How to evaluate "competency" of consultants ?
SGquality
Hello Covers,
So good to be back :bigwave:
I have a question on 21 CFR Part 820.50 (1), that states the below:
Evaluate and select potential suppliers, contractors, and consultants on the basis of their ability to meet specified requirements, including quality requirements. The evaluation shall be documented
How do organizations evaluate consultants / contractors during FDA inspection ? Would the consultant's Resume or CV be good to demonstrate or any additional documents required ?
Thank you very much !
Ronen E
Problem Solver
Moderator
Hello Covers,
The requirement is that you evaluate (and then select) on the basis of the ability to meet specified requirements. So first, you have to have the requirements specified, specific for that job (or set of jobs). You provide evidence for that by having the requirements documented upfront.
Once you have the requirements specified, you need to show that you tried to evaluate the consultant's / contractor's ability to meet them. I don't think that there's just one way to do that. If a resume provides reasonable assurance that the individual has an acceptable ability to meet the requirements, that'd good. Alternatively you could ask for a reference list, then talk to a few and document the results. Or anything of that sort. Essentially, it needs to make sense (and if you rely solely on a resume I would assess the reliability of what's written there, perhaps even try to verify the important bits independently). If you want to be on the safe side you could attach a 1-pager per candidate, describing your thought process and how you reached the conclusion that the individual meets / doesn't meet the ability threshold.
Finally, you could document how you selected one (or more) consultant(s) based on the results of the previous stage (competency evaluation), and why.
Cheers,
Ronen.
mihzago
Some auditors may ask about the skills and expertise of the consultant beyond just work experience, so make sure that the CV/resume or another document show that.
Look for certifications (RAC, ASQ CQA/CQE, auditor, etc), or additional training specific to your needs.
Ronen E
Problem Solver
Moderator
The requirement is to evaluate ability to meet specified requirements. If a requirement for specific certification has been specified, compliance with it should be evaluated (ie is the consultant certified); otherwise it's just an overshoot. The regulation doesn't specify what the requirements should be. It only requires that requirements are specified and evaluated against.
mihzago
Ronen, I agree, however, just because you don't specify something, does not mean you comply with the requirement.
I'm not saying that specifying certifications is required in all cases, I'm just providing an example of a way to evaluate and show consultant's competency.
I'm also sharing a real-life example for an ISO audit during which I was questioned on how did I evaluate and select a consultant for an internal audit. The auditor made it clear that using work experience is not a sufficient requirement.
Now whether the auditor had any basis for making this statement is something we can debate.
Ronen E
Problem Solver
Moderator
Let's please separate the FDA context from the ISO one, the requirements are not necessarily the same. The OP asked in an FDA context and my response was in that context too.
The FDA's requirement is not that you evaluate the consultant's competency in general (for which certifications could be a relevant measure), but their ability to meet the requirements specified (it implies that the requirements have to be specified first). My understanding is that if certification wasn't specified (which is easy to show if the job requirements are actually documented in each instance) then it's not something that needs to be looked into in order to comply with the requirement to evaluate. It might still be a good idea to look at certification, but that's a separate issue.
In the ISO context, I sure doubt that that auditor had grounds to make that assertion. This is one of those "Show me the 'shall'" situations. I'm not aware of a formal requirement for certification in order to be an internal auditor (assuming that we're talking about ISO 13485). I tend to agree that work experience alone might not suffice, but the missing element is independence and not certification. The auditor's comment could have also stemmed from some other obscure requirement in your system, rather than in the standard itself. I can't tell because I don't know your system.
Cheers,
Ronen.
v9991
Cheers,
Ronen.
We hire consultants because we need expertize (i.e., we are evaluating' competency where we dont have that adequate exposrue!) it might look like synopsis of credentials enquired/submitted to us.
further, is there a way to tie the "success criteria" of the proposed scope of work and get the response from the consultants and then do the comparison / assessment. ( its an attempt to actually move on from qualitative assessment to an comparison of outcomes, or precedence(s) of working in same area etc.,!) (essentially making the experts to respond ...and this actually happens in an another form, discussion on scope, etc.,)
Jen Kirley
Quality and Auditing Expert
This is important. Pretty much anybody can learn what the standard says, but a competent consultant needs to be able to guide you in value-added system definition (first), that conforms for certification (second). Too often these objectives are reversed in importance and the client is left with a burdensome or incoherent system.
