How to do Equipment Validation - Establishing our ISO 13485 QMS procedures
Aristo
This is my first post, wish somebody can give me some ideas on this:
we are establishing our 13485 QMS procedures, is it necessary to indicate the validation of equipments(such as injection machine) in the procedure which is suggested by our consultant, but actually we do not and don't know how to do the validation for the equipment.
many thanks
Ajit Basrur
Re: equipment validation
many thanks
Welcome to the Cove.
I suggest that you include a procedure on Equipment Qualification as Level 2 document and could have a template for doing equipment qualification as Level 3.
I recommend to do equipment qualification for all major equipment like injection molding machine, material dryer, robots, mold temp controller etc.
Gert Sorensen
Moderator
we are establishing our 13485 QMS procedures, is it necessary to indicate the validation of equipments(such as injection machine) in the procedure which is suggested by our consultant, but actually we do not and don't know how to do the validation for the equipment.many thanks
A good starting point would be to read (and understand) the FDA guideline on process validation
http: // www .fda.gov/Cder/guidance/pv.htm - DEAD LINK FROM 2007
and also get a good grip of GAMP IV.
Second, you need to qualify personel to perform process validation. This includes management (IMO), otherwise you will never perform a single useful validation.
Third, you need to generate a Master Validation Plan, to prioritize your validation effort. This validation plan should take the guideline on whether or not to validate into consideration. Basically the guideline states that if you can securely verify the result of your process then you do not need to validate, but if you cannot, or have other reasons, e.g. financial, then you should. Since the task of validation is a burdensome one, and the amount of validation that may need to be done if your company is new to the requirements in 13485 is staggering, then I strongly suggest that you consider which of the validations will provide the most value to your company, and which are the easiest ones to perform so you start with some successes.
Alex Kobzar
Registered Visitor
... validation of equipments(such as injection machine) ... we do not and don't know how to do the validation for the equipment.
Process validation is establishing documented evidence which provides a high degree of assurance that a specific process will consistently produce a product meeting its pre-determined specifications and quality characteristics.
Validation is only required where "routine end-product testing" is not sufficient to assure "product quality".
I would strongly recommend to avoid "straight-forward" approach like "here is the mold machine producing MD's; let's go to validate it".
In my experience (with production of rubber catheters) a mold machine shall rarely be a subject of a validation because the features of a molded product may mostly be inspected with an acceptably-high degree of confidence.
Then, for example, if a Product FMEA says that all deviations from the requirements of the "pre-determined specifications and quality characteristics" are having low RPN's (usually due to, e.g. the features being 100% automatically tested; when such testing is likely to be established for critical/safety features of an MD) then the subject of a validation shall be the test equipment and probably not the mold machine.
Gert Sorensen
Moderator
In my experience, in medical devices, the absolute sinner in a company is the plastics department. The components they produce are usually very cheap, and the attitude behind the production reflects the price. Unfortunately the quality that is the result of this attitude is a varying, to put it mildly, resulting in an output that creates trouble for the rest of the company, since these parts is critical for the products and the processes.
If I were to put a financial view on my validation efforts, then I would always prioritize validation of plastics before any thing else (excluding sterilization of course :) )
maxwell
Aristo
Attached you will find a IQ/OQ (Installation Qualification/Operational Qualification) validation protocal. This plan is based on plastic injection molding machines, You will need to tweak for use on your machines. Use the operations manual received with your machine to tweak validation procedure. As previously stated as long as you can measure the results of the device manufactured you will not have to do process qualification.
Gert Sorensen
Moderator
Aristo
Seems like a good starting point, but I fail to see things like qualification of materials, qualification of surroundings, air, humidity, training of personell, cooling water, worst case scenario and establishing of process control... :2cents:
I strongly oppose to not performing PQ on an injection moulding machine, just as I strongly oppose to not defining the worst case scenario or identifying the properties of the material needed for the process. It will greatly diminish the effect of the validation to the point of rendering it useless. :(
RCW
My questions/confusions start off similar to Aristo's but veer off in another direction. I am updating from ISO9001:2000 to ISO 13485. As long as my company has held an ISO9001 cert, we have always claimed an exemption to 7.5.2 Validation. The reason behind the exemption is that we feel we can verify our product through inspection and test.
A few years ago, one of our customers was in here performing an audit for production of medical devices. They jumped all over me for not having installation qualifications in place for our surface mount line which includes a solder paste stencil machine, pick&place machine, and solder oven. I told them we verified product through inspection and test but they would have nothing of it. I asked several times to show me their requirement but they could produce nothing. Management wanted to pacify the customer so installation validations were done along with validation of software. (The software validated was written internally to control purchasing parts and inventory control. IMHO this didn't need to be done either.)
