How to efficiently and compliantly reference external standards/regulations
I am looking for advice on how to efficiently and compliantly reference external standards/regulations. I work for a small medical device company and we are rapidly expanding into new markets and with that we are now governed by over 100 standards/regulations. Historically we would cite 21CFR part 820, EU-MDR, ISO 13485, etc. but now that we have so many it to cite that when there is an update it has been shown this method will no longer work.
We are considering creating a master index of regulations/standards but I think that it would be so long that it would risk people missing applicable standards/references when updating or creating a new SOP.
John Broomfield
QSE,
Each publisher of the refs and regs should be the responsibility of someone to monitor for updates and changes. This person is usually the specifier of service, product, or process requirements.
Your specifiers may have already bookmarked their links to the websites where each of these refs and regs is kept up to date. They may also subscribe to notifications of planned changes.
Ask them how they’d like to share their links and notifications.
That sharing will help verify the links and open them up to your internal audits.
Creating and maintaining a master index reminds me of the 1980’s.
Best wishes,
John
Jean_B
In short: avoid direct implementation for every occurrence by aligning your system to all of them.
The issueing organizations you have no control over, but you can monitor their current valid regulations/standards, etc. (These would be external documents to you, and that is what I will call them from now on). Let's call this part the 'awareness'
Every time an external document becomes applicable to you take note under the 'awareness' part in a central list (note that this listing is seperate from the documents that would indirectly prove your compliance as they follow your far more useful internal procedures). Note the state your system is at as well (e.g. aligned vs not-aligned).
  • Prime examples are market entry (usually under marketing or R&D) and new introduction to existing product (harder to trigger, usually done by a scan once every so often on the relevant categories you know of).
  • Take care to note when you need to retrospectively generate (especially technical) documentation due to updates to external documents. This occurs most often when you have been running a lean system and not necessarily been generating all kinds of information auditing organizations might assume you have but not often bothered to check since older editions seemed to have been more lenient or left wiggle-room.
Implement these through a QMS process which updates your own internal processes to align with or provide for their requirements (there is a lot of overlap). Let's call this part the 'alignment'. This takes the form of delta analysis (for updated external documents), gap analysis (delta to your current QMS), and alignment/implementation which changes your QMS to be compliant.
Through alignment you should far less often need to directly cite external documents in procedures as you have a method to keep your entire system aligned. The advantage should also be that you have less region specific work-instructions as you weave the requirements into the most appropriate process and the evidence should flow out naturally.
Schedule frequent audits on the process of effective alignemnt to external documents and you should (for a small device company) have a good argument that you are assuring compliance.
You still need to do some citing, especially when you are offloading work to standards/methods (and thus not in your system) or when you are claiming documents as evidence of meeting the requirements of certain (parts of) external documents (especially in technical files).
On detailed citing there's already an extensive post: Quality Policy - Standards and reference numbers
J Validating multiple injection molding machines efficiently ISO 13485:2016 - Medical Device Quality Management Systems 5
J How can I manage Occurence Rates in FMEA efficiently when I have many processes? FMEA and Control Plans 9
A How to review a procedure which covers different production lines efficiently Document Control Systems, Procedures, Forms and Templates 2
C How to efficiently audit Suppliers Qualification Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Efficiently Produce Control Plans and FMEAs FMEA and Control Plans 1
T Deviation Tracker - Anyone have a template that can efficiently track 4 days of data? Customer Complaints 2
Wes Bucey Tips to filter spam more efficiently? After Work and Weekend Discussion Topics 28
M SOPs - Reference Documents Section Document Control Systems, Procedures, Forms and Templates 3
B Reference to IEC 60950-1 in Amendment 2 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
J Marking "Distributed By" to product with distributors' reference-code EU Medical Device Regulations 3
Dazza 9001, 14001 and 45001 mandatory documents and records cross reference matrix Process Maps, Process Mapping and Turtle Diagrams 2
T CSE 5.01 reference on drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
CycleMike GD&T - Hole pattern - Print (attached) has a single Datum Reference Frame Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
R ASQ reference material clarification - Spiral bound materials allowed in ASQ Exam? Professional Certifications and Degrees 1
D Good Acceptance Activity/Inspection flowchart for reference - Wanted Please Process Maps, Process Mapping and Turtle Diagrams 2
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
I Data Backup Plan - Document Reference ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Lot assignment for secondary reference standard - Pharmaceuticals Manufacturing and Related Processes 0
V Inspection with 3D Scanning - Reference Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
E Ethylene Oxide Sterilization Validation-Reference Load Other Medical Device Related Standards 2
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
C Do Calibration Reference Standards require an MSA study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
M Quality Policy - Standards and reference numbers ISO 13485:2016 - Medical Device Quality Management Systems 14
M Reference to IATF 16949 clause 8.4.3 in clause 8.3.4.4, Is it right? IATF 16949 - Automotive Quality Systems Standard 1
S Reference calibration tools (traceable to NIST) that are not used in production ISO 13485:2016 - Medical Device Quality Management Systems 4
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
M Looking for Cross reference of AS9100:2016 to ISO13485 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Print only has Reference Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V QMS / QSR - Reference to Framework - Templates - Procedures for Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
E IEC 60601-2-25 Reference to 60601-1 2nd Edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
M AS9100 Rev. D - Can anyone recommend a good reference book? Book, Video, Blog and Web Site Reviews and Recommendations 7
B When to use "For Reference Use Only" on documentation Document Control Systems, Procedures, Forms and Templates 4
G BCARs/EASA to ISO9001/AS9100 cross reference matrix/table wanted EASA and JAA Aviation Standards and Requirements 1
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Use of Certified Reference Materials for Quality Assurance General Measurement Device and Calibration Topics 6
A Reference Source for Polarity Symbol Other ISO and International Standards and European Regulations 1
Q Multiple Quality Standards - AS9100 and ISO13485/9001 Cross Reference Matrix Quality Manager and Management Related Issues 3
E Reference Only on Gage or Visual Aid Calibration Frequency (Interval) 4
F Quality Objective Reference Chart Customer Complaints 4
V Good Documentation Practices - FDA Reference US Food and Drug Administration (FDA) 9
M Good reference sites or material to help me brush up quickly on Gage R&R Reliability Analysis - Predictions, Testing and Standards 7
J How does Layout Inspection determine Reference Value? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
