How to draft a good First Article Inspection Procedure (when AS9100 is overkill)
Rob Holt
How to draft a good FAI (First Article Inspection Procedure)...when AS9100 is overkill for our litte communication device? I have a two decade heritage in HW regulatory Compliance...and have been recently asked to help the QA dept. develop a FAI for our unique system....thanks - Rob
ssz102
i think this procedure should be including some points as below:
the opportunity of FAI
what aspects need to consider during first article inspection
related standard documents and parameter
test and inspection method
the test and inspection records is maintain or not
the report format including cover sheet
other things hope anyone to more explain
Mikishots
You're referring to AS9102, I suspect?
First thing we'd need to know is if there is any standard that your company's QMS is registered to. I have some ideas, but I don't know what your basic requirements need to be.
Any other info you can offer?
Rob Holt
Wiliam
Our company, making enterprise communications device, has not completed (or even started) a QMS yet. The AS9200 is overkill, and I posted this thread on best practices for coming up with a custom FAI from scratch.
Rob
Big Jim
AS9100 likely is not overkill. It is pretty basic and would provide a good basis to start. AS9100 is the aerospace quality management system standard, and the portion that speaks to first article is clause 7.5.1.1
"The organization shall use a representative item from the first production run of a new part or assembly to verify that the production processes and tooling are capable of producing parts and assemblies that meet requirements. This process shall be repeated when changes occur that invalidate the original results (e.g., engineering changes, manufacturing process changes, tooling changes)."
If you are not being driven to perform first article by a customer, and are not bound by AS9100, you get to determine how to apply the concept. For example, you might only do it when the customer requires, not on every project. You might do a variation of it know as "first piece" where you check the first piece after set-up to confirm the equipment is accomplishing what it should.
AS9102 is a short but specific standard on first article that is much more detailed and even includes the forms to use and provides more specifics. It would not hurt to obtain a copy and see if there is any guidance within it that may be helpful in setting up your own program.
T Draft of New UK Regulations? UK Medical Device Regulations 2
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Breast Implants – Certain Labeling Recommendations to Improve Patient Communication Medical Device and FDA Regulations and Standards News 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Clinical Decision Support Software Medical Device and FDA Regulations and Standards News 0
M Informational From Medtech Insight – QSR/ISO 13485 Harmonization Update: FDA Enforcement Discretion Likely When New Rule Stands Up; Draft Reg Coming By Year’s End; Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
M Informational US FDA Draft Guidance – Patient Engagement in Design and Conduct of Medical Device Clinical Investigations Medical Device and FDA Regulations and Standards News 0
M Informational Several US FDA draft guidances, including some specific device guidances for the Safety and Performance Based Pathway Medical Device and FDA Regulations and Standards News 0
M Informational FDA draft guidance – Safer Technologies Program for Medical Devices Medical Device and FDA Regulations and Standards News 0
M Informational IMDRF draft document – Requirements for Regulatory Authority Recognition of Conformity Assessment Bodies Conducting Medical Device Regulatory Reviews Medical Device and FDA Regulations and Standards News 0
M Informational US FDA draft guidance – Testing and Labeling Medical Devices for Safety in the Magnetic Resonance (MR) Environment Medical Device and FDA Regulations and Standards News 0
M Informational EU draft act – Single-use medical devices – safety and performance requirements for reprocessing Medical Device and FDA Regulations and Standards News 0
M Informational Draft ANSM’S GUIDELINE Cybersecurity of medical devices integrating software during their life cycle Medical Device and FDA Regulations and Standards News 0
M Informational Draft standardisation request as regards medical devices in support of Regulation (EU) 2017/745 and in vitro diagnostic medical devices in support of Medical Device and FDA Regulations and Standards News 2
M Informational US FDA draft guidance. – Clinical Investigations for Prostate Tissue Ablation Devices Medical Device and FDA Regulations and Standards News 2
M Informational US FDA draft guidance – Mouse Embryo Assay for Assisted Reproduction Technology Devices Medical Device and FDA Regulations and Standards News 0
L Getting Notice of Revision and Accessing Public Draft Copies of ISO Standards Service Industry Specific Topics 2
M Informational EMA – Consultation on draft guideline on quality requirements for medical devices in combination products Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – Technical Performance Assessment of Quantitative Imaging in Device Premarket Submissions Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – Technical Considerations for Non- Clinical Assessment of Medical Devices containing Nitinol Medical Device and FDA Regulations and Standards News 0
M Informational USFDA Draft Guidance – Review and Update of Device Establishment Inspection Processes and Standards Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – A Risk-Based Approach to Monitoring of Clinical Investigations Questions and Answers Guidance for Industry Medical Device and FDA Regulations and Standards News 0
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
M Informational Publication of Draft Health Canada Implementation Guidance for the International Medical Device Regulators Forum Table of Contents Format Medical Device and FDA Regulations and Standards News 0
Y My mission is to draft a procedure related to ISO 14155 - Good Clinical Investigation Practices Other Medical Device Related Standards 1
M Informational USFDA Draft Guidance – Implanted Brain-Computer Interface (BCI) Devices for Patients with Paralysis or Amputation – Non-clinical Testing and Clinical Medical Device and FDA Regulations and Standards News 0
M Informational USFDA draft guidance – Nonbinding Feedback After Certain FDA Inspections of Device Establishments Medical Device and FDA Regulations and Standards News 0
M FDA News USFDA draft guidance – Principles of Premarket Pathways for Combination Products; Draft Guidance for Industry; Availability Medical Device and FDA Regulations and Standards News 0
S China 2018 draft Amendments to the Regulations on the Supervision and Administration of Medical Devices China Medical Device Regulations 1
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
P Understanding FDA draft "Management of Cybersecurity in Medical Devices" Medical Information Technology, Medical Software and Health Informatics 3
M Medical Device News FDA Releases Draft Recommendations on Premarket Submissions for Management of Cybersecurity in Medical Devices Other US Medical Device Regulations 0
M Medical Device News FDA news - 05-09-18 - Draft - Uncertainty in Benefit-Risk Determinations Other US Medical Device Regulations 0
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
K Computerized system Master Validation Plan, IQ-OQ-PQ Draft or Template Qualification and Validation (including 21 CFR Part 11) 4
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
S 'Clean' Draft Medical Device Regulations Published EU Medical Device Regulations 0
Ronen E FDA releases new draft guidance on when to submit a 510(k) for device modification Other US Medical Device Regulations 10
Ronen E FDA issues draft guidance on form & content of UDI Other US Medical Device Regulations 0
M AAMI draft report - Postmarket Risk Management ISO 14971 - Medical Device Risk Management 2
Ajit Basrur WHO Draft document - Regulatory Framework for Medical Devices Other Medical Device Regulations World-Wide 0
Ronen E FDA issues draft guidance on additive manufacturing Other US Medical Device Regulations 1
bio_subbu USFDA issues draft Guidance on the Acceptance of Medical Device Clinical Data Other US Medical Device Regulations 1
R 510(k) Draft Guidance issued: 2011 vs 2014 - Appendix C. 510(k) Process diagram gone US Food and Drug Administration (FDA) 1
J Draft Guidance document compliance mandatory to avoid a RTA? Other US Medical Device Regulations 2
M New FDA Draft Guidance on 510(k) Ownership and Use Other US Medical Device Regulations 3
J Legal source to purchase a copy of the 9001:2015 Draft ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