We recently bought replacement surface mount equipment and validations were performed again. I asked the operator why he was performing the validation. He said he didn't know why. Only that it was done before.
Continuing on...
ISO 13485 calls out for the validation of computer software used for the production/service process. We use software with a continuity test box (used to check wiring on medical devices) so I am assuming that requires validation. From my previous example, I am assuming an inventory control program does not require validation.
So where am I going with this?
1) If I can truly verify product through inspection and test, do I need to perform installation qualification / validation?
2) I can no longer claim exemption to 7.5.2 under ISO 13485 because I have to validate the test box software?
3) Were the requirements placed upon my company by the customer right or wrong?
As I am suppose to be the expert on all this quality stuff, talking to others here has led me to even greater confusion. (One person told me, you're the expert, go look in the mirror and ask the question.)
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Software validation in Medical Equipment Other Medical Device and Orthopedic Related Topics 20
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
R Which pieces of equipment require equipment validation? ISO 13485:2016 - Medical Device Quality Management Systems 1
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
D Validation of existing equipment - I have been asked to write a quality assessment for equipment ISO 13485:2016 - Medical Device Quality Management Systems 13
D ISO 13485 - Equipment validation , qualification Qualification and Validation (including 21 CFR Part 11) 6
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
S Validation of COTS Equipment plus Software Qualification and Validation (including 21 CFR Part 11) 12
R FDA Requirements - Printing Equipment Software Validation Qualification and Validation (including 21 CFR Part 11) 1
G How many samples you require to test during PQ for validation of a equipment? ISO 13485:2016 - Medical Device Quality Management Systems 1
D ISO 9001:2015 8.3.4 & validation of new equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
P Software Validation for Equipment - Question ISO 13485:2016 - Medical Device Quality Management Systems 5
A Question about what FDA looks for in equipment validation US Food and Drug Administration (FDA) 3
P CMM Equipment Validation and Qualification Approach ISO 13485:2016 - Medical Device Quality Management Systems 11
M Chosing a procedure title - "Validation of equipment" or "Qualification of equipment" Document Control Systems, Procedures, Forms and Templates 8
D Relocation of Equipment - Equipment Validation template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Mohammed Gouda What is the maximum permissible period of delaying the validation of equipment? Other Medical Device Regulations World-Wide 4
D Validation of Computer and Network Equipment Test System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
F Determining activities required for Validation of Manual Equipment Qualification and Validation (including 21 CFR Part 11) 4
T Is Testing Equipment Re-Validation required if the Test Equipment is Relocated? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Computer Simulation Validation Tests for Underwater Equipment AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
V Implementation of Traceability Matrix in Validation Life Cycle of Equipment Qualification and Validation (including 21 CFR Part 11) 2
V Equipment/Machinery Validation in ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 3
R CLIA Equipment or Software Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
C Equivalence Studies - Validation Activities for several Identical Pieces of Equipment Manufacturing and Related Processes 1
C Equivalence Studies - Validation Activities for several Identical Pieces of Equipment Qualification and Validation (including 21 CFR Part 11) 2
E How to write a Validation Risk Management Plan for Equipment ISO 14971 - Medical Device Risk Management 5
F Aged Inspection Equipment Software has no Audit Trail - Validation of Software Qualification and Validation (including 21 CFR Part 11) 5
R Equipment Cleaning Validation Requirements - Medical Device Class II or Class III Other Medical Device and Orthopedic Related Topics 5
M Process Validation and Qualification of Legacy Equipment ISO 13485:2016 - Medical Device Quality Management Systems 10
M Process Validation/Equipment Qualification - Class 1A (Sterile) Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 12
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
A Re-Validation criteria and Requirements for Manufacturing equipment on site ISO 13485:2016 - Medical Device Quality Management Systems 8
R Equipment Change or Process Change? Validation protocol for a planar freezer Misc. Quality Assurance and Business Systems Related Topics 3
I Periodic Review of Process and Equipment Validation Qualification and Validation (including 21 CFR Part 11) 4
C Equipment, Software and Processes Validation for Medical Devices - 21CFR 820.75 (a) ISO 13485:2016 - Medical Device Quality Management Systems 35
H Does Welding of the Metal Housings for Audio Equipment Need Validation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Seeking guidance documents for Non FDA Regulated Process Validation - New Equipment Statistical Analysis Tools, Techniques and SPC 3
Q Validation of New Process Equipment - What are the ISO 9001 requirements? Misc. Quality Assurance and Business Systems Related Topics 6
W Protective earth for Class I ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T AMS2570E certification equipment questions AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
J Class Fixed ME Equipment (US Deviation) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Infrastructure: Equipment, Work Environment and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 4
