How to establish a Sampling Plan from the Rework percentage?
sowmya
Involved - Posts
Experts,
I am sure, you should have discussed this in forum. but I could not able to take it.
Currrently we are shipping the products to our customer place and our customer test the units and ship it to end customer. Moving forward, our customer want us to do direct shipments to the end customer.
Current reject rate at customer end is 0.7% for product A and 0.3% for product B.
We have analyzed the rejects and put gate points based on pareto.
There is 100% visual inspection and functional testing at our end. over and above we are doing Outgoing audit at AQL percentage 0.01% normal inspection.
my question is to reduce the defect to 0.1% (1000PPM) at customer end, what would be the AQL I have to choose?
In simple words, I want to increase my sample size at OQA, so that customer is getting less than 1000PPM defect.
Sowmya
Chennaiite
Never-say-die
I wouldn't prefer leaning on sample audit to reduce customer end ppm, even though statistics can prove it on paper. Why don't you go for the same controls what your customer have today for detecting 0.7% or 0.3%?
supreecha
Acceptance Sampling by Attributes
Measurement type: Go/no go
Lot quality in percent defective
Lot size: 5000
Use binomial distribution to calculate probability of acceptance
Acceptable Quality Level (AQL) 0.01
Producer's Risk (Alpha) 0.05
Rejectable Quality Level (RQL or LTPD) 10
Consumer's Risk (Beta) 0.1
Generated Plan(s)
Sample Size 22
Acceptance Number 0
Accept lot if defective items in 22 sampled <= 0; Otherwise reject.
Percent Probability Probability
Defective Accepting Rejecting AOQ ATI
0.01 0.998 0.002 0.010 32.9
10.00 0.098 0.902 0.980 4509.8
Average outgoing quality limit (AOQL) = 1.628 at 4.348 percent defective.
mdurivage
If there is rework involved, I would reccomend at least one a column shift left to demonstrate a more conservative approach because you will have increased the number of items inspected to make a decision of lot acceptability.
Experts,
Aside from Chennaiite's excellent point about determining the casual mechanisms of the defects and eliminating them - or creating 100% error proofing or defect detection methods - you really aren't looking for an AQL based sample size but an RQL (aka LTPD) or Rejectable Quality Level.
Remember that an AQL plan will ACCEPT the AQL defect rate 95% of the time. An RQL based plan will DETECT and REJECT the RQL defect rate.
When we select a sample size based on the AQL, the RQL is a 'residual' level depending on the accept number chosen. And in today's misguided world of accept on 0 plans teh RQL can be quite large.
You will find a spreadsheet that calculates the sample sizes needed based on either or both the RQL and AQL here.
fro example, if you really want to ship lots that are no more than .1% defective then you want a plan that has a .1% RQL.
IF you choose a c=0 plan then your sample size is 2996. This will give you a 95% chance of detecting and rejecting a lot that has .1% or more defects in it. The resulting AQL for this plan is about .0017% or about 17ppm
If you use an AQL of .1% and a c=0 plan your sample size is 51 and the resulting RQL is 5.7%.
(These plans are all based on 95% confidence and are irrespective of lot size. Lot size really doesn't matter until the lot becomes very small)
sowmya
Involved - Posts
Thanks Bev, can you pl. attach the spread sheet. I could not able to open.
I will go through this and come back for any clarifications.
Thanks again.
Sowmya
sowmya
Involved - Posts
Thanks. We have put error proofing where ever possible. but some issues (like assembly damage, label peel off ) could not be error proofed 100%.
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
O How to establish Datum Planes with two cylinders? Various Other Specifications, Standards, and related Requirements 0
H How to Establish and Document Competence of Employees in a Small Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
shimonv 21 CFR 820.20(d) says: Each manufacturer shall establish a Quality Plan 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Historical Data to establish Control Limits Manufacturing and Related Processes 4
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
T To establish ISO 9001:2008 in a ISO 17025 accredited Company ISO 17025 related Discussions 4
G Characterization Studies: Analyzing Data to Establish Conclusions Statistical Analysis Tools, Techniques and SPC 1
F FAA Letter of Need to establish Continuing Need Federal Aviation Administration (FAA) Standards and Requirements 1
B Airbus to establish assembly line in United States AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G NADCAP - How do I establish if a process is covered? Manufacturing and Related Processes 3
D Establish a Documented Procedure (4.2.3) vs. Establish Process (7.6) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q How to Establish Microbiological Limits in Foods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R How to establish Quality Objectives per TS 16949 Clause 5.4.1 Requirements IATF 16949 - Automotive Quality Systems Standard 7
K How to establish critical limit for Critical Control Points (CCPs) Food Safety - ISO 22000, HACCP (21 CFR 120) 7
L Criteria to Establish a Relevant Due Date for Closing Corrective Actions Internal Auditing 8
Z How to Establish a Process in Terms of more Added Value? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Z Can we establish system documents with VIDEO or HUMAN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How to Establish Internal Quality Control Planning APQP and PPAP 4
T How to establish KPI Disposal and Follow Up Process Quality Tools, Improvement and Analysis 7
G Quality Policy Requirements - Establish and implement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C How should I establish Quality Systems in my small company Manufacturing and Related Processes 7
C The organisation shall Establish, Implement & Maintain a Procedure(s)? ISO 14001 ISO 14001:2015 Specific Discussions 21
C Do I have to establish a software validation procedure? Qualification and Validation (including 21 CFR Part 11) 11
C How to establish a Design History file (DHF)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
R Anyone know how to establish one piece flow in apparel industry? Lean in Manufacturing and Service Industries 9
M How to Establish criteria for acceptance of products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ajit Basrur FDA on path to establish offices in China US Food and Drug Administration (FDA) 0
H Is it possible to establish a new subforum for TL9000? TL 9000 Telecommunications Standard and QuEST 7
Z How to Establish Quality Manual Not Following the Structure of the Standard? Quality Management System (QMS) Manuals 3
Z How to Establish Quality Policy Based on Vision of Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q How can I Establish a New Medical Device Laboratory? ISO 13485:2016 - Medical Device Quality Management Systems 12
Z How to Establish a TS 16949 QMS in an ISO 9001 Registered Company? IATF 16949 - Automotive Quality Systems Standard 2
Z How to Establish Simple and Efficient Procedures and Operating Instructions Document Control Systems, Procedures, Forms and Templates 16
A Establish a New Quality System based on Lean - Starting A Late Career in Quality Lean in Manufacturing and Service Industries 7
R What statistical method to establish a specification? Statistical Analysis Tools, Techniques and SPC 16
T How to establish the 4M (Man Machine Method Material) change control Manufacturing and Related Processes 5
C How to establish an effective ISO/TS16949 System? IATF 16949 - Automotive Quality Systems Standard 2
A How to establish linkage between specs/control plan/FMEA/process flow? Document Control Systems, Procedures, Forms and Templates 10
Douglas E. Purdy Acceptability of Perishable Tooling - How do you establish the standards/requirements Various Other Specifications, Standards, and related Requirements 2
apestate Job Shop Inspection and Test - Where should we establish inspections? Why? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
Raffy Do we need to establish Quality Objectives per department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Geoff Cotton Taguchi quality loss function - How do I establish the 'Consumer Loss' element? Quality Tools, Improvement and Analysis 6
J IVD sampling sizes for buyer Reliability Analysis - Predictions, Testing and Standards 0
C Sampling - ISO 16269-6 vs ISO 2859 Other ISO and International Standards and European Regulations 0
L Sampling Plan Risks AQL - Acceptable Quality Level 6
