How to Determine Tolerances for Equipment Verification
E
ermoth
Hello Calibrating Covers,
My job is document control and my manager has asked me to make a record for monthly verification of our Surface Roughness Tester. The equipment is calibrated by an outside company every three years, but we want to verify it internally on a regular basis.
We have a "Precision Reference Specimen" (master) that will be used during verification. When I asked my manager what tolerance will be used he asked me to look it up online. I really don't know what to do from this point.
Any help would be greatly appreciated.
E
ermoth
I'll just go ahead and add the steps I have already taken.
1. I looked on the "Precision Reference Specimen" for a tolerance. I did not see one. If there is one there, I don't understand it.
2. I googled. No luck there.
3. I checked the calibration records for when we've had the "Precision Reference Specimen" verified. They appear to have used two different tolerances on the two different times they've done it.
Jerry Eldred
I'm probably not nearly the statistics expert that some are on this forum. But if I were going to have to "arbitrarily" derive a limit, it would be some portion of either the tolerance of the specimen, the RS combination of the tolerance of the specimen combined with the tester, or a critical product limit. Small enough that a drift beyond a given value would tell you something is either wrong with the tester or that something is going out of statistical control.
Just to stir things up and give the more expert members something to (rightfully) disagree with, I might start with 10x tighter than some critical applicable specification. In the semiconductor world, using SPC (Statistical Process Control) there are spec limits and control limits (the control limits being some multiple tighter than spec limits to guardband the process limits).
Maybe I've posted enough to get some further discussion on this.
David DeLong
The rule of thumb is 1/10th the tolerance in its tightest application. I have a copy of ASME 14.43 on gage making tolerances and they have also used the 1/10th concept.
Marc
:topic: Jerry, is "guardband" or "guard band" the proper way to 'spell' it, or does it particularly matter? I've seen it written both ways. I'm just curious.
E
ermoth
I'm really not experienced in this technical area, so could you explain this a little more to me? What do you mean by "tightest application"? Would that mean: Of all the measurements the equipment is used for, use the one with the tightest tolerance?
E
ermoth
Thanks for the input, but I'm afraid I'm going to need this explained in layman's terms. :eek:
David DeLong
Yes, you are correct that the tightest tolerance of application, one would use 1/10th the tolerance range as the calibration range of the instrument. This is a bit easier on a vernier caliper where one is using it on a part with a +/- .010 ". The range is .020 so the range for the calibration of the instrument is +/- .001.
Since your instrument is used where there is a unilateral tolerance. I would take the tightest tolerance where it is utilized and then take 1/10th of that value. Now you have a master sample that has been set at a certain roughness. Confirm it on the sample.
Sometimes the 1/10th rule is not applicable if the application is too tight so go "state of the art" which means that you phone the maker of the product and find out the calibration range is on a particular standard. That is it.
Good luck.
G
George Weiss
I offer my view as a calibration tech.
Generally a manufacturer’s service manual and spec sheet would be reviewed.
I viewed the spec-sheet, and a similar item, and found that these devices calibrate/zero-out with a roughness std. No +/- limit tolerance(s) were listed. The device basically is specified to report back 1:1 as the standard material, which was offered for the device auto-calibration.
In the K-mart commercial calibration field, this item is viewed as an EASY-CAL by a calibration tech. It works or it doesn’t. An interesting discussion would arise if you asked the outside calibration vender "what +/- tolerance did you test this device against to achieve a 4:1 TAR and determine it PASSED?" . A calibration occurred because a reference standard, (SRM), traceable to NIST was used, but to make a ISO-17025 data-sheet would be interesting.
GOOD hunting on this one !
NIST roughness standards uncertainty budgets would give a direction to best possible accuracy
http://www.nist.gov/mel/ped/smm/upload/nistsurfcalib.pdf
On the 20 AUG 2009 the question came up.
