How to document Internal Audits done via the "Process Audit" methodology
Casana
Blueberry Nut
I'm struggling with how to document internal audits done via the "Process Audit" methodology, how do others handle this?
We have available a Lotus Notes based system called "QSI" for documenting audits, but for some :mad: reason its setup to record by element. So even though I could do a process audit, the audit report can ONLY be documented on an element basis.
The owners of this system (not me) have just accepted this quirk but I'm starting a new Quality System with another group and would rather NOT document on an element by element basis. QSI does allow one to create customized checklists. The way I see it I have these choices:
1- use current system as is (i.e. document audits by element instead of process)
2- create my own checklists for each process then document these in the system
3-use some other system for recording audit results (other than QSI). (please feel free to recommend, preferably a CHEAP system).
Anyone have advise?? TIA!
-Ana
Q
Qwatcher2
Re: DOCUMENTING Internal audits
One way to handle this and still work within your recording system is to do a process matrix to the ISO requirements. Using an excel spreadsheet, put the elements across the top as column headers and then list the processes down the left side column. Then 'x' the elements that each process touches on. This is used by one of the registrars I audit for and I also use it in my company. It allows me to do process audits and yet still evidence that I have audited all elements of the standard. Some organizations list only high level processes while others list all processes.
Hope this helps.
Casana
Blueberry Nut
Thanks for the reply, Qwatcher2.
My question actually follows from your suggestion - yes, I plan to have a matrix of process vs. element. But if I have several auditors auditing several processes, how to document their results?
For example, auditor 1 looks at Doc control for process 1. Auditor 2 looks at doc control for process 2.
Do I have each auditor open the checklist for element 4.2.3 and add in their findings (good or bad), or do I create two checklists one for each process? :confused:
Coury Ferguson
Moderator here to help
Some type of report. Something to reflect which processes were looked at. Doesn't have to be special. A simple memo in Lotus notes should do in my opinion. Don't make this hard. Keep it simple.
With respect - the greatest kind - internal audits are not supposed to be done to any third party reporting model - the idea of covering all the elements etc is a 'legend in it's own lunch time". It's not a requirement of a good system - only something dreamed up or made a contractual requirement of a CB auditor!
There is little substitute for effective planning for each audit. Simply put, you have to sit down and, armed with a scope and some criteria for the audit, it shouldn't be too difficult to come up with what has to be audited. It occurs to me that we have very few questions here about helping to define audit 'scope' and 'criteria' - it's always 'a process', 'procedure' department' or something simple, and the scope if always ISO or a procedure! Doesn't have to be that way!
So, that's why I created the football metaphor for helping auditors to plan their way through the 'sequence and interaction' of the processes of the QMS so they could address which apsects have to be audited.
For myself the best documentation of an audit, is the 'working documents' like a checklist etc which has the auditors scribbles, dirty thumbprints and "dogearedness" that kind of shows someone did an audit.
Your comments about the QSI software validate my comments to ISOClaire (in another thread) about why such tools don't work!!
Casana
Blueberry Nut
Andy, I agree on creating a checklist before the audit (prefer to actually). My confusion was, now that I have an open field, how best to use it ;)
I prefer to document our results online, so its available to all. But I think you answered my question in a roundabout way - checklist per process is probably the way to go. Preferably created from scratch prior to the actual audit (after doing the paper audit, etc.)
Thanks!
Helmut Jilling
Auditor / Consultant
-Ana
yes, the age old question...
My best suggestion is to get some good training in ISO process-based auditing. I have put together a tool my classes use and the feedback is often, "Gosh, I wish we had this before, it would have made it so much easier to audit..." There are some good trainings available, and that is my best suggestion.
Beyond that, here are some additional thoughts:
Follow Andy's suggestions regarding planning. It's a bit of a fetish for him,but the old boy is right.
Divide the list of processes into logical groups - ie: doc and record control goes well together, audit it at the same time.... Manufaturing and Maintenance... process measuring, data analysis, management processes... and so on. have each audit team tackle a cluster.
After planning, each process audit should address three stages:
* the inputs and outputs to the interacting processes, metrics for each process,
* the sequence and steps of the process itself, as shown in the procedures, flowcharts and work instructions,
* The effectiveness of the interactions to the supporting processes.
Every audit should address these three stages.
To your specific question about auditing the document process, one of the teams would be assigned the actual audit of the document process, and all the other audit teams would only address and examine some sample links. That way, the process gets audited, and the links get checked whenever appropriate.
Hope this helps, but give serious thought to getting some good training on how to do this. It will pay for itself in spades.
Helmut - thanks for the compliment - I take 'old' to mean 'sage', 'experienced', 'wise', 'worldly'......etc!! Especially since we're about the same age.......;)
Caster
An Early Cover
The much discussed and often hated turtle approach offers a way to document a process audit.
Take a look here for two files that describe the concept very well.
http://www.terrapeneintl.com/support/documents.html
I'm not sure how well the software works, or even its cost, but the files are well worth a read!
I made up a simple Excel file with a tab for each part of the turtle. Observations are recorded on the spreadsheet, and evidence is either pasted right in or hyperlinked.
The last tab is a closing meeting and link to agreed actions. Free is good.
xfngrs Measureables for Document Control and Internal Audits Document Control Systems, Procedures, Forms and Templates 112
J AS9100D - Good ways to document an internal audit plan / schedule Internal Auditing 25
Q Internal Audit of a Plan or other document - Closure Plan Internal Auditing 1
M How to Document Internal & External Communications - Suggestions/examples pls IATF 16949 - Automotive Quality Systems Standard 3
Z Internal Memo used to document work instruction Document Control Systems, Procedures, Forms and Templates 2
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
E Could a BBS (internal forum like phpBB) be used as a Document Control System? Document Control Systems, Procedures, Forms and Templates 3
P Company Conducted Internal Audit Offsite using a Document Review Process Internal Auditing 65
P How to document an Internal Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Must I document qualification(s) or qualification process for Internal Auditors? IATF 16949 - Automotive Quality Systems Standard 10
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
K How does an Internal Auditor document non-ethical or illegal practices Internal Auditing 10
GStough Internal Audit Checklist as a Controlled Document - Pros and Cons Internal Auditing 19
C Document Control for External and Internal Projects (overseas projects) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Document Control - Internal Departmental battles for control of template Document Control Systems, Procedures, Forms and Templates 17
S Document Control of Internal Auditing Documention Document Control Systems, Procedures, Forms and Templates 7
Crusader ISO 9001:2000 Internal Auditor Training document Training - Internal, External, Online and Distance Learning 2
P Seeking Training Document - Good Characteristics of an Internal Auditor Training - Internal, External, Online and Distance Learning 8
M Internal Document Request Process - Please Critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Internal Document Numbering System - Please review and advise Document Control Systems, Procedures, Forms and Templates 7
F Seeking: Examples/Samples - How to document internal auditor qualifications Internal Auditing 9
J Process Audit Checklist to document Internal Process Audit results Process Audits and Layered Process Audits 19
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
