How to Ensure Compliance with Noise Exposure Limits?
samsung
Exposure to high noise is a significant health hazard and as such there are regulatory requirements for control on noise or atleast workers' exposure to noise within the prescribed limits.
What I'm confused about is the exposure limit v/s noise level. Here's an example to clarify my question - if the noise level is 95 dBA, the maximum prescribed limit for human exposure is 4 Hrs. I'm not sure of the exact meaning of this requirement and thus have the following queries:
a) Is it permissible for a worker to work for 4 hours a day at 95 dBA without hearing protectors?
b) Is it permissible for a worker to work for 4 hours at 110 dBA with hearing protectors that provide 15 dBA noise attenuation?
c) or after using the above said hearing protectors, can a worker be made to work for 8 hours in a 95 dBA noise environment?
Before putting up here, I went through the noise rules, searched the internet and other resources but the confusion still prevails.
Request your opinions/comments on the interpretation of this regulatory requirement.
Thanks.
Jason PCSwitches
I feel that this should be a matter of what I perceive as common concern for our human counterparts. Anyone subjected to abnormal levels of audio frequencies should be required to don protection regardless of a particular industry guideline.
Personally, I've adopted the approach of treating each environmental risk factor as if I were subjecting my own children to the environment. How would I protect them - as such, we should treat all personnel in the same manner. While that may appear to be over the top, we should treat our fellow man in the same regard, as much as possible.
Hi
The numbers you have given are for factory workers and I am not sure if 95 dbA is allowed for 8 hours working. It should be 85 dBA. Indeed these levels and exposure times are safe boundaries to work without any special precautions to avoid any long term effect. i.e. one can work for 8 hrs a day 5 days a week without ear muffs/ear plugs when he is exposed to a sound level of less than 85 dBA, week after week, year after year without much of an effect on his hearing (i.e. the probability of the worker affected by hearing impairment in the long term is negligible). As the sound level increases the allowed time of exposure decreases to avoid long term effects. But in practice, as a precaution, workers are expected to wear a ear muff/ear plug if they work in areas with more than 85 dBA sound levels. Of course the best way is to reduce the sound level by design or engineering controls and bring the level to less than 85 dBA.
With kind regards,
Ramakrishnan
samsung
Thanks Jason. I appreciate your concern and respect for the human environment and I very much support that any occupier should do more than what's minimum prescribed in the corresponding legislation. But purely from the compliance standpoint, I want to understand the requirement or say the intent of the requirement so as to make sure that whatever action I take to prevent the fellow beings from being exposed to high noise is right and will serve to protect their health. It's always not possible to reduce the source noise and whatever best one can do is to limit the exposure and provide the fellows with protective equipment. So the question is how do I know that I have done well or atleast what I was supposed to be doing.
samsung
Hi
With kind regards,
Ramakrishnan
Infact 95 dBA exposure (to continuous noise) is allowable only for 4 hours a day in a manufacturing environment. I have attached the relevant part of the factory rules that allow 8 hours of exposure to 90 dBA noise level in a day. But as the noise levels go up, the exposure is exponentially lowered and at 105 dBA, the permissible exposure time is just an hour a day. My question is - can a worker be allowed to work for 8 hours a day at 105 dBA while wearing hearing protectors designed to attenuate the noise level by 15 dBA (effective exposure being 90 dBA)?
Thanks.
somashekar
Thanks.
No.
What I gather after reading This
ILO says this :
"workers should not be exposed to noise levels above 95 dB for more than four hours per day. Exposed workers should be provided with ear protection while exposed at this level and rotated out of the noise areas after four hours of continuous work."
Goes to say that if the noise level is 95dB, two things are requirement:
1. Protection
2. Not more than continuous 4 hours work with protection when noise is 95 dB.
At 90 dB 8 hour work is permissible
At 105 dB protection must be provided and not more than 1 hour work is permissible. Even if the protection gets the effective noise down to 90 dB to the person, he must be rotated out every one hour.
samsung
I'm inclined to agree with your point and believe that it's practically not possible to work in a 105 dBA work environment with naked ears but the following rule (given in my previous post attachment) makes the things little ambiguous:
"Where the ear protectors provided in accordance with sub-paragraph (2) and worn by a worker cannot still attenuate the noise reaching near his ear, as determined by subtracting the attenuation value in dBA of the ear protectors concerned from the measured sound pressure level, to a level permissible under Table 1 or Table 2 as the case may be, the noise exposure period shall be suitably reduced to correspond to the permissible noise exposures specified in sub-paragraph (1)."
According to this and for the purpose of calculating the effective noise (reaching near the ears), the protection provided by the hearing aids is to be subtracted from the measured value. If the difference of the two values falls within the limits, then it's OK for the worker as well as for the regulators?
Not sure if I understood it correctly.
ScottK
Not out of the crisis
In the USA this would be correct.
Per OSHA
When employees are subjected to sound exceeding those listed in Table G-16, feasible administrative or engineering controls shall be utilized. If such controls fail to reduce sound levels within the levels of Table G-16, personal protective equipment shall be provided and used to reduce sound levels within the levels of the table.
It's simply subtracting the noise reduction Rating (NRR) of the PPE from the actual time weighted average noise level.
For example, If your time weighted average is 95 dB over 8 hours and you use Noise Reduction Rating 15 dB ear plugs, then your people may easily spend an 8 hour shift in the area.
