How to Do Ppk on Non-Normal Data
bobdoering
Stop X-bar/R Madness!!
#11
The software says the best distribution to analyze my set of data is Johnson family distribution.
One thing I found in both Johnson family analysis (one with no LSL & the other with zero as LSL) is the P value remains same.
Yes, this is true because the p-value is not related to the spec limits - only the curve.
Assuming the limiting factor for P value is 0.05 my process is well with in normal distribution in both the cases. So can I say my process is normal?
I do not look for a "limiting factor", I look for the highest p value. You can use the [Select Distribution] button in the software to force the software to calculate the statistics for any of the distributions in its list. Force it to calculate the normal distribution, and compare it to the best fit distribution. In order to accept that the normal distribution is "close enough" of an estimation of the data, either it should be the best fit (it is not, the Johnson Family is) or the p-values should be relatively close (for example, if the best fit p value was .50 and the normal distribution fit was .45, I would call it "close enough" to normal as a fit) You might say that if the best fit is less than .05, then I would not trust that any of the curves is a good fit.
Also I see there is no Pp value indicated if we do not specify LSL (in this case the Ppk is good), can you explain me why it happens?
The capability is only being evaluated by its distance from the USL. The distance from 0 is not relevant.
The Ppk value becomes worse if we specify zero as LSL, so you have suggested not to go by this method, Pls explain me how you arrived at this conclusion.
Because, by specifying 0 as a LCL, the calculations assume you are trying to center the process in the middle of LCL and UCL. It cuts everything in half. But the target is not the "middle", it is 0! That is why it does not make sense to use 0 as an LCL.
Hope this helps!! By the way, you will love this software! A lot easier to use than Mintab, etc.! I use it all of the time.
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
D Ppk of non-normal bounded proccess, one sided specification Capability, Accuracy and Stability - Processes, Machines, etc. 3
N Analysis of non-normal stratified data for cpk/ppk? Rupture test Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Johnson's Transformation - Minitab 14 - How can I find out Ppk - Non-normal Distribu? Using Minitab Software 9
V MINITAB and non-normal unilateral tolerance data - Cannot confirm Ppk values Using Minitab Software 15
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
D Signal Detection-If Ppk>1, compare measurement system to process. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
S Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
B Cpk vs Ppk to look at the Capability by Fixture Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Customer requires CpK 2 and PpK 1.5 Capability, Accuracy and Stability - Processes, Machines, etc. 2
R Which of the following indicators is important for Operations - Ppk, Cpk, or Cpm? Statistical Analysis Tools, Techniques and SPC 15
R When Pp>2, and Ppk<1.33, can we approve a new process? IATF 16949 - Automotive Quality Systems Standard 3
U Cpk and Ppk for different Countries/Standards Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Advise on R Chart with Ppk of 17.85 for Ford Capability, Accuracy and Stability - Processes, Machines, etc. 37
B Understanding why my CpK and PpK are low, and LCL Statistical Analysis Tools, Techniques and SPC 20
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Which one is better to calculate, Cpk or Ppk? Statistical Analysis Tools, Techniques and SPC 11
N How to make a MSA for an Attribute Gauge if the Pp=Ppk=1.33 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
A How to calculate Cpk & Ppk if the tolerance changes during the period? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Is a Stable Process (within Control Limits) required for Calculating Pp, Ppk? Capability, Accuracy and Stability - Processes, Machines, etc. 6
A Ppk Issue - Some Products have Unilateral Tolerances Capability, Accuracy and Stability - Processes, Machines, etc. 24
F Please share an MS Excel sheet to calculate Cpk and Ppk Statistical Analysis Tools, Techniques and SPC 1
B Sample Size based on Process Capability Indices (Pp/Ppk)? Capability, Accuracy and Stability - Processes, Machines, etc. 20
R Ppk vs Cpk: Big Differences - What conclusion can I reach about my process? Six Sigma 3
A How to interpret Minitab Results? What is difference in Cpk and Ppk values? Using Minitab Software 2
J Cpk & Ppk - Reviewing a PPAP Package - Some questions Statistical Analysis Tools, Techniques and SPC 8
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
M When a moving range is 0, is it acceptable to have a PP/PPK of 0 also? Statistical Analysis Tools, Techniques and SPC 8
S Ppk & Cpk - Within Subgroup Variation is always smaller than Total Variation Capability, Accuracy and Stability - Processes, Machines, etc. 18
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
R Cpk & Ppk and Differences between Minitab and an Excel Spreadsheet Results Statistical Analysis Tools, Techniques and SPC 4
S How is Cpk /Ppk value calculated in Minitab since I have subgroup size of 1 Capability, Accuracy and Stability - Processes, Machines, etc. 1
R Customer Rquest for Real Ppk? Get Real... APQP and PPAP 2
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
A Deciding on when to go for Cp & Cpk or Pp & Ppk Study? Statistical Analysis Tools, Techniques and SPC 3
M Minimum number of samples to inspected for Pp & Ppk study ? Any statistical proof?? Capability, Accuracy and Stability - Processes, Machines, etc. 4
C Understanding the relationship of Pp, Ppk, Cp, Cpk Six Sigma 4
A Ppk Reporting - Ideas to make it more meaningful for Management Statistical Analysis Tools, Techniques and SPC 3
S Cpk and Ppk Differences and Questions Capability, Accuracy and Stability - Processes, Machines, etc. 5
E Cpk and Ppk template wanted Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q ASQ CSSBB Question on Cpk and PPk , can you solve it ? Capability, Accuracy and Stability - Processes, Machines, etc. 15
J Using Ppk to set up Control Plans - Injection molding Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Calculation of Cpk and Ppk for an unstable process Statistical Analysis Tools, Techniques and SPC 7
Q PPK, CPK of >= 1.67 Automotive Requirement and Auditing IATF 16949 - Automotive Quality Systems Standard 1
