How to handle Out of Tolerance during Calibrations and exceeded Alert Action Limits
P
Phoebe
We have a system where deviations, discrepancies and nonconforming product are all routed to our CAPA system. How are others handling out of tolerance results and exceeded environmental monitoring results? Are they treated as a separate category or is the nonconformance expanded to include more than a nonconforming product per release specifications?:confused: We are ISO 9001 and ISO 13485.
Duke Okes
Re: How to handle Out of Tolerance during Calibrations and exceeded Alert Action Limi
That's your organization's decision, but putting them into the CAPA system makes sense to me. However, when you assess the risk you may decide that containment & remedial action are all that are required, rather than going after physical and system causes.
If you use the ISO 9000 definition of "nonconformity" which is "non-fulfillment of a requirement," you can fit anything you want into the CA category. Worry less about the box you put something into and more about the contents. Do what helps to prevent recurrence.
P
Phoebe
Would someone be willing to share a sample report for an OOT finding?
BradM
Hello Phoebe!!
OK, this is just me kind of talking about the processes and such. Duke and Jim have provided some excellent advice. So this is more food for thought more than anything.
1. Have your acceptance tolerances clearly defined up front, and in writing. So for example, say your adjusment criteria is 2, but the process tolerance which would impact the process is 4, then only initiate a CAPA (if that is your use) for what would impact the process. So, only involve others, when the error found could impact their process. Again, this should be identified up front.
2. If you have an out of tolerance that might affect the process, then enter that information with the CAPA. I would include the magnitude of error, and some previous history on the device. The calibration entity should provide the sufficient information surrounding the instance, so people can make better informed decisions.
Your CAPA should follow a general process:
CORRECTION: The unit was adjusted for maximum accuracy, replaced, taken out of service, sent to mfg. etc.
CORRECTIVE ACTION: Maybe replace the unit, investigate the calibration process to see where the error may have come from during calibration, etc. May be some training issues. Did you identify the cause for the failure? Do you have a solution for the cause?
PREVENTIVE ACTION: Whatever your organization deems to assure this does not happen again. A fair amount of time there is too tight of a tolerance somewhere, or it's a random event (assuming that the calibration process is stable and somewhat mature).
However you decide to assess these occurences (and yes, they will happen), have things identified up-front to minimize knee-jerk reactions and such (and should be a risk-based approach), and complete it; from start to finish. Too... If you find you are having failures on the same instruments, address your corrective/preventive actions, as they are most probably not sufficient.
Oh... :D try to avoid taking the easy paths- shortening calibration interval, sending to mfg. for service, or replacing the instrument. They have their place, but so many times are used as Band-aids for a problem, without figuring out what is really going on. :)
K Different Indications for Use in Different Countries -- how to handle IFU? Other Medical Device Regulations World-Wide 4
K How to handle GTINs for different configurations of one device with one part number? Other Medical Device Related Standards 0
I How to handle pending FSN when incident happens? EU Medical Device Regulations 1
Jimmy123 Process disturbances and the repair - How do you handle this risk in your company? FMEA and Control Plans 18
GoSpeedRacer How to handle operator involvement in the non conformance ISO 13485:2016 - Medical Device Quality Management Systems 5
A How to Handle Documented Information in an online database for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O How will you handle Clause 6.1 - Risks and Opportunities for AS9100 Rev. D Auditors? Risk Management Principles and Generic Guidelines 22
V Systems to Handle Development and Batch Analysis in same Laboratory Qualification and Validation (including 21 CFR Part 11) 3
dubrizo How do you handle damaged IM&TE in your organization? General Measurement Device and Calibration Topics 3
D MDD Classification of Bone Saw Handle ISO 13485:2016 - Medical Device Quality Management Systems 1
1 How to handle Nononformances in Clincal Manufacturing ? Nonconformance and Corrective Action 2
R How do we handle Training during transition and overlap from one system to other ? Training - Internal, External, Online and Distance Learning 4
Q How to handle different voltages for different countries Document Control Systems, Procedures, Forms and Templates 1
A How to handle complaints after end of specified medical device life-time ISO 13485:2016 - Medical Device Quality Management Systems 5
M How does Australia handle products that are EU PPE, but Australia Medical Devices? Other Medical Device Regulations World-Wide 7
C How to handle this Inspection conflict? Second Shift Inspector? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
T How to handle Demo Units during an ISO 9001 Audit General Auditing Discussions 3
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How to handle a blood stained GMP document ? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
T How to handle 510(K) submisison in 2014 when the Fees were paid in FY13 ? US Food and Drug Administration (FDA) 3
C How to handle Action Results in a new FMEA Review once we have a new RPN? FMEA and Control Plans 1
Mikishots How to handle CAR (Corrective Action Request) Scope vs. Timely Response Nonconformance and Corrective Action 9
J Quality Procedure to handle some standard Medical Device Processes Document Control Systems, Procedures, Forms and Templates 1
L How to handle a Business Shutdown - Business Dissolution 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Plan & Procedure to handle a Product that's being Withdrawn from the Market 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Can you handle passivated parts without wearing gloves? Manufacturing and Related Processes 5
A How to handle the various Document Revisions Document Control Systems, Procedures, Forms and Templates 2
N How to handle Quality and Safety Deficiencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Client that refuses to help - How to handle ? Misc. Quality Assurance and Business Systems Related Topics 5
C How to handle Outsourcing with Same Site - Separate Cert ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B How to handle Medical Device Emergency Software Releases Software Quality Assurance 4
B How to handle/follow supervisor and department head with different supervisory style? Quality Manager and Management Related Issues 7
Z If this is a Nonconforming Product (Service) under clause 8.3? How do we handle it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Responsibility of Distributor for Customer Complaints - How should we handle this Customer Complaints 5
R How to Handle 'Scrap and Replace' of Non-Conforming Products Nonconformance and Corrective Action 9
B Upper Management makes changes to a report - How do I handle this? Six Sigma 12
J SOP for How to Handle an Investigation wanted Document Control Systems, Procedures, Forms and Templates 1
J AS9100 C - 7.5.1.3 - How do you handle Production Equipment Maintenance? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J Seeking advice on how to handle a Special Process Nonconformance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
M How to handle the task of Organizing a Regulatory File Room Document Control Systems, Procedures, Forms and Templates 2
V ISO 26262 - How to handle OEM ASIL A (Automotive Software Integrity Requirements) Other ISO and International Standards and European Regulations 4
M How to handle Rejections of a Internal NCR event Nonconformance and Corrective Action 7
G Manufacturing Process Subcontracted - How do I handle Cl. 7.5? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M The importance of Document Control? How do you handle your Document Control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R How do you handle 'Contaminated Wood Pallets'? US Food and Drug Administration (FDA) 16
L Quality Objectives - How various device companies handle "Quality Objectives" ISO 13485:2016 - Medical Device Quality Management Systems 9
A How does your registrar handle 2 certificates, one for AS9100 and one for ISO9001? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 18
Le Chiffre Great article on how to handle continuous improvement Quality Manager and Management Related Issues 3
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
