How to determine the correct Sample Frequency for SPC Features
bobdoering
Stop X-bar/R Madness!!
#51
Re: How do I determine a correct Sample frequency for SPC features?
So where do you stand on Bob Doering's approach. Although I understand his approach, I'm handcuffed with using QC-Calc (Xbar / R charts only). Please expound on how you would approach should be used for sub-grouping if your only option was Xbar and R charting (what would be a rational sub-group for precision machining?)
The problem is if you are precision machining, there is no sampling rational that can make the X-bar/R work. I have case studies that prove that not only is X bar-R OR I-MR wrong, they give the exact opposite signals to the true condition of the process - i.e. if the process is out of control on X bar/R it is actually in control and vice versa. Those are the absolute worst charts you could ever use for precision machining - bar none. You are better off using paper charts than confusing your operators with an automated system that is wrong. In fact, I did that, replaced a computerized SPC system with paper charts - in a union plant - and they actually appreciated it because finally the charting made sense.
You may want to approach QC-Calc and ask them is they have correct charting (X hi/lo-R) for machining, since they claim to offer SPC software. You get more traction as a customer than other people might. It's sad if they don't know about it - the technique has been published for over 10 years and implemented much longer than that. And....it is correct!
N
ncwalker
#52
Got an example of Xhi Rlo?
I'm the guy who can sexy it up.
#55
Proud Liberal: Bob's approach is correct for 'slow' tool wear that occurs over many parts. (And there are other processes that will exhibit this behavior).
Technically this steady movement in results is an assignable cause. We know what's causing it. The Xbar, R chart and I, MR chart will correctly identify it. The issue is that this cause is not something that can be economically removed or controlled to the 'within subgroup' variation of a homogenous process.
The answer is not to try to find some other rational sub grouping scheme as we might do with processes that have other types of non-homogeneity (like multiple cavity plastic injection molds). The answer is to change the chart type. (Which can be argued to be a form of rational sub grouping). The chart that Bob proposes is not the only choice. Donald Wheeler proposes the use of 'sloping limits' that incorporates the within subgroup variation as well as the mean drift. Both work just fine.
You are not forced to handcuff yourself to a statistical program that doesn't include this type of chart. You chose to accept this constraint. You can choose to not use it. Remember that the point of SPC is to control and improve your processes as close to the process as possible. It is not to use SPC software.
There is no logical reason to not use another approach when the process calls for it. Have the operators use paper or Use EXCEL if they have laptops at their machines.
I suspect that your organization is using QC-Calc for purposes other than on line control processes by the operators?
Proud Liberal
#56
The use of QC-Calc's XBar charting is MANDATED by the owner and president. We even had Bob out to our facility presenting his approach (which fell on deaf ears). When the decision was made to move our SPC activities from PLEX (ERP software) to a dedicated statistical package, my lobbying for InfinityQS was overruled in favor of QC-Calc.
Now, I'm tasked with making this work (not possible in my opinion). In addition to charting offset-able dimensions (ones that the operator can make process adjustments to), we also chart dimensions they can't control (ie: roundness, runout, etc). The cherry on top is that the president wants to "control" the processes in the shop by the daily monitoring of Cpk.
My apologies if my frustration is showing but I don't like being setup to fail. At least here at the forum, rational minds prevail. There, now that I've let off some steam, I feel better even though I'm destined to fail.
#59
Presidents do not have the competency to determine a rational subgroup any more than you have the competency to run a merger or acquisition. You need to educate them that correct SPC depends on the type of data and the process. These determine the type of chart and the basis for rational subgrouping. This cannot be done by edict.
#60
While I am a huge fan of Wheeler, this is one of those concepts that sound good in theory, but don't work in practice. First of all, it is overly complicated for use in a factory by machinists. Second, there are too many variables in machining that will affect the tool wear rate (i.e., the slope of the limits). Once you have accepted the fact that you can live with the quasi-uniform distribution of the output, detecting a signal that the tool is wearing faster or slower than the baseline is irrelevant. I agree with Bob D. about keeping it simple and easily understood.
As Shewhart (and Deming) always said SPC wasn't about probability, it was about economic control of the process. 3 sigma limits happened to be economical and struck the right balance between false alarms and missing a signal.
T How to determine the correct QMS I need Misc. Quality Assurance and Business Systems Related Topics 3
P Plastic Identification/Test - Melt Flow Index to Determine Correct Material? Manufacturing and Related Processes 16
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar How to Determine the Necessary Employee Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
