How to Inspect the Weld Strength of High Pressure Vessel & Oil Pipe Line
rohitmishra051286
please tell me about these welding test:-
1. CSWIP 3.1
2. PCN - RT
AND / OR
3. PCN - UT
4. BOSIET
Darrell B
RT would be Radio-graphic Testing, and UT would be Ultrasonic Testing.
I don't recognize the other acronyms offhand. Your local NDT house could probably assist.
A simple google search shows me that CSWIP is a personal welding certification body in the UK. Since I am an AWS-CWI, that may explain why the acronyms are foreign to me.
N Does 13485 auditor have a right to inspect non-CE products? ISO 13485:2016 - Medical Device Quality Management Systems 5
B Will FDA Inspect a New Coating Supplier for a Class III Combination Medical Device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A What to expect if FDA wants to inspect a Class 1 Medical Device Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 1
K Would ANVISA (Brazil) inspect our new manufacturing site? Other Medical Device Regulations World-Wide 12
W Gage R&R for gage pins used to inspect a hole ID called a Statistical Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C What's the sampling plan I need to inspect for each lot? AQL - Acceptable Quality Level 7
N Symbol for Medical Device Sterile Packaging - "Inspect Seal Before Opening" Other Medical Device Related Standards 5
S Plastic Translucency Inspection - How to inspect plastic for 85% translucency? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Building a Dimensional Metrology Laboratory to Inspect various Physical Measurements General Measurement Device and Calibration Topics 2
V DIS Inspect software for our CMM Operations - Seeking Contact Information Calibration and Metrology Software and Hardware 3
A Is it mandatory to have a profilometer to inspect >16 surface finish? General Measurement Device and Calibration Topics 8
O NET-INSPECT is it worth it? Small Machine Shop doing AS9100 Quality Manager and Management Related Issues 8
Q How to Inspect for ESD (Electro-Static Discharge) Damage Manufacturing and Related Processes 5
1 What is the best way to Inspect a Wiring Harness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
R Thread Inspection - Using go/no-go gaging to inspect threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D How to inspect maximum allowable contaminate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Capability of CMM's - The minimum tolerance in microns a CMM can inspect Capability, Accuracy and Stability - Processes, Machines, etc. 4
H Definition Inspect, Review, Verify and Witness - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
B How to inspect Mylars to verify dimensions, grid lines and grid points Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
B Customer Property - The best way to inspect MLO and what acceptance criteria AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
F How to inspect the 5 different dimensions using an optical comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
C Information on GD&T Symbols, what they mean, and how to inspect features Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
S How often does the FDA inspect organisations outside of the USA? US Food and Drug Administration (FDA) 12
S A Better Way to Inspect Timed Threads Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
F Number of Parts to Inspect for 95% confidence in meeting 1.33 Cpk Statistical Analysis Tools, Techniques and SPC 4
O Site Audit Process - Team to inspect GSM (Global Services of Mobility) sites General Auditing Discussions 5
B Incoming Metal Coil Inspections - How many do you inspect? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Z Gage R&R for sorting gage - Leaktester to inspect for leakrates on parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
M Weld Symbol--Bubble Drawings for FAI Document Control Systems, Procedures, Forms and Templates 4
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H FCA projection weld nut IATF 16949 - Automotive Quality Systems Standard 0
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
E European Weld Callouts - Confused with the "/C" and the "a2" portions Various Other Specifications, Standards, and related Requirements 7
B Weld Validation on Titanium Parts ISO 13485:2016 - Medical Device Quality Management Systems 1
V Tolerance achievable for Sheet Metal Part with some weld - 0.4mm TP Manufacturing and Related Processes 5
V Rust and Paint adhesion with new Weld Nut Supplier Manufacturing and Related Processes 5
F Welder Recertification to AWS 17.1 Groove Weld AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
Fender1 Controlling Documents and Records in a Custom Weld/Fabrication Company Document Control Systems, Procedures, Forms and Templates 10
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
J Weld Current Monitor Calibration Laboratory in North America General Measurement Device and Calibration Topics 6
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
L AWS Certified Weld Inspector (CWI) Requirement Question Manufacturing and Related Processes 16
K Inspecting a Length of Weld - High Reject Rates Manufacturing and Related Processes 7
hogheavenfarm Does anyone know of a calibrated Fillet weld gage? General Measurement Device and Calibration Topics 12
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