The most common ear plugs I've seen have an NRR of 25 or more.
samsung
Per OSHA
So my interpretation is close to what the rule says provided the degree of attenuation offered by the ear protectors is correctly measured or ensured. This is indeed a tough task to handle since NRR keeps decreasing with continued use of hearing aids and there's no way to measure there efficiency at site. So the best deal is to keep a wider safe margin.
ScottK
Use a disposable ear plug and change them more than once a day. And provide training on how to insert them properly.
I worked in an adhesive tape converting facility for a number of years - imagine 25 rolls of duct tape being unrolled at high speed at the same time... per machine.
Even with a noise booth over the unwinder the operators on the rewind were exposed to over 105 dB unprotected for most of the day.
Disposeable ear plugs with a 25-33dB NRR, changed at break times, were perfectly acceptable to our insurance agency and to OSHA.
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
S Digitising Existing Documents to ensure regulatory compliance Document Control Systems, Procedures, Forms and Templates 6
S How do you ensure compliance with 4.3.2 - Legal & other requirements? ISO 14001:2015 Specific Discussions 31
C What should a temporary, remote location have in place to ensure OSHA compliance? Occupational Health & Safety Management Standards 14
F How do I ensure QSR compliance in an FDA company within 12 months ISO 13485:2016 - Medical Device Quality Management Systems 33
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
T How you ensure that QMS is effective and efficient? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N How to ensure our employees don’t grab and use the wrong materials Manufacturing and Related Processes 11
Moumen H Controls to ensure that Quality Plans are accurate APQP and PPAP 2
Sidney Vianna IATF bringing stakeholders together to ensure Transition by the 2018-09-14 deadline IATF 16949 - Automotive Quality Systems Standard 10
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D AS9100 7.4.1 vs 7.4.3 - Ensure purchased product conforms to specified requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Ball Bearing V-Blocks to ensure Lobing and Roundness are Minimal Manufacturing and Related Processes 1
H Methods to Ensure that we are Purchasing what we've Designed Benchmarking 16
T MSA - Repeating Gauge R&R to ensure effectiveness over time Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T How to ensure Inventory FIFO (First In First Out) by Suppliers Supplier Quality Assurance and other Supplier Issues 1
B How does an organization ensure valuable employees are taken care of? Career and Occupation Discussions 10
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M AS 9100 Transition Checklist to ensure all areas of the new REV C are covered AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Do I need a QMS and what do I need to ensure my QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M What is the best way to ensure retraining when changes occur? ISO 9001 Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Q How to ensure quality on the supplier? Supplier Quality Assurance and other Supplier Issues 4
Sidney Vianna How do philanthropic foundations ensure their projects are properly managed? Coffee Break and Water Cooler Discussions 1
B How to ensure Configuration Management and Control manually AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T How to ensure that counterfeit goods do not enter into our supply chain? Misc. Quality Assurance and Business Systems Related Topics 15
N Note interpretation - Ensure that the preservation of the product has been consider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Stijloor Toyota to extend development time to ensure quality World News 0
P 5 Ways to Ensure Mediocrity in Your Organization Lean in Manufacturing and Service Industries 2
E Protection 7.6 e - How do you ensure the application of this requirement? General Measurement Device and Calibration Topics 3
D How to Ensure Suppliers are meeting all RoHS Requirements RoHS, REACH, ELV, IMDS and Restricted Substances 8
G Inspection by Attributes to ensure a 99% Confidence in a Customer Contract Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
I ISO 9001: How to ensure Long Term Internal Benefits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
G To ensure that document changes are identified... Document Control Systems, Procedures, Forms and Templates 11
T What Verification Method can I use to ensure Supplier Implemented Preventive Action Nonconformance and Corrective Action 14
Ajit Basrur How to Ensure DNA Free parts - Molded Parts for Labware ISO 13485:2016 - Medical Device Quality Management Systems 2
F Supplier Audit Form - Process reviews at suppliers to ensure quality Document Control Systems, Procedures, Forms and Templates 5
J Ensure customer confidentiality - TS 16949 Cl. 7.1.3 Confidentiality Various Other Specifications, Standards, and related Requirements 7
B What Process will ensure defect detection? Nonconformance and Corrective Action 12
K TS 16949 Training - How can I ensure competence? IATF 16949 - Automotive Quality Systems Standard 8
J MSA - Is ISO 10012 the standard we are looking for to ensure the FDA will be happy Other ISO and International Standards and European Regulations 3
B Method to Ensure Latest Customer Specifications (Documents of External Origin) Customer and Company Specific Requirements 2
D Understanding ?to ensure the changes are identified?? Revision Status of documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Recurrence of NC - What do you do to ensure that non-conformities do not recur? Nonconformance and Corrective Action 8
B Reviewing corrective action - How to ensure that root cause analysis is correct Problem Solving, Root Cause Fault and Failure Analysis 5
D Electronic Documents and Forms - How can I ensure forms are entirely completed? Document Control Systems, Procedures, Forms and Templates 4
J 7.6 Process to ensure m and m is carried out IATF 16949 - Automotive Quality Systems Standard 3
M Frequency of Measurement Systems Analysis to Ensure Suitability General Measurement Device and Calibration Topics 9
H I see the word 'ensure' in standards - How do I comply? Misc. Quality Assurance and Business Systems Related Topics 1
