How to do a Root Cause Failure Analysis
Moncia
#22
I do know what to do to fix the problem
revise the matrix
train people on accessing our onlice ISO system - again
will have proof of their additional training in training form - dated and signed by them
need to either make a new WI for those inspection specifications or just make a huge poster with faulty material pictures- post it all over production
and I have to fix that PA - change the format to CA and re - write it
the problems are root causes
that's where I got stuck
Big Jim
#23
One of the best treatments on how to reply to ncrs is ANAB's "Heads Up" 137. You can find it on ANAB's web site. It is very complete while still being concise. Be aware that it is meant for a different audience, as is is written to aid certification bodies (registrars) respond to ncrs that ANAB writes against the certification bodies. It should be easy to see past that though.
qusys
#24
revise the matrix
The virtuos flow is to identify first the root cause ( the most probable), not backwards from the solutions, otherwise you can wrongly jump to them, but they will not fix the real root cause.
You can use some quality tools such as brainstorming, 5 why's, fishbone diagram, pareto analysis, is/is not method etcc for this purpose:bigwave:
Moncia
#25
got it
thanks
Big Jim
#27
Often, that's the hardest part. Most of the time, the root cause is hidden. It takes some detective work to dig it out.
One of the simplest techniques is 5 why. This originated from an oriental philosopher (who's name I have long forgotten) who basically said if you ask why enough times you can find the cause to any problem. Often, 5 is the magic number, but not always. It could take more or less.
Something to pay attention to, is that you may not be the best person in the organization to solve the problem. The standard alludes to it being the responsibility of the manager over the area where the nonconformance was found. It lease it specifically says so for internal audit nonconformances. If you are the management representative, your role should be to make sure it is responded to, and, if needed, be a coach or cheerleader to aid in getting it done. If that is not how it works in your organization, I suggest you have a talk with top management and try to help them to understand that ISO never intended for all quality matters to be the responsibility of the management representative.
Assuming that you can't shift the responsibility to where it belongs, enlist the help of the appropriate manager to help find the root cause. Sometimes it is also useful to enlist the help of the person working where the nonconformance is found. After all, they are the true expert. A wise mentor of mine once said the expert of any job is the person doing it, and as soon as you move as little as three feet away, you are no longer the expert.
Moncia
#29
I am doing it slowly but surely
going with the 5whys
now as to the reply to the registrar itself
can someone please show me what did they send to registrars as reply with the Corrective actions that were done according to their internal procedure
that's what we / I did
performed corrective action as we do any other corrective actions in here
but now have to send the reply to the registrar
what should be in it????
I have their guidance which is made of off that ANAB's Head up
JaneB
#30
naaa
in our small organization
the whole ISO is on me
Naaaaa, it can't be. Unless you're a one-person busienss? ie, the owner, the MD, the worker, the shipper, the checker and everything else?
In any quality management system, everyone has a part to play. Recall that underlying principle (one of 8 on which the Standard is based) is 'involvement of people at all levels' principle?
OK, perhaps you've got all the responsibility of maintaining/updating documents and doing the paperwork (again, not idea, but still) but the whole system? Nope.
M Test failure Root cause not found Customer Complaints 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
R Induction Coil Open Circuit Failure Root Cause Problem Solving, Root Cause Fault and Failure Analysis 15
Marc --> Related Forum - Root Cause and Failure Analysis Nonconformance and Corrective Action 0
Marc --> Related Forum - Root Cause and Failure Analysis Preventive Action and Continuous Improvement 0
K Failure (root cause) codes for service reporting Problem Solving, Root Cause Fault and Failure Analysis 4
U Failure of Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 17
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
S Root Cause Analysis and/or Failure Investigation Training Problem Solving, Root Cause Fault and Failure Analysis 1
E Failure Investigation/Root Cause Procedure Examples Problem Solving, Root Cause Fault and Failure Analysis 6
C Training for RCA - Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 9
C Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 3
A Root Cause Failure Analysis - Educate Me: What Is Root Cause Analysis? Problem Solving, Root Cause Fault and Failure Analysis 10
qualprod What is exactly the root cause? Nonconformance and Corrective Action 9
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 26
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
