How to keep track of employee read-only training
racglobal
Hi everyone,
I work for a startup company with very few people (under 12). What is the best way to keep track of read-only training by employees? We have group-training whereby the applicable employees sign a group training sheet with the trainer evaluating effectiveness of training signing off at the end to confirm effectiveness. This is normally done on a piece of paper (a hard copy). What about for online read-only training? Where evaluation of effectiveness is self-assessment (for those employees who only need to be aware of the SOP because their work does not require them to apply the process). What program can we use to keep track of people's read-only training? For each employee, I would like to print out a record with their training on each SOP that they received for read-only training. Is there a simple online program that I can use for this purpose?
John Broomfield
Your read only training could end with a quiz to verify understanding. One of the benefits of doing this online with an LMS is that your software keeps the record. So, invest in a so-called Learning Management System.
If you are not verifying understanding are you just going through the motions and undermining the importance of the management system in the minds of your employees?
As always the bottom line is employee awareness and competence for which you’ll have separate controls such as supervision, monitoring, recording, analysis or evaluation and acting on the results.
Marc
I fully agree. I used to do a lot of training and every course had an "exam" at the end to show evidence that each attendee understood the material. In addition, auditing and internal auditing courses included a day of monitored auditing in their facility.
Watchcat
Hi everyone,
Do all employees have to be aware of all SOPs? If not, what criteria are used to determine whether an employee needs to be aware of an SOP, even though their work does not require them to apply the process?
Marc
No. Every employee needs to know what documents affect them. What document(s) affect each employee are determined by the job description and related aspects.
Watchcat
Marc, agreed. What I'm trying to understand is, if an employee's job doesn't include applying the process in the SOP, in what way might the SOP affect them, that they would still need to be trained on it? Or at least "be aware of" it?
Marc
Example: Train engineer has an SOP which instructs him/her to notify the conductor if the train engineer believes there is a problem developing with the engine so that the conductor can notify the passengers that the train might arrive late at the destination (one of, or part of one of the conductor's SOP(s)). The engineer's SOP applies to the engineer as it is part of his/her job tasks/responsibilities. The engineer's SOP, in part, has to be known/understood by the conductor (it affects the conductor in that it triggers one of the actions in a conductor SOP {IF engineer tells conductor engine trouble, THEN conductor shall notify passengers and...} ) yet the conductor him/herself doesn't actually do anything in the engineer's SOP. In that way at least part of one of the engineer's SOP(s) affects the conductor.
This is essentially part of what is known as the Interaction Of Processes.
E.g.: Process Mapping - Process Flow and Interactions of Processes - ISO 9001
Process Interaction Chart example as required by ISO 13485 2003
How do I show the Interaction of Processes in the Quality Manual referring to 4.1(b)?
Interaction of Processes for both ISO 9001 & ISO 14001 Combined
This long predates ISO 9001:2000, but the 2000 version made a big deal out of it as if it was something new. While the date on the slides is 2004 (the date it was rendered/printed), I actually wrote it around 1998 or earlier: The Organization as a System, Subsystems, and Processes - It is relatively basic, admittedly. It was part of a course I gave, as primitive as it was 20 years ago, so a lot of explanations were in the discussion.
racglobal
Hi Watchcat
Here is my experience at a very small startup company. Training should also be risk-based. We have two tiers of training in this company, the first level of training is attending a classroom session where the trainer explains the requirements of the SOP/QMS process and have them take an evaluation (quizzes, tests, or Q&A session). The second level is read-only training for those who are not directly involved in the QMS process, they would only need to have read-only training to be aware of the SOP. For example, while the Management Responsibility SOP doesn't directly involve the production employee, being in a small company of 10 people, they would still need to be aware of their responsibility to be in charge of their own area of the QMS and any corrective actions should be reported to management for purpose of management review. In this sense, while they are not directly involved in management responsibility and hence do not have to be tested, it makes sense for them to be aware of this. After all, the standard calls for risk-based thinking. At my previous company, everyone from CEO down to the maintenance worker had to take a quiz on design control, which didn't make sense to me if the maintenance person was never gonna be involved in design reviews. Nor does read-only training apply to them either.
If anyone else has thoughts, I would like to hear them.
Watchcat
Sorry we are drifting so far from your "simple" question, but I think this is a good discussion, so I'm going to persevere.
I think Marc's example is how it should be. I think small device startups tend to be textbook examples of the opposite. Risk-based, yes, I think that's the way to go, and also 'bout the best you can hope for. The problem is, even risk-based requires resources, to assess the risks and then apply the results.
I was thinking they might be overtraining on the one hand (everyone gets "trained" on every SOP) and undertraining on the other, by not documenting the limited amount of training that some employees need ("aware of"). I think the former approach is often adopted as an alternative to investing the effort needed for a risk-based approach (or a process-mapping approach).
As for your original question, if your goal is to be able to print out training records for individual employees, would you plan to incorporate the group training that is currently documented on paper into the electronic system? Or would each employee's training record have two different types of records...paper records (perhaps scanned) for group training and electronic for each individual's online reading?
