How to Evaluate a Calibration Report Certificate
silver ring
Measuring devices are sent to calibration. After the calibration is completed, measuring devices are returned back together with their calibration certificates. How are we going to evaluate these certificates. What are the critical points to look for and judge the usability of the measuring equipment?
P
phloQS
Re: How to Evaluate a Calibration Certificate
Calibration depends on type of measuring device. The accuracy, the precision and the nominal value could be some of the information. Information on the kind of calibration nominals could be another information. Basics like who did it, when was it performed and when is next calibration required should also be in place.
regards
phloQS
MantleMickey
When I get back gaging, I look for CALIBRATION RESULT-PASSED.
Next, I look at the ranges of the calibration checks.
Example-standard is .00200, tolerance is + .00210, - .00190.
My gage measured AS FOUND .00204, within this range.
I check each measurement the same way, to ensure all ranges
are in spec. I also make sure gages were calibrated to ISO/IEC 17025
If all looks good on the cert of calibration, I check mark and initial the
report to show it was reviewed. Good luck.
BradM
Aside from the great responses given...
  • Date calibration was performed
  • N.I.S.T. traceability
  • procedure used for verification
  • as-found/ as-left data (if requested)
  • Technician name
  • Uncertainty/ statement of uncertainty
  • Company name/ organization that actually performed the calibration (in the event the service was outsourced).
  • I evaluate the data and compare to previous results. Are we calibrating too often/ not often enough? (To me... as-found/ as-left data pays for itself with the management information it provides.)
  • Is the device suitable for its current use/purpose?
  • If the device was found Out Of Tolerance, the magnitude of the error is useful in investigating any potential process impact.
I can't think of no more right now. :D
Hershal
Metrologist-Auditor
One thing to watch for, if the cal lab is accredited, then the accreditation information. It is possible that for that information there will be an additional charge.
For traceability, in the US it is common to claim NIST traceability, though not required if a different NMI is providing the traceability. If outside the US, then a different NMI is the norm.
Hope this helps.
jimatsntc
I agree with everyone above....and one more thing you need check is the standard they used to calibrate your equipment... every lab. shall indicate the referencd standard used... checked the spec. if that is suitable or good enough to use as a standard...
Good luck...
barkranch
Can anyone please help me understand the information that should be reported on a calibration report? I understand what basic information must be documented on the report. What I am struggling with is how do I determine the accuracy of the instruments used to calibrate my gages (thread rings for example)? The reports I receive list the measuring instruments used to calibrate the thread rings and :confused:their identification/calibration due dates but it does not report their accuracy. Naturally, the measuring instruments accuracy should be greater than the gage it is calibrating. I had an auditor ask me how do I verify the measuring instruments accuracy is greater then the gage it is measuring and I didn't know how to respond. I work for a medical device manufacturer and we are certified to ISO 13485. Any response is greatly appreciated.
Sean Kelley
I would like to add that the scope of the 17025 certification needs to be verified. We had a finding in the past that one our our pyrometers measured to 2100 degrees and the company performing calibration was only certified up to 1800 so this pyrometer was out of their scope.
Another example: if they are calibrating your micrometers make sure their scope includes micrometers of that range such as 0-1", 1-2", etc. They may be able to do small micrometers under their scope but when your get to a 48" they may not be certified to be doing this work.
Sorry that I don't have a reply for you...but if I may suggest - it might be better to make this a new thread - you're likely to get a wider response than piggy-backing it here.
James
S How to Evaluate the Outgoing Quality Level of a Calibration Laboratory? General Measurement Device and Calibration Topics 3
D Evaluate and Monitoring of Equipment and Calibration Suppliers General Measurement Device and Calibration Topics 2
Ch00Ch00 How to evaluate a process ? Document Control Systems, Procedures, Forms and Templates 3
Ch00Ch00 Evaluate a process - Issue number Lean in Manufacturing and Service Industries 7
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
Watchcat CERs Literature Databases - Searching for data to evaluate EU Medical Device Regulations 16
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
qualprod To Evaluate Effectiveness in All Improvements? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Evaluate Contingency Plan for Equipment and Tools IATF 16949 - Automotive Quality Systems Standard 4
qualprod Propose Aspects to evaluate risk impact? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to Evaluate Internal Resources for Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Source of practice to Evaluate Risks? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S How to evaluate "competency" of consultants ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
Jen Kirley How to evaluate hazards in using bar code scanners in chemical manufacturing Occupational Health & Safety Management Standards 1
A Creating a policy to evaluate the Third Party Security IEC 27001 - Information Security Management Systems (ISMS) 4
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
G How to Audit or Evaluate our suppliers? We are not AS 9100C certified. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Format to Evaluate the Effects of New Processes and Equipment Manufacturing and Related Processes 4
K Validity of Using NCR's to evaluate Performance Nonconformance and Corrective Action 7
T Why evaluate Suppliers that are Brands we represent? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Web based Database to Collect and Evaluate 5S Audit Results, Trends, Charts Lean in Manufacturing and Service Industries 3
S Required to Assess and Evaluate all Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W How you can evaluate ISO 9001 Certification Body (CB) Auditors during their visits? Registrars and Notified Bodies 19
B How do you evaluate courses - eg. Awareness Training, Concept etc. Training - Internal, External, Online and Distance Learning 3
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
R Can manufacturer separately evaluate the clause 14 (PEMS) of 60601-1: 2005? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Training Efficiency Assessment - Evaluate the Effectiveness (Clause 6.2.2 c) Training - Internal, External, Online and Distance Learning 3
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
B Our suppliers are retail shops - How to evaluate OTS (Off the Shelf) suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Do I evaluate my supplier when he doesn't have delivery in that month? Supplier Quality Assurance and other Supplier Issues 10
0 Best way to evaluate the differences between 2 gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Distribution of Procedures to the copy holders (evaluate my matrix) Document Control Systems, Procedures, Forms and Templates 16
S How to evaluate the Effectiveness of Corrective and Preventive Actions Nonconformance and Corrective Action 3
B How to Evaluate Competence of an Internal Translator ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Board of Directors - Their duties and how can we evaluate them? Misc. Quality Assurance and Business Systems Related Topics 8
B What happens if we evaluate supplier as not approved and there are no anothers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L Weighing plastic part to evaluate moulding process Design and Development of Products and Processes 2
J Approved Supplier List - Required to evaluate every supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Supplier Quality Rating - What to evaluate Supplier Quality Assurance and other Supplier Issues 11
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K How to evaluate or measure the complexity of product? Manufacturing and Related Processes 8
V Should We Evaluate Suppliers on a Regular Basis or only when Issues Arises? Supplier Quality Assurance and other Supplier Issues 7
R Evaluate Customer Satisfaction without having to send questionnaires Supplier Quality Assurance and other Supplier Issues 2
