How to keep old versions of work instructions from being used at point of use?
Renea Koski QSM
As long as I have been a Quality Manager (8 years,) document control has been a thorn in my side!
I was wondering what some of you do to control printed work instructions at point of use that are outdated.
My idea was to have only access to our server with all the work instructions available, but some of the work stations do not have access to a computer.
What is the best way to ensure that printed documents of work instructions are kept up to date? I cannot stand at each work station to ensure that are making sure they are using the most recent version and the managers cannot track every employee either.
If I add a statement that this document is only good for 30 days past printing, then I am setting myself up for a non-conformance if that document is still sitting there past 30 days. . .
I did add a statement that "All printed documents are considered uncontrolled and for reference only" but the auditor said that work instructions cannot be for reference only.
I was just wondering if you all had any great ideas you could share. I am at a loss!
Tidge
A footer that says something like "Uncontrolled Document When Printed" should be ok... provided you have some mechanism for the control of "non-printed" copies. (The same issue will crop up if local electronic copies are stored).
How much control are you willing to exert? For production processes, it is not unreasonable to require a recording of work instructions (and revisions) used during manufacture, at the point of use... I'm not referring to attaching a printed copy of a BOM, I'm thinking of requiring an actual recording the WI number and revision used in the DHR/traveler. (and having a review of the record)
Renea Koski QSM
That is a great idea, but logistically, I am not sure how to get the WI on the traveler without it being manually done. Our document control systems and ERP are 2 separate softwares and I can hardly get them to record their initials on the DHR let alone add more for them to do. . . .
But I will look into it.
(BTW, the BOM is printed on the WO/DHR/Traveler at each processing step.)
Thank you.
John C. Abnet
Teacher, sensei, kennari
Good day @Renea Koski QSM ;
Regrettably, your situation is not new...nor is there any "silver bullet" to bring resolution. Let's consider the goals...
1- Ensure only CURRENT information is available.
2- Ensure information IS readily available at the point or work/where needed.
In my experience, a computer terminal is an inexpensive 'best' solution. A terminal with EASY and INTUITUIVE access (i.e. maybe a single folder icon on an otherwise blank screen, which provides direct access to only the information needed {a method I've used in the past) )...
to the information that users need can be a big asset in achieving your goals.
Not sure what your organization's size nor "work station" configuration allows, but if/as practicable, the terminal solution I describe may be your best option.
Hope this helps.
Renea Koski QSM
Hope this helps.
Thank you! That is what I thought, but just seeing if there was something that I just could not think of out there!
Sidney Vianna
Post Responsibly
First and foremost, educating the workforce about the risks of using inadequate revisions of documents. Normally, if you can use some examples of real-world (hopefully recent) cases of nonconforming products due to wrong revisions, the employees can relate to the concerns and understand the potential issues. Keeping printed copies of these WI's in drawers or posted on walls are always a potential risk. Having focused internal audits at a high frequency on this specific issue should help in bringing awareness to the shop floor workers.
From a technical standpoint you can limit the availability of printed WI's to a single central location on the shop floor (assuming a small to medium size plant) and the updating would be easier to a single point of distribution. Each work environment is unique, but, in my experience, most workers don't need the WI's to perform work. Most of the time, only new employees use them and, after some time, the knowledge contained in the WI is memorized. Obviously, each scenario is different; so, this solution would depend on the complexity of the work being performed.
Good luck.
As stated it’s an age old Problem. My take is a bit different: the standards (rightly) say that we must prevent use of outdated instructions. Now having copies available somewhere (either hard copies or local electronic copies) is ‘troublesome’ because they could be used, it doesn’t mean they are being used. Unfortunately objective evidence is usually taken as the (easy) detection or observance of a document. But just like a signature on a document doesn’t prove that the person signing it actually did what they say they did, the mere existance of an outdated document is taken a proof that it old have been used. Add to this the number of revisions that are for administrative purposes that don’t change the actual instructions and you have quite the dilemma. I’ve never seen an auditor discover that the ‘old way’ was used; they just find that an outdated document and thi evidence that it could have been used. Changing this approach will probably never happen so we are stuck chasing outdated documents.
I would add that talking with the employees about the importance of following only current instructions and having only current copies available and most importantly asking why they have outdated copies around is critical to improving the situation…
Another thing to consider is error proofing your processes as much as possible so the wrong thing can’t be done.
