We feel comfortable with our study method. We may not be the best at statistical studies but we make a damn good part.
Our issue is HOW do we select and justify our sample size. Customer is expecting a calcualtion and reasoning. We need to reference some (any) industry standard or practice. A white paper or 6 sigma techique would suffice. But our contact is pushing for detail. This customer is isnsiting on approval of content pre-PPAP.
#12
We are given thier requirements of confidence and a "power" for our calculations. But were not given sample size or a formula for sample size. A request for direction or requirement got us the -no rule of thumb, and justification memons!
You must know the ~ total standard deviation of the process.
What typically freezes peopel for new products is that any capability study is an iterative process - it is not a one time thing.
A first approximation is to use what you already know about similar processes and characteristics. how much variation do you typically experience? Is the variation 'homogenous' (in other words is the largest amoutn of variaiton seen from piece to piece) or are tehere large differences between setups, raw material batches, operators, beginning to end of a run (do you have shifts, drifts or cycles?)
bobdoering
Stop X-bar/R Madness!!
#13
Are these short run parts? It sounds like you do not do SPC on this process for control, is that true?
RoscoeSplevins
#14
Short run, usually 200-500 per order. Next run may not be for months. May be next week.
This is a new part, projected for long term. We don't normally do SPC. We will do data collection and post-completion reporting when required. Ours is a high precision environment. Variation is usually limited to tool wear. Cycle times are such that operators can (but not requried) to 100% for critical dims. Most do. Our run charts are kind'a sawtooth shaped, random up and down is for the most part measurement error (a function of tolerance and machine capability) and very small.
bobdoering
#15
This is a new part, projected for long term. We don't normally do SPC. We will do data collection and post-completion reporting when required. Ours is a high precision environment. Variation is usually limited to tool wear. Cycle times are such that operators can (but not required) to 100% for critical dims. Most do. Our run charts are kind'a sawtooth shaped, random up and down is for the most part measurement error (a function of tolerance and machine capability) and very small.
Perfect. That is exactly what you should see in precision machining. That means Cpk calculations are not correct for your operation. It is non-normal. The next question is what do you run your characteristics to, 75% of the tolerance or so to allow for the part measurement error?
RoscoeSplevins
#16
Production has min/max limits lower than print spec. Usually about 75%. Process inspection has min/max limits set a little higher (varies by situation). Final inspection uses print spec.
Long term data is kind'a upside down bathtub shaped. I have been told Cpk is not valid for this type capbility but never heard a good explanation. Not covered in college, not covered in SPC seminars. Found a book with detail, but didn't want to spend 120.00! WHAT technique should be used with non-normal, repetitive data?
bobdoering
#17
Long term data is kind'a upside down bathtub shaped. I have been told Cpk is not valid for this type capability but never heard a good explanation. Not covered in college, not covered in SPC seminars. Found a book with detail, but didn't want to spend 120.00! WHAT technique should be used with non-normal, repetitive data?
If you use 75% as production "limits" and you get sawtooth curve between them, then the
Capability is: (USL-LSL)/.75(USL-LSL) or 1.33
The explanation is that the sawtooth curve is a non-random continuous uniform distribution. Cpk calculations are for random distributions, typically normal discrete processes. The book that describes it correctly is linked in the area you go if you click my name, view public profile - and go to the website cited there. You can read most of the info for free here. Long term data is more affected by sop/start locations and special causes - such as warm up, material changes, other lot to lot issues, etc. Long term data is less representative of the process capability than the actual sawtooth curve you get.
Even if it was covered elsewhere...it was probably covered wrong. If you read the blog you will see it makes a lot of sense to somebody that really does precision machining.
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
U How do I determine Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
P Use of Historical Quality Data to determine Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
Tim Folkerts Sampling Spreadsheet to help determine the Sample Size for Sampling Plans Inspection, Prints (Drawings), Testing, Sampling and Related Topics 54
B Sample size to determine confidence interval Quality Tools, Improvement and Analysis 5
R How do I: Determine Sample size, Number of Trials and Appraisers for MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Sampling Plan to determine sample size/frequency based on a Given Rate of Production Inspection, Prints (Drawings), Testing, Sampling and Related Topics 40
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