Calibrating Mitutoyo SJ-201P Surface Roughness Testers
A good spec page for reference
http://www.mitutoyo.com/pdf/1902SJ400.pdf
Daniel Walker - 2011
The manufacturer's stated accuracy should also be considered. You will be chasing your tail with service and recalibration visits if you try to hold a tolerance that is tighter than the unit was manufacturered to operate within. This is usually not the case but something to definitely keep in mind.
L How to determine / validate Medical Device Storage Conditions ISO 13485:2016 - Medical Device Quality Management Systems 1
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
E How do you determine if hipot is necessary for a cable product? Manufacturing and Related Processes 8
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
O Monitoring performance - How do I determine performance measurement basis within my organization? Misc. Quality Assurance and Business Systems Related Topics 4
T IEC 60601-1 - Risk assessment to determine the liquid - 11.6.3 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
Ashok sunder How to determine the internal and external issues in ISO 45001 standard? Occupational Health & Safety Management Standards 2
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
samer Do we have to determine Educational level for all Staff as pr 7.2 b clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Supplier Qualification - How do we determine which suppliers to qualify? ISO 13485:2016 - Medical Device Quality Management Systems 9
K ISO 13485:2016 Cl. 4.2.3 - Determine QMS Processes, Monitoring, Measuring, etc. ISO 13485:2016 - Medical Device Quality Management Systems 4
A Compliance Obligations - Implementing 6.1.1 and 6.1.3 NOTE - Determine risks and... ISO 14001:2015 Specific Discussions 1
B Auditing Senior Management to determine the Effectiveness of Management Processes IATF 16949 - Automotive Quality Systems Standard 6
R What testing would you run to determine if a device is "Clean"? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
Q Tissue Adherence Test to determine how Tissue sticks to Gauze Other US Medical Device Regulations 2
C DOE - How to determine optimal settings and transposing data Statistical Analysis Tools, Techniques and SPC 2
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Buckyb Are KPIs a requirement to determine Process Effectiveness? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
M Is a Real Time Stability Study required to determine Expiration Date? EU Medical Device Regulations 9
K How to determine rated input power for the markings? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I How to determine the thread wire size needed - Buttress Thread Gauge General Measurement Device and Calibration Topics 3
M How to determine Process Capability using Minitab 17 Capability, Accuracy and Stability - Processes, Machines, etc. 6
V How does ASQ determine Exam Cutoff Marks Professional Certifications and Degrees 2
R How to Determine Working Voltage & Tolerance for Isolation Barriers? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
apestate How to determine all regulatory and statutory requirements to be met? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Gage R&R Study (Crossed) - How to determine Process Tolerance Using Minitab Software 4
D How can I determine a process metrics? Manufacturing and Related Processes 1
D Can I use the % Tolerance to determine the actual process tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R How to determine the Thickness tolerance of the Cold Rolled Steel Manufacturing and Related Processes 6
T Technical regulations that determine the acceptable limits of cigarettes General Measurement Device and Calibration Topics 4
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q PPAP - How to determine the "Design Record Change Level" APQP and PPAP 2
K 7.6 c) c) Have Identification in order to determine Calibration Status Calibration Frequency (Interval) 3
S How to determine part that is most difficult to sterilize Other Medical Device Related Standards 10
G How to determine if a Standard is Auditable General Auditing Discussions 15
L Who and when to determine AQL for our product inspection AQL - Acceptable Quality Level 1
R 4 Factors 3 Level DOE to determine which factors are significant Using Minitab Software 2
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S How to determine Preventive Maintenance and Calibration Grace Periods General Measurement Device and Calibration Topics 4
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
C Statistics equation to determine the number of samples in a lot Statistical Analysis Tools, Techniques and SPC 8
S How to determine the Air Clearance for Floated Secondary Circuit IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
somashekar How to Determine the Necessary Employee Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F ISO 22000 Clause 7.4.4 to determine whether a control is a CCP or and OPRP Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Best Minitab Tool to determine a Statistically Significant Trend Using Minitab Software 5