T ISO 14971-2019 doubt - Evaluate if estimated risks are acceptable ISO 14971 - Medical Device Risk Management 9
Watchcat CERs Literature Databases - Searching for data to evaluate EU Medical Device Regulations 16
M Informational US FDA final guidance – Utilizing Animal Studies to Evaluate Organ Preservation Devices Medical Device and FDA Regulations and Standards News 0
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
M Minitab tool to evaluate PM (Preventive Maintenance) process Using Minitab Software 6
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
qualprod To Evaluate Effectiveness in All Improvements? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H Evaluate Contingency Plan for Equipment and Tools IATF 16949 - Automotive Quality Systems Standard 4
qualprod Propose Aspects to evaluate risk impact? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to Evaluate Internal Resources for Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Source of practice to Evaluate Risks? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Jen Kirley How to evaluate hazards in using bar code scanners in chemical manufacturing Occupational Health & Safety Management Standards 1
A Creating a policy to evaluate the Third Party Security IEC 27001 - Information Security Management Systems (ISMS) 4
C How to evaluate the Detection Ranking of a new Design Control FMEA and Control Plans 1
G How to Audit or Evaluate our suppliers? We are not AS 9100C certified. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Format to Evaluate the Effects of New Processes and Equipment Manufacturing and Related Processes 4
K Validity of Using NCR's to evaluate Performance Nonconformance and Corrective Action 7
T Why evaluate Suppliers that are Brands we represent? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
E Using ANOVA during the PQ Validation Run to evaluate Statistical Differences Statistical Analysis Tools, Techniques and SPC 4
N The right method to Measure and Evaluate a Flatness Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S How to Evaluate a Calibration Report Certificate General Measurement Device and Calibration Topics 8
J Web based Database to Collect and Evaluate 5S Audit Results, Trends, Charts Lean in Manufacturing and Service Industries 3
S Required to Assess and Evaluate all Suppliers? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W How you can evaluate ISO 9001 Certification Body (CB) Auditors during their visits? Registrars and Notified Bodies 19
B How do you evaluate courses - eg. Awareness Training, Concept etc. Training - Internal, External, Online and Distance Learning 3
M How to validate a Dye Test method used to evaluate Package Integrity Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
R Can manufacturer separately evaluate the clause 14 (PEMS) of 60601-1: 2005? IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
S Training Efficiency Assessment - Evaluate the Effectiveness (Clause 6.2.2 c) Training - Internal, External, Online and Distance Learning 3
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
B Our suppliers are retail shops - How to evaluate OTS (Off the Shelf) suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Do I evaluate my supplier when he doesn't have delivery in that month? Supplier Quality Assurance and other Supplier Issues 10
0 Best way to evaluate the differences between 2 gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Distribution of Procedures to the copy holders (evaluate my matrix) Document Control Systems, Procedures, Forms and Templates 16
S How to evaluate the Effectiveness of Corrective and Preventive Actions Nonconformance and Corrective Action 3
B How to Evaluate Competence of an Internal Translator ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Board of Directors - Their duties and how can we evaluate them? Misc. Quality Assurance and Business Systems Related Topics 8
B What happens if we evaluate supplier as not approved and there are no anothers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L Weighing plastic part to evaluate moulding process Design and Development of Products and Processes 2
J Approved Supplier List - Required to evaluate every supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Supplier Quality Rating - What to evaluate Supplier Quality Assurance and other Supplier Issues 11
U MSA Roadmap - Is there an order in which to evaluate a measurement systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K How to evaluate or measure the complexity of product? Manufacturing and Related Processes 8
V Should We Evaluate Suppliers on a Regular Basis or only when Issues Arises? Supplier Quality Assurance and other Supplier Issues 7
R Evaluate Customer Satisfaction without having to send questionnaires Supplier Quality Assurance and other Supplier Issues 2
B Evaluate Compliance to AS9100 Paragraph 7.6 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
J Evaluate a business or organization - Need case study for school! Coffee Break and Water Cooler Discussions 16
K The 'Cohen's kappa' method to evaluate degree of consensus between visual operator Six Sigma 9
D Which Indicator is Best to Evaluate our HR Training Programs? Training - Internal, External, Online and Distance Learning 7
P TS 6.3.1 Plant, facility and equipment - Methods to evaluate effectiveness of existin IATF 16949 - Automotive Quality Systems Standard 2