Renea Koski QSM
From a technical standpoint you can limit the availability of printed WI's to a single central location (assuming a small to medium size plant) and the updating would be easier to a single point of distribution. Each work environment is unique, but, in my experience, most workers don't need the WI's to perform work. Most of the time, only new employees use them and, after some time, the knowledge contained in the WI is memorized. Obviously, each scenario is different; so, this solution would depend on the complexity of the work being performed.
Good luck.
Thank you!
Renea Koski QSM
I would add that talking with the employees about the importance of following only current instructions and having only current copies available and most importantly asking why they have outdated copies around is critical improving the situation…
Amother thing to consider is error proofing your processes as much as possible so the wrong thing can’t be done.
Thank you!
Thank you.
I work in a system where all production cells work from paper documents. While it should fall to the Production Manager and Supervisors to ensure their people use the correct documents, it does not. Long before I came here, the Quality Manager (two before me) assumed that responsibility, as he was the one both writing and revising the Work Instructions, as well as controlling all drawings. So, part of that revision process is to print the newest revision, and replace the old revision, which is then destroyed (unless it's so old that there is no electronic copy, in which case it's scanned and then destroyed).
Checking the revision levels of documentation is also a part of our regular WIP Quality inspections.
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
Antonio Vieira Do you still keep old numbers of Quality Progress in paper format? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 9
Z How to keep up with changes on applicable technical standards (EU MDR)? EU Medical Device Regulations 6
H Does ISO state in anyway that we MUST keep physical first piece parts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Awareness of Guidance and Policies - how do you keep track? Canada Medical Device Regulations 2
J How to keep MDD certificate valid when legal manufacturer has liquidity problem EU Medical Device Regulations 0
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 7
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
R How to keep track of employee read-only training ISO 13485:2016 - Medical Device Quality Management Systems 14
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
Ed Panek Ideas to keep quotes for consulting service accurate on not inflated Consultants and Consulting 11
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
J ISO 15223-1: Keep dry vs. humidity limitation label symbol Other Medical Device Related Standards 2
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Where to keep Enterprise Resource Planning software (ERP) Validation Records ISO 13485:2016 - Medical Device Quality Management Systems 1
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
Q Is Handwritten Raw Data required to keep with Electronic Records? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
E Design Dossier/DHF Updates - What to Keep EU Medical Device Regulations 2
L Product Safety Officer - How to keep VW Happy VDA Standards - Germany's Automotive Standards 24
T How to keep Customer Engineering Specifications & CSRs Up to Date IATF 16949 - Automotive Quality Systems Standard 6
AnaMariaVR2 FDA to keep closer eye on diagnostics: FDA chief US Food and Drug Administration (FDA) 0
AnaMariaVR2 How to Keep the Fizz in Your Biz The Reading Room 0
H Best place to keep myself updated on EU Regulatory Changes EU Medical Device Regulations 7
T What Can Be Done to Keep Operations Trainers Busy? Training - Internal, External, Online and Distance Learning 3
V Device Retains - How many people keep retains of finished devices and why? US Food and Drug Administration (FDA) 6
Q Material Changes - To keep questions and answers as records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J SR-001 Revision - Keep watching for the new revision of SR001 (It is expected soon) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Controlling QMS - We are expanding globally and want to keep our QMS Confidential Quality Manager and Management Related Issues 20
A Do you keep up your CCT (Certified Calibration Technician) Certification? General Measurement Device and Calibration Topics 3
P Self Motivation - How to keep it when overwhelmed with problems? Career and Occupation Discussions 13
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
K How you keep yourself motivated in tough times? Career and Occupation Discussions 15
T From Manufacturer to Distributor - Still keep ISO 9001:2008 Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Documents required to display/keep during ISO 9000 Audit in EPCC firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
M Dbase or Excel file to keep track on our internal failures (Non conform products) Document Control Systems, Procedures, Forms and Templates 8
Q How should I Keep my various types of records .. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
D Training Records - Requirement to keep original copy of training/assessment form? Records and Data - Quality, Legal and Other Evidence 12
R How long do I keep expired Calibration Certificates General Measurement Device and Calibration Topics 8
Marc Flying will be a real pain now - New rules keep passengers in seats Travel - Hotels, Motels, Planes and Trains 7
S Revisions in ISO 9001 QMS Documents - Where to keep the record of revisions? Document Control Systems, Procedures, Forms and Templates 7
P New Year Goals and Resolutions - Did you keep your goals and resolutions in 2009? Coffee Break and Water Cooler Discussions 5
C Do you keep ISO 9001 when going AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
