How to do Multiple Regression Analysis in Minitab 16
P
Priss80
I am using Minitab 16, i can't find the multiple regression tab althought I click into "assistant"/ "Regresion". Anyone know and help.
You can perform multiple regression in Minitab 16 using either Stat > Regression > Regression or Stat > Regression > General Regression.
I recommend using General Regression as it is easier to specify your model.
reynald
Happy New Year!
Minitab shares the command with simple regression and multiple regression.
As Miner said go to Stat > Regression > Regression. Then input as many predictors as you need. If you want interactions between 2 numerical columns create a third column containing the product of those two columns and add that as a predictor.
Regards,
Reynald
P
Priss80
What is the different between Regression>Regression and Regression>Regression General in Minitab?
sajid7
Re: AS91X0 Third Party Auditor Cycling and Changing Auditors
Thus far everything is going as planned, and i'm almost there. But i'm stuck on the Regression analysis. The standard error of estimates to be precise.
You will obtain the same results from each. Regression is an older version that retains a lot of manual control for those that are very adept at regression analysis. However, as reynald indicated, to include interactions (and quadratics) you must manually create these factors in their own columns.
General Regression is a recent addition that is more user-friendly. To create an interaction, you simply add A*B to the model with no need to create the factor in a column.
In Minitab 17, both were consolidated into a single option.
P
Priss80
What is the purpose of categorical predictors (optional) in general regression? What to select fill in this area? Is it related to the type of coding? In the worksheet, what variable to be fill in for the category predictor, example speed high, low or 1, 0
reynald
Since this is general regression, predictors can either be continuous (i.e. simple linear regression) or ordinal/nominal variables (logistic regression) or both (general linear regression).
On that slot you put in the categorical predictors. Otherwise it will be read as a continuous variable and can lead to error.
The effect of using a categorical predictor is the you get a separate regression equation for each level of the categorical predictor.
For example: You want to perform a regression using weight as the Dependent Variable (DV) using height and gender as the Independent Variables (IV). Gender is categorical (M/F) and height is continuous. You will get two regression equations (e.g., weight F = B0 + B1*height F and weight M = B2 + B3*height M ).
D Multiple regression with student t distribution Using Minitab Software 1
C How to calculate coefficeints of X's in multiple variable regression equation Statistical Analysis Tools, Techniques and SPC 2
C Multiple regression questions Statistical Analysis Tools, Techniques and SPC 2
E Performing a GRR when you get multiple readings over time per part. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Control plan - Multiple batches Manufacturing and Related Processes 2
S Setting AQL Levels with Multiple Suppliers Supplier Quality Assurance and other Supplier Issues 3
I Distinguishing multiple importers with symbols EU Medical Device Regulations 0
D Multiple amendments at same license Canada Medical Device Regulations 1
F Multiple Intended Use Statements US Food and Drug Administration (FDA) 1
P IMDS Multiple parts RoHS, REACH, ELV, IMDS and Restricted Substances 1
E How to isolate multiple APPLIED PARTS IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Can you have one Core Process (PEAR) with multiple plants? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M Multiple time zones in the Audit Trail Qualification and Validation (including 21 CFR Part 11) 7
C Multiple Part Numbers, IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 2
D Control chart selection of multiple batches review Statistical Analysis Tools, Techniques and SPC 6
M Reference to an archived template in multiple SOPs ISO 13485:2016 - Medical Device Quality Management Systems 2
Z GRR for multiple automated metrology tools Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
L 1 product multiple factories EU Medical Device Regulations 0
C Custom Injection Molding - Multiple Cavities and Subgrouping Capability, Accuracy and Stability - Processes, Machines, etc. 4
A One-factor and multiple-response Minitab optimization Using Minitab Software 2
I Multiple Indications in SaMD Other US Medical Device Regulations 8
K Multiple importers EU Medical Device Regulations 2
S Instructions for use multiple manufacturing locations ISO 13485:2016 - Medical Device Quality Management Systems 0
S Defibrillator Protection applicability When using Multiple applied parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
C Multiple owners for one listed device Medical Device and FDA Regulations and Standards News 1
A CE-IVD Technical File with Multiple IFUs EU Medical Device Regulations 5
K One CE Mark holder - multiple manufacturing sites EU Medical Device Regulations 3
K Multiple function device products EU Medical Device Regulations 0
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
shimonv FDA News FDA guidance on Multiple Function Device Products (8/2020) Other US Medical Device Regulations 1
C Contract Review with Multiple Line items ISO 13485:2016 - Medical Device Quality Management Systems 7
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
B QMS question in regards to multiple medical devices/products and N/A activities Other Medical Device Related Standards 12
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
D Reduction of software class based on multiple external risk controls IEC 62304 - Medical Device Software Life Cycle Processes 5
S Samples for GR&R - Can we get the 10 samples from multiple models Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
C FDA Registration Requirements for Multiple Sites 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C Can a manufacturer (in South of Korea) have multiple Brazil Registration Holder (BRH) for same brend name? Other Medical Device Regulations World-Wide 1
S Multiple Authorized Reps in the EU for the same device? EU Medical Device Regulations 6
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
C FMEA - Multiple function failures considerations FMEA and Control Plans 3
B AS9100 Multiple Distributor warehousing locations under same Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
W SOP for Vigilance reporting covering multiple requirements Document Control Systems, Procedures, Forms and Templates 7
