How to determine the ratings of components in primary circuit
Roland chung
Hello forum,
The standard just says the components including wiring shall be used in accordance with their specified ratings, but it is unclear how to determine the ratings.
For the current rating of components in primary circuit, three options swim into my mind:
1) not less than the current rating of primary protective devices, such as mains fuses, circuit breaker
2) not less than the rated current of equipment
3) not less than the current that components are intended to carry when the equipment is operating under normal load
Which one mentioned above do you think is correct? Can I have your opinions?
Many thanks,
Roland
Peter Selvey
In general it's the normal condition of use, unless the part is required to keep certain characteristics also under abnormal/fault conditions.
For example, equipment rated 2.5A, actual input is 1.7A, with a fuse of 3A, has an EMC inductor rated for 2A. It's generally OK because 2A > 1.7A, and because under abnormal condition there is usually no safety issue with an inductor overheating.
However, if the inductor happened to be near double insulation, then rating might need to be checked also in abnormal condition.
Roland chung
That means component which is safety relevant should be considered under normal conditions and fault conditions. Right?
Is it ok for high capacity equipment rated 100A, actual input is 30A, with a circuit breaker of 125A, has a terminal block rated for 50A?
Peter Selvey
For the example shown, clause 4.8 of IEC 60601-1:2005 should be Pass. If it were not, we would be in a situation where all components after over-current protection (fuse or circuit breaker) would have to be rated the same or higher than the over-current protection, which is not practical.
However, if there is a large difference between the rating of a component that carries fault current and the rating of the over-current protection, there may be doubt about suitability in fault condition. It's not a non-compliance, but tests may be necessary under 8.11.6 b).
For example, a 100A circuit breaker protecting a 2A terminal block would clearly require a test, in the test we could expect the terminal block to burn out or even explode before the breaker trips, potentially damaging insulation, starting a fire or scaring the pants off the test engineer.
A 100A breaker and 30A terminal block is probably OK. To keep the temperature rise down, a 30A terminal would need to have less than 0.001ohms contact resistance, which is negligible in the overall circuit including under fault conditions (in contrast, a 2A terminal could have 0.1ohms contact resistance, which is relatively large).
Roland chung
But the point in 60601-1:1988 is that the current rating of over-current releases shall not be greater than the current rating of any component in the mains circuit carrying the mains supply current. We can find the statement in clause 57.6
Peter Selvey
It seems this requirement was removed in the 3rd edition. In the 2nd edition the text is any part "carrying the mains supply current" but that is undefined, imprecise and doesn't make sense for a number of reasons.
To comply with the second edition, you could fall back on Clause 4.1, which states that requirements are only applied if there is some safety relevance.
But of course it could be difficult to convince a test lab to agree :D
Roland chung
Although there is no a definition for "carrying the mains supply current", it seems obvious. I would think it is not a valid arguing point.
Regarding the test to verify the suitability of component, the test lab said type test is always not sufficient when it comes to the component.
Peter Selvey
It's obvious in some cases, like a single circuit that has only supply leads, terminal block, switch and a heater.
But what if there are branch circuits? Do you apply to each branch? If yes, each branch will then require a separate fuse according to the parts in that circuit. If no the requirement makes no sense (why apply just to the "main" circuit? It's inconsistent).
But if you apply the "fuse each branch" rule, then any parallel component (capacitor, diode bridge, bleed resistor etc) becomes it's own mini branch circuit, which would require a fuse ... it would be endless and impractical.
The real situation is that that most small parts don't rely on the fuse to protect against fire. Rather, the small size of the part limits the fault energy, they tend to burn out on it's own, and any fire will be limited through the use of non-flammable materials (PCB, wiring, enclosure etc). I once tried to start a fire using tissue paper and an overloaded 0.25W resistor, it was impossible.
For high current parts (10A or more), I-squared-R power loss means the resistance has to be very low just to be functional. It's not really an issue for fire caused by overcurrent, unless the fuse size is >> rating (e.g. 10 times higher).
But there is a sweet spot in between where neither of these apply. A large bulky part rated for 2A protected by a 10A fuse could be trouble in fault condition. This happens some times with high power resistors (intended for inrush or dumping capacitors), exceeding 400C in SFC for extended periods.
If in doubt, do the test.
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar How to Determine the Necessary Employee Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
