How to do a profile on a surface with one datum
brossbach
I'm learning somewhat on how to measure a profile of a surface. I need help on how to do this correctly and to do a correct cpk on the profile. Here is example of what I'm dealing with. On the design print I'm dealing with a ignition coil. On this print it calls out for this profile. Here is an example.Profile symbol/2.0/datum A. Sorry it wouldn't paste my picture to show better example. This is really new to me. I doing this on CMM / With a MM3 program. If someone could help step by step I would really appreciate it. Also, if I would a cpk study on this what would be the tolerance zone for this +/-.
Paul F. Jackson
If the measured feature and the datum feature are parallel to one another, then measure the displacement and compare it to the basic. Chart the point to establish process control. When control is established, determine the size of the profile zone required to contain each measured point and compare the mean and associated standard deviation of the resultant zones to specified profile tolerance. Report Cpk from (Cpu or Cpku) in other words compare the encroachment of the distribution on the upper limit and discard the Cpl.
If Datum A is an axis and the measured feature is displaced from it then the measured points can be compared from their basics, charted and controlled, reported according to the size of the zone necessary to contain each one, and predicted for capability. Just like above.
If the measured feature is defined at any other angle than 180 degrees to the datum feature plane or axis then only orientation to A can be determined. For instance a surface or axis can be measured for perpendicularity to a datum surface or axis. Note: The measured feature is free to rotate perpendicular to the datum surface A. Chart the oriented feature form deviation which is the size of the profile zone needed to contain all measured points on the feature. Establish control and then use the same resultant zones to predict capability.
If the datum feature A is a point (center of a sphere) then the displacement can be measured as well but it is probably easier to orient the measured feature and measure the displacement of the datum feature to it.
Good luck, Paul
Proud Liberal
There isn't enough information in your post to help you. If you'd like an opinion, email a section of the blueprint to [email protected] I've taught GD&T classes and have more than 10 years experience running a CMM. Profiles can be tricky. The most common error is to report the maximum deviation from nominal as the profile when in reality it is twice the max deviation. Unless your problem deals with a planar surface parallel to datum -A-, the solution will require some best fit algorythm to be performed on the data.
Coleman Donnelly
I have a similar problem - I have profile of a trim edge back to Datum A|B|C but only Datum A is identified on the print - Datum A consists of two target zones on the same plane. My trim edge would best be described as a plane though not much of one (2mm x 24mm) i could report angularity or perpendicularity to datum A but i want to make sure that this is a legal and technicaly correct way of measuring the part. Would i then report the perpendiculariy value of my trim edge back to Datum A since there is no control fram to define 2 point orientation/rotation or 1 point origin location?
TIA
Stijloor
I have a similar problem - I have profile of a trim edge back to Datum A|B|C but only Datum A is identified on the print - Datum A consists of two target zones on the same plane. My trim edge would best be described as a plane though not much of one (2mm x 24mm) i could report angularity or perpendicularity to datum A but i want to make sure that this is a legal and technicaly correct way of measuring the part. Would i then report the perpendiculariy value of my trim edge back to Datum A since there is no control frame to define 2 point orientation/rotation or 1 point origin location?
TIA
It would help us if you could provide a sketch. Can you attach one?
Stijloor.
Stijloor
My mistake... Drawing does not reference a datum B or C...:eek:
Coleman,
I am still confused....:confused:
The only call out visible on the sketch is the "flatness within 0.5" callout.
It is not clear to me if this applies to the entire top surface or just to the "25 Zones." I can not discern another callout....
Can you further clarify?
Stijloor.
Coleman Donnelly
the call out is spelled out in a general note on a different page of the drawing... It calls out all trim edges to be 1.0 back to datum A. Datum A is the 2 target zones identified on the sketch.
Stijloor
1.0 what to datum A?
The datum targets are incorrectly specified. (Do you have Y14.5 handy?)
They should be drawn in the view where it makes most sense using the correct symbology and basic dimensions.
Don't give up..we're getting there....:agree1:
Stijloor.
C Complex Surface Profile as a datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
C Definition GD&T Clarification - Callout for Profile of a Surface Reference to the Datum Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 34
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Profile of Surface with Basics and Angle Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
K Profile of a Surface Tolerance - Part with a 195 mm radius on it Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Surface Profile Callouts - How the profiles are being dimensioned Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
optomist1 Profile of a Surface - Applying Profile of a Surface Geometric Control Symbols Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
B Measuring the Profile of a Surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
C Reporting Profile of a Surface Results on an Internal Cylindrical Feature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
G How to calculate profile of a surface? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Hole Surface Profile Tolerance Discussion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
B Help with the GD&T - Tolerance for the Profile of the Surface General Measurement Device and Calibration Topics 2
Brizilla User Profile - How do I edit my profile info? Elsmar Xenforo Forum Software Instructions and Help 3
I Lifetime Support Calculation - Thermal Operating Profile Reliability Analysis - Predictions, Testing and Standards 7
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Department Plan for QA and HSE (profile, plans, structure, goals, etc.) Misc. Quality Assurance and Business Systems Related Topics 2
G Gear Profile & Lead Report Manufacturing and Related Processes 1
R Temperature Profile for Transport Simulation (Sterile Eye Drops) Other Medical Device Related Standards 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
Q Form IPC 1720A Assembly Qualification Profile still required? Various Other Specifications, Standards, and related Requirements 1
B Requirement to have Customer Signature Profile on File Document Control Systems, Procedures, Forms and Templates 4
T CMM Inspection of Profile Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
M Measuring a circle's profile Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
D Profile of a Line of a radius of 25mm basic dimension - Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
R Capability for CMM Scanned Profiles on a feature with a Bilateral Profile Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 26
C Inspecting a Profile Tolerance for a Die Cut Gasket Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
AnaMariaVR2 A Profile of the Pharmaceutical Manufacturing Industry: Russia Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
optomist1 Contour vs. Profile - Is there a connection between "Contour" & "Profile"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
optomist1 Composite Profile Tolerancing Clarification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 21
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
A Customer Profiles - Creating a Customer 'Profile' for our Top 10 Customers Document Control Systems, Procedures, Forms and Templates 2
J Reputable Third Party Inspection (Metrology Lab) In USA? Cam Profile Measurement General Measurement Device and Calibration Topics 5
P ISO 20072 Requirements - Example or template of a DFP (device functionality profile) Other Medical Device Related Standards 2
O How to report Profile of a Sphere crossed by a Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 31
A Capability Studies for Profile (GD&T Callout) Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Changing Job Profile - Logistics Engineer to Buyer Career and Occupation Discussions 3
S Benchmarking PVC Profile Extrusion Metrics Benchmarking 2
CycleMike Profile of datum planes - Profile callout back to datum A (itself) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J Angularity or Composite profile - Angularity callout on a recent print Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Oven Qualification - Thermal profile during the OQ of a vacuum oven General Measurement Device and Calibration Topics 6
A Checking Profile Tolerance on CMM's Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B New Print Profile Symbol? Misc. Quality Assurance and Business Systems Related Topics 6
P Design an experiment to optimize the PCB solder reflow profile Design and Development of Products and Processes 4
