How to handle Incoming (Receiving) Inspection as a PFMEA item?
anil123
#11
Failure mode is depends on the inspection characteristics as we have to analyse the risk if it happens what will be the impact of it during the manufacturing. Also FMEA will analyse the detection of the failure of the part characteristics during inward inspection.
It is basically the risk assessment tool.
Failure mode may be as under:
1. Dimensional variation
#12
No, if the cause of the failure is ascribed to the supplier, it shouldn't be addressed in the PFMEA. PFMEA failure modes should be limited to those caused by (or in) the present process. Remember--what you're trying to do in the PFMEA process is anticipate how your process(es) might fail.
DrM2u
#13
I agree with Jim. Failure mode is not limited only to product related failures, but it encompases process related failures that have an impact on the organization's ability to meet customer's requirements as well. Way too many organizations, teams and individuals limit their analysis to product failure modes and totally ignore the process. The main idea is to controll the PROCESS to ensure that PRODUCT characteristics are consistently and capably met. Most product failures are analyzed in Design FMEA. FMEA principles can also be applied to equipment maintenance, safety, etc.
To get back to the focus of this discussion, analyze and control the receiving process steps. The 'product inspection' is the actual verification that you received what you ordered and is just a part of the whole receiving process. There are many other failure modes in the process that should be considered in order to ensure an effective and efficient receiving process. Keep in mind that the purpose of having a receiving process is not only to verify incoming product but to also handle, process, evaluate, disposition, contain and/or store said product.
treesei
#14
I agree the PFMEA should focus on the process and the DFMEA should focus on the product. But please help me with this: A wrong material from the supplier, if not caught, can lead to product failure or non-conformance. Eg, a RoHS solder vs a non-RoHS solder. Will this potential supplier mistake be considered in DFMEA? I personally do not think so because supplier mistake is not a design flaw which I think should be the subject of DFMEA. Supplier problems will be better handled in supplier management or overall risk management. However, I have heard different voices and have seen such DFMEA putting "wrong part shipped from supplier" as a failure mode and the detection is incoming inspection.
#15
I can see some such things being addressed in a DFMEA. For example, there might be a purchased component that's similar in appearance to a different component that won't work in the present assembly. A DFMEA might address this by having the supplier use special markings or packaging, or by making sure that the component is properly verified before use. There are no strict rules in situations like this.
Richard Pike
#16
A basic principle of FMEA is that one must "assume" that the previous process is correct. Once this is accepted one is simply looking at the "mistakes" that can happen at that particular point of the process. In this instance receiving Inspection. That having been said there is often merit in including suppliers in the FMEA team for receiving. ps I do take exception to the "customer" who tries to dictate what they "want". The customer should stick to seeing if the FMEA is effective and not impose their "wants" unless of course by including those wants in their contract>
#17
Receiving inspection (and inspection in general) is an exception; you can't assume that the incoming material is what it should be, otherwise there would be no need for receiving inspection.
DrM2u
#18
The explanation for what you have seen regarding 'wrong product' in DFMEA is that the DFMEA is actually a major input to the PFMEA. The 'design' group established that on way for the product to fail is by using the wrong material. Assuming that you do not make that material, then the failure mode is the supplier shipping the wrong material and that not being detected. This becomes an input to the PFMEA for the receiving process, which should therefore include in it the detection methods for the correct/wrong material, among other things. There might not be much that you can do for prevention, other that the specifications you have in the purchase agreement.
Richard Pike
#19
Point taken. However I would maintain that the "Purpose" of inspection is to prevent defects from being processed further. So it remains to be established what would the "Causes" would be of the inspection process allowing defects to be processed further. I think we are in agreement and apologize if my choice of words confused the issue.
Harigovindan
#20
Re: How to handle incoming inspection as a PFMEA item?
You are right, incoming inspection is not required to include in the FMEA, if you want to include the transportation and loading and unloading at receiving stage for transit damages as failure mode and to analyse the current process controls of transportation and loading and unloading is sufficient or not then only you need to add these processes, i.e, loading and unloading and transportation at receiving stage.
