How to document discontinuation or end of life for a software version ?
jradford
I do not see anything in the 62304 standard about discontinuing or end of life a software version?? Is there a guidance out there to help with this?
So, we manufacture medical devices. They are operated through software we design and code. This same version of software runs our whole family of medical devices. When we made a change to one of the devices, so we had to make changes to the software. It was determined to increase the version level of the software from version 7 to version 8. So basically version 7 is obsolete and no further upgrades would be made to it. There was not an end of life for the medical device product.
So I would believe there needs to be some report about ending maintenance on version 7 software. Anyone else run into this?
c.mitch
There is no formal requirement in IEC 62304 about that. You may rely on problem resolution procress, which tells you to inform parties about problems.
However, this is more at the ISO 13485 level, or US QSR level, that obsolescence should be treated, by informing users of the SW obsolescence and the need to upgrade it.
Depending on how you manage the traceability of sold products, this could be very easy, or a nightmare!
This is very astonishing. Most of regulations require to define a device shelf life (even for standalone software, but this is another subject). If there is a shelf life, then all products older that their self life shouldn't be upgraded. Unless you upgrade them as a goodwill gesture.
Spazz
While I'm not an IEC 62304 expert, this sounds like a revision of existing software and not an end-of-life. It could be handled through your change control procedure and software maintenance plan.
Mga_MD
do IEC 62304 and IEC 82304 have any requirement that states which activities should be performed when a Software is discontinued?
many thanks!
Tidge
The only direct requirement I am aware of per 62304 is that as part of the Software Maintenance Plan it is necessary to consider obsolesence.
Indirectly, I think a case can be made that the Configuration Management Plan ought to include specific mechanisms for control of obsolete software.
Mga_MD
hi tridge, thanks a lot!
may I take advantage to also ask the following:
- if the Software (SW) is discontinued and we have evidence that users are no longer able to access the SW, it is necessary to keep doingPost Market (PMS) activities?
-do we have to inform the NB about the MDSW discontinuation?
-do we have to keep the QMS, Technical Documentation stored for five years as per MDD administrative provisions (our SW is currently under MDD certificate)
thanks!
Tidge
I saw your question in another (revived) thread. This is a regulatory question, and the answer depends on which regulations you intend to comply with. Software (SaMD or as a component in a Medical Device) ought to be treated like other medical devices. In the case of the USA, I would be conservative and leverage 21 CFR 820.180(b):
Record retention period. All records required by this part shall be retained for a period of time equivalent to the design and expected life of the device, but in no case less than 2 years from the date of release for commercial distribution by the manufacturer.​
If it is SaMD, you should be keeping all records for at least 2 years after you formally obsolete all versions of the SaMD. I would also recommend that you still allow for the normal life-cycle activities like complaint intake during this period as well. My recommendation is that you leverage the existing Risk Management Plan and its regularly scheduled Periodic Risk Reviews to guide you in the End-of-Life phase.
I suppose it is possible that you may precisely know where all instances of the software is, and could have objective evidence that its use has been everywhere discontinued (akin to a recall)... and that you may be tempted to argue that the "clock started" sometime in the past. Even if you believe a case can be made that "everyone stopped using our software five years ago", and even if you think you have airtight evidence of this, I would still recommend that you formally implement and EoL plan consistent with previously existing RM plans. If you've never done a periodic risk review for it before, I would say that you ought to plan on adhering to the full length required by regulations.
Other regulatory authorities may have different periods of time, depending on the nature of the device. DHF/DMR records for SaMD should be pretty inexpensive to keep around. Sales/service/ERP/complaint records may be a different matter. I would consult with your regulatory affairs officer/NB representative.
Mga_MD
thank you so much for the clarifications.
I add more context related with the situation below:
-we don't want to sell anymore a SaMD that it is not yet on its EoL, but we only want to do that discontinuation in one country
Do you think your previous answer would change based on these? do you forsee any difference on the answer you provided before?
thanks a lot in advance!
John C. Abnet IATF rules 6th edition - Looking to access the Draft document IATF 16949 - Automotive Quality Systems Standard 8
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
A Can a Form Template be altered in a 13485 document control system? ISO 13485:2016 - Medical Device Quality Management Systems 4
Sidney Vianna Informational ISO/TC 176/ TG4 Updated summary of emerging themes document ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G 8D on Audit Non Conformance -- Incomplete Document Nonconformance and Corrective Action 23
A How to structure a controlled document template Document Control Systems, Procedures, Forms and Templates 7
J Document hierarchy for Process mapping for ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
J Document Control Requirements within Oracle System Document Control Systems, Procedures, Forms and Templates 1
Q Procedure document review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Design and Development document ISO 13485:2016 - Medical Device Quality Management Systems 2
T Quality Document Definition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Sidney Vianna Interesting Discussion IAF Mandatory Document for the Harmonization of Sanctions and Dealing with Fraudulent Behaviour ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
Sidney Vianna Interesting Discussion IAF issues "INFORMATIVE DOCUMENT" on Management of Fraudulent Conduct ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 0
Ron Rompen Document archiving software & hardware Document Control Systems, Procedures, Forms and Templates 0
T Terms & Conditions Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
T Document Review Process Map AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Introducing a document control system benefits Document Control Systems, Procedures, Forms and Templates 13
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Record test data into Word document Document Control Systems, Procedures, Forms and Templates 3
A Digital Document Control - Revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Ensuring Document Review AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T TipQA Document Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
A Document control system for QMS in Google Drive? Document Control Systems, Procedures, Forms and Templates 6
M On-demand EU MDR Compliance toolkit with online training courses, templates & document management system Training - Internal, External, Online and Distance Learning 0
C Document Record/Template Minimum Requirements ISO 13485:2016 - Medical Device Quality Management Systems 3
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
Q Document representation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Document control Document Control Systems, Procedures, Forms and Templates 10
D Increasing efficiency - Capt. Proj. Document Review Matrix Document Control Systems, Procedures, Forms and Templates 4
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Document Changes that don't have to be approved Document Control Systems, Procedures, Forms and Templates 11
D Electronic Document Management System ISO 13485:2016 - Medical Device Quality Management Systems 16
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 7
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
D Document Change Approval ISO 13485:2016 - Medical Device Quality Management Systems 6
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 5
C Document Identification Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Document retention Policy for Japan's PMDA Japan Medical Device Regulations 1
B Document Retention Policy for NMPA China Medical Device Regulations 1
B Document Retention period for MHRA submission UK Medical Device Regulations 0
A If document coding is change will there be a revision Document Control Systems, Procedures, Forms and Templates 1
S Document numbering question? ISO 13485:2016 - Medical Device Quality Management Systems 7
R Quality policy review document IATF 16949 - Automotive Quality Systems Standard 3
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Software design document NMPA guidance and consultant China Medical Device Regulations 4
qualprod Is it worth to document all the processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
