How to determine the reference voltage for three-phase transformer?
Roland chung
Dear all,
This is my first post here. I found some experts herein and hope to get some useful information from this forum.
We manufacture X-ray equipment for diagnostic purpose. As you can see from the caption, my question is related to reference voltage of three-phase transformer (reference voltage used for determination of clearance & creepage, etc). In our X-ray equipment, the primary part (line to line voltage is 400V) of three-phase transformer is delta connection (without neutral) and the secondary part (line to line voltage is 208V) is star connection (the neutral combines the earth, as referred to PEN).
Wondering how to consider the reference voltage between input line (primary) and earth (barrier A-a1 in iec 60601-1), between input line and output (barrier 17.g.4 in iec 60601-1).
Thanks in advance.
Stijloor
Dear all,
Thanks in advance.
Any X-Ray equipment experts that can help here?
Thank you!!
Stijloor.
Tim Folkerts
This seems like more of an electrical engineering question than a question about either quality or x-rays.
There are a wide variety of experts here, but I don't recall many electrical engineers answering questions, so there may not be many people here with the expertise to address your question. I have a vague understanding of three phase wiring and delta connections on transformers, but I don't know enough to answer your specific question.
BradM
Any voltage reading off of a transformer is going to depend on the incoming voltage supplied to that transformer. What is specified by you as the mfg.?
When you state "primary part" and "secondary part", is that referring to the primary voltage (feeding a transformer) and then secondary voltage (coming off the transformer)?
Also, if you don't mind, can you explain to me what PEN is? I am not familar with that term.
As far as considering any of the voltage, again I would think that is highly dependent on the nominal voltage (and the deviation of actual voltage from nominal voltage) supplying the transformer.
Are you asking what the acceptable leak rate (in volts) should be from the supply voltage to ground?
Sorry for so many questions. Just trying to figure out a little better exactly what you're looking for.:D
BradM
No one wants to share his/her experience, a little bit of disappointment. :(
Roland, I don't think that is the case. That's a pretty specialized question you got there; that requires asking an electrical contractor (and/or an electrical engineer) that does work in the medical industry. Most of us are a bunch of quality nuts!!:lol::lmao:
However, I'll certainly try to answer any question for you.:agree1:
Al Rosen
To answer the original question using my limited knowledge of the system, I believe that you can ignore the primary to secondary since they are isolated from each other. Use the 120v line to neutral for the spacing of the secondary & neutral/ground. Use 208 volts for calculating the spacing requirements between the lines. Use 400v for spacing requirements on the primary. Just my opinion.
Peter Selvey
This can be worked out theoretically by knowing the peak voltage (with respect to earth) and phase relationship between each of the primary and secondary windings. Alternately, you may find it easier to simply to measure the working voltage between each points in turn, e.g.
P1 - S1
P1 - S2
P1 - S3
P2 - S1
etc until
P3 - S3
(total 9 measurements)
It is possible depending on the construction that at one or more of these nine combinations will have a secondary voltage that is 180 degrees out of phase with the primary, so that the working voltage at that point will be simply Vw = Vp + Vs, where Vp and Vs are the primary and secondary rms voltages with respect to earth (not line to line). So, in your example, Vp = 230Vrms, Vs = 208Vrms, so Vw = 438Vrms.
It is normal in safety testing that engineers ignore the secondary voltage, which is reasonable when the voltage is relatively low (e.g. 24Vrms). They do this because with the second edition, the real working voltage can often be slightly above 250Vrms (e.g. 230Vrms + 24Vrms = 254Vrms). This puts the cr/cl in the next column which is a massive overkill. So everyone has quietly agreed to ignore the secondary voltage.
However, this should not be done if the secondary voltage is large, such as your case. In this case there may be real working stress of 438Vrms, which should have appropriate cr/cl for that voltage. That said, the 3rd edition has some more realistic values than the 2nd edition.
Roland chung
Dear all,
Many thanks for your input.
Peter, your answer makes more sense. In fact, I have measured the working voltages between primary and earth, between primary and secondary.
As you said, the maximum working voltage between primary and secondary is equal to primary rms voltage plus secondary rms voltage with respect to earth, i.e. 230V+ 120V= 350V. (I think you made a little mistake, the 208V is line to line voltage)
This raised another question. That is the measured vlotage of 350V less than the input voltage of 400V. I would think the reference voltage shall be 400V at least.
Furthermore, the primary part of three-phase transformer is delta connection without neutral. Why do not you consider the primary line to line voltage plus secondary line to line voltage (i.e. 400V+ 208V= 608V) when determined the voltage between primary and secondary?
Best regards.
Roland
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T How can I determine the current level of exposure to talc in the workplace? Occupational Health & Safety Management Standards 6
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
I How to determine "generic/me too" device? Japan Medical Device Regulations 0
J UDI-DI how should we interpret Device version or model to determine if a new UDI-DI is needed? EU Medical Device Regulations 0
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S Is using ANSI/ASQ Z1.4-2008 the correct sampling plan to determine Pass/Fail of Apparel measurements? AQL - Acceptable Quality Level 8
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
armani Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