K Different Indications for Use in Different Countries -- how to handle IFU? Other Medical Device Regulations World-Wide 4
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
I How to handle pending FSN when incident happens? EU Medical Device Regulations 1
Jimmy123 Process disturbances and the repair - How do you handle this risk in your company? FMEA and Control Plans 18
GoSpeedRacer How to handle operator involvement in the non conformance ISO 13485:2016 - Medical Device Quality Management Systems 5
A How to Handle Documented Information in an online database for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
V Systems to Handle Development and Batch Analysis in same Laboratory Qualification and Validation (including 21 CFR Part 11) 3
dubrizo How do you handle damaged IM&TE in your organization? General Measurement Device and Calibration Topics 3
D MDD Classification of Bone Saw Handle ISO 13485:2016 - Medical Device Quality Management Systems 1
1 How to handle Nononformances in Clincal Manufacturing ? Nonconformance and Corrective Action 2
R How do we handle Training during transition and overlap from one system to other ? Training - Internal, External, Online and Distance Learning 4
Q How to handle different voltages for different countries Document Control Systems, Procedures, Forms and Templates 1
A How to handle complaints after end of specified medical device life-time ISO 13485:2016 - Medical Device Quality Management Systems 5
M How does Australia handle products that are EU PPE, but Australia Medical Devices? Other Medical Device Regulations World-Wide 7
C How to handle this Inspection conflict? Second Shift Inspector? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T How to handle Demo Units during an ISO 9001 Audit General Auditing Discussions 3
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How to handle a blood stained GMP document ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
T How to handle 510(K) submisison in 2014 when the Fees were paid in FY13 ? US Food and Drug Administration (FDA) 3
C How to handle Action Results in a new FMEA Review once we have a new RPN? FMEA and Control Plans 1
Mikishots How to handle CAR (Corrective Action Request) Scope vs. Timely Response Nonconformance and Corrective Action 9
J Quality Procedure to handle some standard Medical Device Processes Document Control Systems, Procedures, Forms and Templates 1
L How to handle a Business Shutdown - Business Dissolution 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Plan & Procedure to handle a Product that's being Withdrawn from the Market 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Can you handle passivated parts without wearing gloves? Manufacturing and Related Processes 5
A How to handle the various Document Revisions Document Control Systems, Procedures, Forms and Templates 2
N How to handle Quality and Safety Deficiencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Client that refuses to help - How to handle ? Misc. Quality Assurance and Business Systems Related Topics 5
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B How to handle Medical Device Emergency Software Releases Software Quality Assurance 4
B How to handle/follow supervisor and department head with different supervisory style? Quality Manager and Management Related Issues 7
Z If this is a Nonconforming Product (Service) under clause 8.3? How do we handle it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Responsibility of Distributor for Customer Complaints - How should we handle this Customer Complaints 5
R How to Handle 'Scrap and Replace' of Non-Conforming Products Nonconformance and Corrective Action 9
B Upper Management makes changes to a report - How do I handle this? Six Sigma 12
J SOP for How to Handle an Investigation wanted Document Control Systems, Procedures, Forms and Templates 1
J AS9100 C - 7.5.1.3 - How do you handle Production Equipment Maintenance? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M How to handle the task of Organizing a Regulatory File Room Document Control Systems, Procedures, Forms and Templates 2
V ISO 26262 - How to handle OEM ASIL A (Automotive Software Integrity Requirements) Other ISO and International Standards and European Regulations 4
M How to handle Rejections of a Internal NCR event Nonconformance and Corrective Action 7
G Manufacturing Process Subcontracted - How do I handle Cl. 7.5? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
P How to handle Out of Tolerance during Calibrations and exceeded Alert Action Limits Quality Manager and Management Related Issues 4
M The importance of Document Control? How do you handle your Document Control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R How do you handle 'Contaminated Wood Pallets'? US Food and Drug Administration (FDA) 16
L Quality Objectives - How various device companies handle "Quality Objectives" ISO 13485:2016 - Medical Device Quality Management Systems 9
A How does your registrar handle 2 certificates, one for AS9100 and one for ISO9001? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Le Chiffre Great article on how to handle continuous improvement Quality Manager and Management Related Issues 3
