Re: Backup QC conflict??
I understand your concerns. It sounds like your culture developed with the two functions as separate. But I have seen it work with operators being responsible for their own inspection when the culture is right. However, you said one person would be used, "As needed." Are we talking once a shift, once a week or once a month? Training is key. Not just the physical aspects but making sure they grasp the seriousness of OK'ing a job to run. As you make the switch I would trust but verify. You need to feel confident the system is working. Then you can relax a bit. Also, I would make sure that internal audits include the night shift. After all, we often like to say that a goal of the well run QMS is getting rid of the need for a inspection department at all.
As already state, much of what will work depends on your organizational culture. Surely you can't violate your own internal procedures and as things grow and change, these may need updated.
If the upper management want someone other than the operators to do this inspection, and management holds the supervisor responsible, then as long as it is allowed by your procedures and they have been properly trained, then there is no reason this would not work.
If you do implement this, I would make sure you have a mechanism to track the effectiveness of this 2nd shift inspection function. If you start to see rejections, failures or complaints on product that should have been detected by this shift, then you will be able to demonstrate to management that this approach has failed.
Remember the objective of inspection... "to detect and prevent nonconforming product from being shipped or used by subsequent operations"...
If there are reasons such as culture, training or time that does not give you the confidence in this inspection function you desire, then why not just hold all product ran on that shift until release by your normal first shift inspection function. If the product ran on that shift has to be shipped asap, then you could have 2nd shift do the inspection, document the results but also have them retain the samples they pulled and checked. Then you could have your first shift inspection function either audit the documentation or even inspect some of these parts. You may not need to check all of the samples pulled, but just do a random sample from what they already checked. If you are taking actual measurements or readings, I would collect that data on a data sheet or better yet a chart and when you perform your secondary inspection audit, you should see that the re-inspection results match what they were on 2nd shift.
Then, if you see differences in the measurements, you can either address it as a training issue or a measurement systems issue...
Don't over think this and re-state your objectives. If you can meet these objectives and have a method to track the effectiveness of this 2nd shift inspection function, then you should be able to comply with your own internal procedures but also meet your customers requirements.
You may even want to re-think your internal procedures if they are creating non-value added restrictions. I find that many times our procedures or work instructions are several years old or maybe even a decade old and if you re-state what your goal or objective is for this procedure... you may find that your world has changed. Maybe your current customers really don't care about the systems you developed under QS9000 or the systems forced on you by customer X, that is not your biggest customer any more, but consider asking yourself what is my real objective. What is the value of this procedure or what is the value of this inspection or even, "What is the failure modes and the potential effects if I don't do this inspection?"...
Good Luck...
thenson (email me at "
[email protected]" if I can help...
