How to Estimate the Number of Replicates on a DOE (Design of Experiments)
Jparfer
Hi there!
How can I calculate the number of replic i need to do in order to arrive to good conclusions and to get all the variability of the process?
The answer is yes, but you will probably need a good software package. You need an estimate of the process standard deviation, the effect size that you wish to detect, as well as the alpha risk and power. Minitab has an easy to use Power and sample size calculator.
If you do not have a software package try this online ANOVA sample size calculator. You will have to go at it in a trial an error approach and the answer will be approximate, but should be close enough.
Jparfer
Yes, I?m using Minitab software
I have this menu, but i have some doubts in how to fill some fields:
Number of corner points: I think that is the numer of corners in the cube. For example, in a complete 2^3 = 8, and in a complete 2^4=16
Effects: I have no idea of how to fill it.
Can someone help me in this and give me the formula to stimate it?
Thanks!
supreecha
Power and Sample Size
Plackett-Burman Design
Alpha = 0.05 Assumed standard deviation = 0.5
Factors: 4 Design: 12
Center pts (total): 3
Including a term for center points in model.
Center Total Target
Points Effect Reps Runs Power Actual Power
3 0.75 2 27 0.9 0.938420
3 0.75 2 27 0.8 0.938420
3 0.75 2 27 0.7 0.938420
3 0.75 1 15 0.6 0.639023
3 0.75 1 15 0.5 0.639023
3 0.75 1 15 0.3 0.639023
3 0.75 1 15 0.2 0.639023
3 0.75 1 15 0.1 0.639023
Power Curve for Plackett-Burman Design
Number of corner points: You are correct. This is the number of experimental runs, excluding replicates and center points.
Effect: this is set by you. How large or small of a process shift do you want to detect? It should be large enough that your boss would get excited and be willing to fund more experiments. Also, if this number is set to 1 standard deviation or smaller, the sample size rapidly increases.
D Estimate Sample Size for very rare event Using Minitab Software 1
S Is there a difference in the process? Analyze residuals, construct interval estimate Using Minitab Software 2
S Least squares estimate, regression model and corresponding residuals Using Minitab Software 13
G How to compute or estimate a micrometer or caliper flatness using optical flat General Measurement Device and Calibration Topics 2
0 The Uncertainty of an Estimate of the Bias ISO 5725-1 - Help Measurement Uncertainty (MU) 8
B Interpretation of Hodges-Lehmann's estimate of tau Statistical Analysis Tools, Techniques and SPC 4
Z How to estimate Uncertainty for Instrumental Results Measurement Uncertainty (MU) 3
I Cpk < 1.33 - How do I estimate actual defects? Statistical Analysis Tools, Techniques and SPC 7
Q Quick ISO-TS 16949 Electronic Copy Cost Estimate IATF 16949 - Automotive Quality Systems Standard 2
E How to Estimate the Time of GTAW and FCAW Welding Procedures? Manufacturing and Related Processes 4
Z Estimate Spread of Tolerance Stackup for each Dimension to Cp Statistical Analysis Tools, Techniques and SPC 1
B Gage R&R estimate of confidence interval Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M How do I estimate sigma level for my workshop? Six Sigma 14
P Cost Estimate for how many hours to measure a part (Full first artcle) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A How Can I Estimate Cp? Statistical Analysis Tools, Techniques and SPC 2
S Adding new product code/Catalogue number to existing 510K US Medical Device Regulations 0
J Average number of Nonconformances during internal quality audit for Medical Device Manufacturers Internal Auditing 3
I Restricting scope to one part number for one customer IATF 16949 - Automotive Quality Systems Standard 6
T EN 17141 - number of monitoring locations Other Medical Device Related Standards 2
renenatasha Single Registration Number (SRN) EU Medical Device Regulations 2
Ed Panek ANNUAL FDA Registration - What 510(k) number to use? US Food and Drug Administration (FDA) 1
B How to change hour format to text but not changing the number ? Excel .xls Spreadsheet Templates and Tools 1
Y CE marking with NB identification number EU Medical Device Regulations 0
H Notified Body Number with CE Mark CE Marking (Conformité Européene) / CB Scheme 4
L How to deal with the model number symbol for X-RAY PRODUCT Other Medical Device Related Standards 1
R UDI Number Identification EU Medical Device Regulations 5
G Number of Destructively Tested Devices Needed for Ethylene Oxide Validation Other Medical Device Related Standards 4
D Number of people to be interviewed during an internal audit? Internal Auditing 10
S How to calculate Effective Number of People for ISO 13485 Certification? General Auditing Discussions 2
Ch00Ch00 Evaluate a process - Issue number Lean in Manufacturing and Service Industries 7
N How to find column number for the last non-empty column? Using Minitab Software 0
S Business Number versus Company ID? Canada Medical Device Regulations 3
B Document Issued with incorrect Document number code Document Control Systems, Procedures, Forms and Templates 3
M Are you allowed to reuse the same asset number if the device was replaced? General Measurement Device and Calibration Topics 10
D Control Number for Class III and IV devices Canada Medical Device Regulations 1
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
K How can Acceptance Number and Reject Number be larger than Sample Size on Z1.4 Table? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
K Why 'FD&C act section number' and 'section number' in the title of the act are different? US Food and Drug Administration (FDA) 7
A Risk Number for each software requirement IEC 62304 - Medical Device Software Life Cycle Processes 7
K Adding the Notified Body Number CE Marking (Conformité Européene) / CB Scheme 2
C Quantifying risk in choosing the number of parts, operators and replicates in a GR&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Jane's Like-for-like critical raw material change qualification - type of testing/ number of lots required ISO 13485:2016 - Medical Device Quality Management Systems 4
Q LOT or Serial Number Symbol not used when the information is contained in the UDI? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Proud Liberal Power Query to combine multiple tables of unequal number of columns Statistical Analysis Tools, Techniques and SPC 1
Q How is Medical Device Number (MDL) assigned to companies? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
D How to get EUDAMED Single Registration Number (SRN) EU Medical Device Regulations 19
M Informational US FDA – Modifications to the List of Recognized Standards, Recognition List Number: 052 Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
I Number of decimals in equation calculated by MiniTab Using Minitab Software 0
