How to Integrate ISO 17025 with current QMS
Hershal
Metrologist-Auditor
#21
Hello all! I have some questions on the beginning phase of ISO 17025.
Our calibration lab is under a mature QMS (ISO9001- 10+ years; regulated industry; 1000-4000 employees). For discussion, I will specify the current, comprehensive sytem as the "large" system, and the calibration activities program as the "small" system.
As we sit, my assessment is we have a good program (small and large). There is interest, for various reasons, to fall under the 17025.
For the most part, most of the components specified is 17025 are encompassed within the larger system. We already have procedures in place to handle:
Purchasing
Calibration records
Management/ management review
Nonconforming product
Corrective action program
Document control....
Among others
There does not appear on the surface to be any reason why these would be deficient within the "small" system.
NOTE: There are a few I have identified that need addressing.
Currently (and in the foreseeable future) there will only be internal customers.
So, am I hearing that in the end, it will be better to create a new quality system within the system? So, do I "pretend" that the larger umbrella system does not exist, and create from scratch?
Too, I cannot imagine that the quality professionals responsible for the large system would be completely OK with creating a small system independent of the large. That is my thought; but nothing verified on that one.
Your thoughts, input, and opinions are welcome.:)
Brad,
First, if you have a copy of ANS/ISO/IEC 17025:2005, great, if not, first thing is to purchase it, likely the best price is from NCSLI http://www.ncsli.org
Now, pick it apart word by word and line by line, write everything down that is a requirement. For example, Management Review has a prescriptive agenda that you must be aware of, including topics that may not be a requirement under ISO 9001.....purchasing, watch criticals; sub-contracting (if any) watch how you qualify organizations; Clause 5.9.1 requires special attention and for it also obtain APLAC PT 001 and PT002, both are free at http://www.aplac.org and similar specific requirements are throughout the Standard.....
Now, go through your already-documented QMS word by word and line by line.....WHERE everything matches up, use the parent system.....where you can't absolutely put a peg in the sand that there is a match, then document.....
GET TRAINING!!!!!!! Training in ISO/IEC 17025 and in Measurement Uncertainty.....there are a number of courses available.....
Do your uncertainty, a requirement for traceability of calibration and a great early warning system for problems in the technical arena.....
It is unlikely that you will seek accreditation, but if you do remember there are FIVE accrediting bodies (ABs) in the U.S., and do NOT choose one till you have quotes from all five and have spoken to all five, and called a good sample of their customers.....
Hope this helps.
Hershal
Hershal
Metrologist-Auditor
#22
2. Uncertainty calculations
I would like to see if it is feasible to go with what we currently have for the technical portion. We have established at least 4 to 1 accuracy ratios for our standards. We have a few less than 4 to 1, as the current technology limits the possible standards. This is the fundamental comparison of the tolerance of our standard, compared to the tolerance of the U.U.T.
We have not performed extensive uncertainty calculations. This is due to two components- 1) Assuring proper accuracy ratios has been deemed sufficient; 2) we have somewhere between 75-175 standards.:tg: Of course, these (accuracies) are documented in several places within the system. I do need to get these into one document.
As for the 4:1, first, to be absolutely clear, it is allowed and at times even directed under the now-retired American National Standard ANSI/NCSL Z540-1-1994 and also allowed under the current ANSI/NCSL Z540.3-2006.....key is, you must be able to prove it, so you still have to do uncertainty studies.....
Hershal
Metrologist-Auditor
#23
It was explained to be that most accreditors will cite for using a non-accredited lab, then the customer “appeals” through the Corrective Action for the nonconformance. Why would I want (and why would you want a system) to enter with a known problem? I agree it should be highly preferred, but seems a bit aggressive to mandate it. Your thoughts…
According to the Standard, simply because a supporting lab is not accredited, that is not worthy - in and of itself - of a corrective action, because the Standard does in fact provide some leeway.....however, there must then be sufficient documentation to prove the ACTUAL requirements of the Standard which are: traceability, competence, and measurement capability, according to Clause 5.6.2.1.1 which addresses traceability.....
Side note, the IAS policies are available at no cost on their website, as are the policies for A2LA, L-A-B, ACLASS, and NVLAP on their resepctive websites.
Hope this helps.
BradM
#24
Thanks, Cliff. Excellent as usual.
The audit report includes all audit activity, including follow up, presumably by the auditor. The auditor can explain how he cleared the NC
But that's my point. Generally an auditory cites the clause and evidence of non-conformity. The correction/corrective/preventive action usually is the domain of the auditee, not the auditor. Some things may be easy fixes while they are there; some will take a while.
S Can we integrate both ISO 9001:2015 and API Q1 Management System Standards Quality Management System (QMS) Manuals 11
S ISO 13485:2016 - How I can integrate a risk management approach in our SOPs ISO 13485:2016 - Medical Device Quality Management Systems 1
D How to integrate SQF with ISO 9001:2008 Food Safety - ISO 22000, HACCP (21 CFR 120) 5
H How to integrate ISO/TS 16949 & ISO9001 Quality Systems - Plastic Injection Mold IATF 16949 - Automotive Quality Systems Standard 7
E System Integration - How to integrate ISO 14064 and ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F How to Integrate Audits and Audits Schedule - ISO 9001 and OHSAS 18001 Occupational Health & Safety Management Standards 2
H How to integrate ISO 9001:2000 with ISO 22000 (Food Safety Management System)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S I'm looking for handbook to integrate ISO 9001, ISO 14001 and Ohsas 18k Book, Video, Blog and Web Site Reviews and Recommendations 4
A Integrate our system with ISO 9000:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Shop Drawings that Integrate Information from a Database Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M To Integrate or not to Integrate (ISO9001, ISO14001 & OHSAS18001) Miscellaneous Environmental Standards and EMS Related Discussions 2
P An IMS organization can integrate CMMI with IMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Program which will Integrate all of our PPAP forms Document Control Systems, Procedures, Forms and Templates 5
G The most effective way to integrate CMDCAS requirements into Quality Manual ISO 13485:2016 - Medical Device Quality Management Systems 4
H How to Integrate System Audit, Manufacture Process Audit and Product Audit Process Audits and Layered Process Audits 5
Q What if I want to integrate Policy of QMS, EMS and OHS-MS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D What are the master steps to integrate Iso9001 in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
A ISO/DIS 15223-1:2020 - Country of manufacture label (IEC 60417 No. 6049) - Which national law requires this symbol? Other Medical Device Related Standards 0
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
K PDCA cycle and ISO processes alternative model Quality Management System (QMS) Manuals 14
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 13485 & CE Certification for Surgical Gloves CE Marking (Conformité Européene) / CB Scheme 0
S ISO 11137- Simulated product vs SIP Other Medical Device Related Standards 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
V ISO 10360-5: 2020 Gap analysis and Action plan Excel .xls Spreadsheet Templates and Tools 1
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Inventory Listing and ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 45001 6.1.2.1 Hazard Identification Occupational Health & Safety Management Standards 1
