How to do a Root Cause Failure Analysis
Chance
#51
Re: Root Cause analysis
so can I just put "ongoing" into the due date box???
it will be ongoing
Wait for other comments here.
In my case, we put dates of actual training, or target date/plan of training. And we document actual training in our Training Sheet.
Dan Johnson
#52
I coming in late to this discussion, but after 2 years of trying to teach supervisors to do a root-cause analysis, I made up this work sheet that makes them look at human and environmental factors, then perform a basic "5 Why" RCA. It has proven to be a relatively effective tool to date.
Moncia
#53
yes
if that was a case of one time training - we do the same
but we have to have like monthly training in here for people who do not know how to operate computer
that was exactly the NC - they were trained on accessing our system, they were told their ID's, passwords, how to use it
but some of our employees - specially the older ones just dont know how to use computer
so we need to have like constant reminder training type for them to make them comfortable working with computer
so it will be happening every other month until the next audit
they will be trained , re- trained, re-re-trained re-re-re-re-trained .... and so on
until they get it
Moncia
#54
I love it
thank you
Mike S.
Happy to be Alive
#55
Personally, I have found Apollo RCA to be overkill in all but the most complex RCA situations. I have done maybe 4 Apollo RCAs in the last 2-3 years out of probably 100 or more RCAs written. IMO it has a place, but it is not my most frequently used RCA tool.
Mike S.
Happy to be Alive
#56
yes
until they get it
Is the training more and more advanced each time, or are you going over the same subjects over and over again? If the latter, I'd look carefully at the training methods, trainer, etc. and/or the competence of the trainees.
Dan Johnson
#57
I'd just write a work instruction. Detailed instructions on how to comply with a procedure are often put on a WI so the employees have step-by-step instructions handy.
Moncia
#58
but that's exactly it
our work instructions are online
and they dont know how to work on computer
hahahhahah
how will they read it???
we will need "monkey see, monkey do" - sorry, I know it is mean
but that's what will be happening in here
Big Jim
#59
hahahhahah
May I suggest that you have a work instruction on how to access the files in the computer that you keep in hard copy near the computer?
May I also suggest that "ongoing" as in "forever" isn't really a good answer. Perhaps when the training fully implemented and the hard copy work instruction for accessing the rest of the work instructions is in place would work toward having some closure.
Chance
#60
Yes I totally agree, On-going seems to be vague. How would you prove that the on-going action is helping the employees. How do you measure them. I guess having a hardcopy on how to access the computer is the best solution. I guess it would be less than 10 actions anyway..not that difficult to follow.
M Test failure Root cause not found Customer Complaints 10
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Must we identify steps taken to identify the Root Cause of a failure Nonconformance and Corrective Action 15
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
R Induction Coil Open Circuit Failure Root Cause Problem Solving, Root Cause Fault and Failure Analysis 15
Marc --> Related Forum - Root Cause and Failure Analysis Nonconformance and Corrective Action 0
Marc --> Related Forum - Root Cause and Failure Analysis Preventive Action and Continuous Improvement 0
K Failure (root cause) codes for service reporting Problem Solving, Root Cause Fault and Failure Analysis 4
U Failure of Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 17
Q Failure where the Root Cause was the Material Handler Not Following Procedure Problem Solving, Root Cause Fault and Failure Analysis 20
S Root Cause Analysis and/or Failure Investigation Training Problem Solving, Root Cause Fault and Failure Analysis 1
E Failure Investigation/Root Cause Procedure Examples Problem Solving, Root Cause Fault and Failure Analysis 6
C Training for RCA - Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 9
C Root Cause Failure Analysis Problem Solving, Root Cause Fault and Failure Analysis 3
A Root Cause Failure Analysis - Educate Me: What Is Root Cause Analysis? Problem Solving, Root Cause Fault and Failure Analysis 10
qualprod What is exactly the root cause? Nonconformance and Corrective Action 9
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 26
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
Ed Panek Root Cause CAPAs from internal audit ISO 13485:2016 - Medical Device Quality Management Systems 16
A Interesting Discussion Human Factors as Root Cause AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause on Non-Conformity Against Quality Manual Problem Solving, Root Cause Fault and Failure Analysis 9
A CAR from 3rd party AS9100D auditor - Root cause dilemma AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 45
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
T Human Error vs Technique Root Cause (Categories) Human Factors and Ergonomics in Engineering 9
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
N Root Cause Challenge: The guy at the top ... Problem Solving, Root Cause Fault and Failure Analysis 4
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
