How to include machine error in uncertainty calculations?
greif
How do I state machine error in my uncertainty statement?
I have calculated uncertainty (using repeatability,temperature, user repeat, and the uncertainty of the cal standards used to calibrate the instrument).
In the 100%R to 23%R range, 451 to 700nm, the k=2 uncertainty is 0.52%
Then I read the cal standards on the instrument several times and note there is an error of around 1.5 % worst case in the 451nm to 700 nm range.
Right now (on a calibration certificate) I state the k=2 uncertainty is 0.52% with +1.5/-0.0 %R residual error.
The measurement device is a reflection spectrophotometer which reads out %R every 10nm from 400nm to 700nm.
If it makes any difference, this will eventually be in a 17025 system with ANAB accreditation.
Question: Is this a proper way to state this uncertainty and residual error?
or do I need to include the error in my uncertainty (what is the proper way to do that in this case?)
Note: eventually I hope to get a handle on the error and subtract it out if possible.
Thanks to all, this forum is a great help!
dwperron
"Right now (on a calibration certificate) I state the k=2 uncertainty is 0.52% with +1.5/-0.0 %R residual error."
It took a while for me to figure out what bothered me about this (old age creeping in).
You are claiming a "residual error" that is 3 times your measurement uncertainty.
That sounds like a problem, either with your equipment or with your process.
Normally you would combine all of the significant contributing factors in determining your measurement uncertainty. Why aren't you doing that, since both terms are stated in "%R"? ILAC says that "uncertainty arising from correction of the measurement results for systematic effects". That sounds like your "Residual error", it is a factor to be taken into account when stating measurement uncertainty.
greif
Yes, the equipment is more repeatable than it is accurate. Not too unusual for photometric measurements.
I see that normally known error is corrected for, so it is not included in uncertainty. I can't do this at this point (until we change the way reports are done). I can't see including the known error into the uncertainty calc., since at k=2 it ends up double.
Is just adding the known error to the calculated uncertainty kosher?
dwperron
I'm afraid that I wasn't clear on this.
I meant that you need to include the uncertainty of your "known error" that you are correcting for.
greif
I hadn't thought of that one!
So something like this?
Uncertainty calc based on the usual things (ref std, thermal, repeatability, etc.) and uncertainty of the measurement of error to make the k=2 uncertainty, then add the measurement bias (my machine error) to that.
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
H Does internal ppm include defects produced while adjusting the machine? Records and Data - Quality, Legal and Other Evidence 22
M Article 22 - Include statement in procedure pack? EU Medical Device Regulations 1
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
G What does performance specification include? US Food and Drug Administration (FDA) 1
K What to include in SOP Definitions section Document Control Systems, Procedures, Forms and Templates 3
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
G Any good examples of CAPA forms that include a risk based approach? ISO 13485:2016 - Medical Device Quality Management Systems 8
A EN ISO 14971:2019 does not include the Annex Zs ISO 14971 - Medical Device Risk Management 4
R Do Medical Device Complaints include Clinical Trials? Medical Device and FDA Regulations and Standards News 3
S 510k: What to include if your own device is the predicate US Food and Drug Administration (FDA) 5
B Include cost of quality (and other wastes) in an ISO 9001 system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
B Does EN ISO 15223-1:2016 include the graphic symbols to be added to software and IFU? Other Medical Device Related Standards 9
M Technical File (STED) labelling - When you compile tech files do we have to include all the product labels? EU Medical Device Regulations 2
B MDSAP for OEM products in Canada for in vitro diagnostic test kit to include lancing device Other Medical Device Related Standards 0
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Calibration laboratory scope - Include software such as Gagetrak or Mini tab used? General Measurement Device and Calibration Topics 3
M Include IFU in Class II Medical Device Marketing Brochure? US Food and Drug Administration (FDA) 2
Q MDSAP Regions and how to include in procedures Other Medical Device Related Standards 2
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
B Quality Policy does not include a commitment to comply with legal requirements Quality Management System (QMS) Manuals 5
K Does ISO 13485:2016 - 7.2.3 Customer Communication include Marketing? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Does nonconforming product include reagents/disposables? ISO 13485:2016 - Medical Device Quality Management Systems 1
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
Q To include Context and Interested Parties in Process Map? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Does CE Marking include compliance to WEEE and packaging waste? CE Marking (Conformité Européene) / CB Scheme 4
T Does nonconforming product disposition include parts bought from the supplier? IATF 16949 - Automotive Quality Systems Standard 15
shimonv Does 510(k) submission need to include UDI Data Other US Medical Device Regulations 6
Q Where to include other types of Nonconformities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Paul Simpson Does Knowledge Management include aspects of Information Security? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J How to understand the word "include" in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
Crimpshrine13 IATF 16949 Audits to include Processes and Products from Non Subscribing Customers IATF 16949 - Automotive Quality Systems Standard 20
E Updating DHF (Design History File) to include Alternative Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Include homogeneity uncertainty into budget table for thermocouples Measurement Uncertainty (MU) 1
J What does "other relevant management roles" include? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
M Changing FMEA template to include Detection Ranking for the PFMEA FMEA and Control Plans 2
WEAVER Gage R&R Sample Selection - Can we include NG Samples? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
V ICH Q3 - To "Include OR Not to Include" impurities below reporting threshold General Measurement Device and Calibration Topics 2
P What to include in a Clinical Evaluation Plan EU Medical Device Regulations 2
D Include non-automotive in TS16949 Registration Scope IATF 16949 - Automotive Quality Systems Standard 1
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B COA (Certificate of Analysis) - What information should they include? ISO 13485:2016 - Medical Device Quality Management Systems 2
H What does the PEM-gate review include? Manufacturing and Related Processes 3
P What should a Quality Plan Include and Examples Misc. Quality Assurance and Business Systems Related Topics 3
C Document Control - Details to include on Documents Document Control Systems, Procedures, Forms and Templates 2
