How to do a Root Cause Failure Analysis
Moncia
Hi my fellow quality ferries
We just went through an audit and since we had to reschedule, we got different auditor. was not pretty. the guy did not understand the scope of our business.
so anyways, we got 4 minor ones- little babies easy to fix, but having trouble writing a root cause
any one is really good at those in here,
I need a help.
thanks
selena15
Re: Root Cause analysis
Hi monika
how are you doing ?
maybe it may be nice to give more info about your NC, it will be easier to discuss and establish a root cause. will not ?
I need a help.
thanks
If you can share the exact text of the NC statement(s), we can help.
Moncia
off course
I was just asking if anyone knows how to do it
then I would give all the info
should I retype them as they appear on the report???
thanks
GStough
I need a help.
thanks
Hi Moncia,
Our registrar doesn't require root cause analysis for minor nonconformances, only for the major ones. Sometimes, especially when they are easy to fix, a simple correction plan is sufficient, along with follow-up for verification that it was effective.
Hope this helps, and good luck! :bigwave::cool:
Moncia
that's exactly what I have
easy - delete part of a sentence problem
but the guy was major pain in something
and I simply dont know what to write for simple easy to fix problems
ok, let me retype the NCs
off course
thanks
Yes, please--exactly as they appear on the report, including the references to the requirements.
Moncia
then I am gonna just copy and paste his report
I have the electronic copy
Moncia
ok
here is number 1
Standard : ISO 9001-2008 Audit Dates : 25-26 July 2011
ISO Std. Section : 4.2.4 Process : Documents & Records Control
Type of Nonconformity : Major 0 (Special Audit Required)
Major 0
Minor 
Established nonconformity (Requirement, Nonconformity, Evidence):
Requirement: Records to provide evidence of conformity to requirements and of the effective operation of the quality management system shall be controlled. The organization shall establish a documented procedure to define the controls needed for the identification, storage, protection, retrieval, retention time and disposition of records. Records shall remain legible, readily identifiable and retrievable.
Nonconformity: The records control process is not fully effective. The records matrix which is a key tool in controlling records does not contain all the record types in the QMS
Evidence: Records matrix used in the Records Control procedure 4.2.4 Rev 2 dated 7/17/09 does not contain the Purchasing record types.
qusys
off course
thanks
Make copy and paste of the text as is, so that we can read what they reported.
If you want to add some other details too, we can better understand the dynamic of the audit.
Was the audit vs 9001 or other standard? Was it surveillance audit?
What is your business?
See you:bigwave:
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 5
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
R Induction Coil Open Circuit Failure Root Cause Problem Solving, Root Cause Fault and Failure Analysis 15
Marc --> Related Forum - Root Cause and Failure Analysis Nonconformance and Corrective Action 0
Marc --> Related Forum - Root Cause and Failure Analysis Preventive Action and Continuous Improvement 0
K Failure (root cause) codes for service reporting Problem Solving, Root Cause Fault and Failure Analysis 4
U Failure of Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 17
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
S Root Cause Analysis and/or Failure Investigation Training Problem Solving, Root Cause Fault and Failure Analysis 1
E Failure Investigation/Root Cause Procedure Examples Problem Solving, Root Cause Fault and Failure Analysis 6
C Training for RCA - Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 9
C Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 3
A Root Cause Failure Analysis - Educate Me: What Is Root Cause Analysis? Problem Solving, Root Cause Fault and Failure Analysis 10
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
Q Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
S Preparing a Root Cause Report - Possible Root Causes Document Control Systems, Procedures, Forms and Templates 11
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
P Is it a rule to fill in all the 5 why in order to get the actual root cause? Quality Tools, Improvement and Analysis 5
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
H Root Cause Corrective Action Examples Nonconformance and Corrective Action 4
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
R Root Cause for "Simple" External Audit Findings ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
