Dear Mr BradM,
I was explaining SPC concepts to one of the fresher to my org. During discussion this question came. I know that through Minitab we can check whether data is normal or not . If we dont have Minitab then how to find out ?? In our factory our Mfg process incudes Stamping, Painting, Assembly so I want to know how much data needed because each process output rate varies.
Superb posts from Steve and Stijloor (as usual). Forgive me if I keep coming back to the same issue, but why limit how much data you will obtain? Is it cost prohibitive?
If you only collect 15 data points, you will need to be concerned with normality. If you collect 1500 data points, normality will virtually be a given. This is why it's important to try to figure out how much data you're looking at, and whether normality is an issue. Also, depending on how many variables per sample you are trying to assess, the power of your inferences may become very low if you don't have enough data.
As mentioned by the others, even though your post specifically said you wanted to keep away from a software package for a decision, most decent software packages have statistical tools to estimate normality.
Here is a link on a thread where we had a good discussion on non-parametric statistics, if you're interested:
Non-Parametric statistics