D What are the important things to keep track of in product audit checklist? Software Quality Assurance 3
R How to keep track of all FDA rules and regulations for medical device companies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M Dbase or Excel file to keep track on our internal failures (Non conform products) Document Control Systems, Procedures, Forms and Templates 8
Ajit Basrur How do you keep track of various passwords ? Coffee Break and Water Cooler Discussions 24
C APQP Meeting Agenda - Need Example and How to keep the meetings focused & on track APQP and PPAP 7
T Supplier Quality Software to help me keep track of molds, tool and dies at suppliers Supplier Quality Assurance and other Supplier Issues 10
CarolX Deleted (Obsoleted) Procedures - How do I track? Should I keep a copy? Document Control Systems, Procedures, Forms and Templates 7
J How to keep MDD certificate valid when legal manufacturer has liquidity problem EU Medical Device Regulations 0
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
lanley liao How to keep the manufacturing capability under the API monogram Oil and Gas Industry Standards and Regulations 6
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
P Images of Product for Automated Process - How long to keep? US Food and Drug Administration (FDA) 2
J Organization merger. Should we keep two separate ISO 13485 certificates? ISO 13485:2016 - Medical Device Quality Management Systems 6
D How long should we keep the spare parts available for our medical device, after we have stopped the production? ISO 13485:2016 - Medical Device Quality Management Systems 0
Ed Panek Ideas to keep quotes for consulting service accurate on not inflated Consultants and Consulting 11
CPhelan Internal audit - Combine similar nonconformities in one or keep separate? Internal Auditing 6
Sidney Vianna Interesting Discussion How major corporations in the West keep failing to uphold their pledges of abolishing child labor in their cocoa supply chains Sustainability, Green Initiatives and Ecology 3
J ISO 15223-1: Keep dry vs. humidity limitation label symbol Other Medical Device Related Standards 2
S Where to keep Enterprise Resource Planning software (ERP) Validation Records ISO 13485:2016 - Medical Device Quality Management Systems 1
C ISO 14001 vs Existing Quality System - How to keep them separate? ISO 14001:2015 Specific Discussions 3
S Record Retention - How long must a company keep the following records? Records and Data - Quality, Legal and Other Evidence 17
Q Is Handwritten Raw Data required to keep with Electronic Records? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
E Design Dossier/DHF Updates - What to Keep EU Medical Device Regulations 2
L Product Safety Officer - How to keep VW Happy VDA Standards - Germany's Automotive Standards 24
T How to keep Customer Engineering Specifications & CSRs Up to Date IATF 16949 - Automotive Quality Systems Standard 6
AnaMariaVR2 FDA to keep closer eye on diagnostics: FDA chief US Food and Drug Administration (FDA) 0
AnaMariaVR2 How to Keep the Fizz in Your Biz The Reading Room 0
H Best place to keep myself updated on EU Regulatory Changes EU Medical Device Regulations 7
T What Can Be Done to Keep Operations Trainers Busy? Training - Internal, External, Online and Distance Learning 3
V Device Retains - How many people keep retains of finished devices and why? US Food and Drug Administration (FDA) 6
Q Material Changes - To keep questions and answers as records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J SR-001 Revision - Keep watching for the new revision of SR001 (It is expected soon) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Antonio Vieira Do you still keep old numbers of Quality Progress in paper format? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 9
C Controlling QMS - We are expanding globally and want to keep our QMS Confidential Quality Manager and Management Related Issues 20
A Do you keep up your CCT (Certified Calibration Technician) Certification? General Measurement Device and Calibration Topics 3
P Self Motivation - How to keep it when overwhelmed with problems? Career and Occupation Discussions 13
Q Do we need to keep MSDS documents for all "chemicals" used in the factory? Occupational Health & Safety Management Standards 4
K How you keep yourself motivated in tough times? Career and Occupation Discussions 15
T From Manufacturer to Distributor - Still keep ISO 9001:2008 Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Documents required to display/keep during ISO 9000 Audit in EPCC firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Q How should I Keep my various types of records .. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How much information should I keep in my Master Document Register? Document Control Systems, Procedures, Forms and Templates 8
D Training Records - Requirement to keep original copy of training/assessment form? Records and Data - Quality, Legal and Other Evidence 12
R How long do I keep expired Calibration Certificates General Measurement Device and Calibration Topics 8
Marc Flying will be a real pain now - New rules keep passengers in seats Travel - Hotels, Motels, Planes and Trains 7
S Revisions in ISO 9001 QMS Documents - Where to keep the record of revisions? Document Control Systems, Procedures, Forms and Templates 7
P New Year Goals and Resolutions - Did you keep your goals and resolutions in 2009? Coffee Break and Water Cooler Discussions 5
C Do you keep ISO 9001 when going AS9100? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Q How many records should I keep when implementing Corrective Actions Records and Data - Quality, Legal and Other Evidence 3
