How to Link Electronic Records (510k Documents) to Handwritten Signature
Jennifer27
Hi All!!
I have a problem in which our consultant has limited experience, I would highly appreciate the help of the regulatory experts on Elsmar.
Our company is in USA, we have a regulatory consultant in country A and a sister branch of our company, where all the regulatory 510k documents have been prepared and the testing of our device was performed, in country B.
We have prepared all our documents required for 510k submission in pdf. We used to send these to our consultant through email and he reviewed them and sent them through email.
With each document we have a revision history. I was wondering if our sister branch in country B should take print outs of all complete documents, to be submitted to the FDA for the 510k, sign and send to us (company in USA) OR they can only take print outs of revision history (single page, giving details of reviewer etc and uniquely linking to an electronic record) sign it also send it to the consultant, he also signs it and sends to us in USA.
I would highly appreciate your input. Please help :thanx:
yodon
Well, I must say, I kind of got lost in all that and I'm not sure I completely understand what you're trying to accomplish.
It sounds like you're saying you are suggesting that printing a hardcopy of the pages with signature blocks & revision history and then "wet ink" signing that would link it to an electronic record. I don't see that being defensible.
Document Control (whichever country) needs to manage the approved documents and their distribution. If you want to have an electronic record that requires signature, I don't see how you can do that without an electronic signature.
We frequently work with off-site clients that sign a copy of the cover page then fax it to us, we sign the original, & attach both to the hardcopy. Clearly that process has potential for misuse but it's been acceptable up to this point. The signatures are associated with the hardcopy (which is kept and, as necessary, copied / distributed; e.g., to FDA, by doc control).
Not sure if that helps. Maybe re-state what you want to accomplish or where you feel uncomfortable.
Jennifer27
It sounds like you're saying you are suggesting that printing a hard copy of the pages with signature blocks & revision history and then "wet ink" signing that would link it to an electronic record. I don't see that being defensible.
Yes we will be doing the same "printing a hard copy of the pages with signature blocks & revision history and then "wet ink" signing" and in order to link to an electronic record we will provide electronic record unique details ( like the name of the record, create/modify time and date, its size (in Kb, as it would appear on the computer), format (pdf)). After this time to time manual audit trails will be conducted to prevent any unauthentic changes to the records. The audit trails will be signed and maintained in separate and parallel paper records. The audit trails will be conducted in our sister branch in country B. Now the audit trail records, signed pages will be sent on the mailing address of our main branch in USA (here I guess we can use fax?) and the complete 510k submission documents will be emailed to us in USA by our sister branch in country B, we in USA will take print outs ( or you would suggest that we should ask our sister branch in country B to take print outs of the complete 510k submission documents and send them to us through fax?). Finally we submit all documents to FDA with the signed pages and audit trails. Will this be acceptable? OR would you suggest to adopt any alternate method?
Can you please suggest any way to include the signature of the consultant who in country A?
OR We should keep the documents just between us in USA and our sister branch in country B and skip the signature of consultant because that might make our compliance complex, as we will then have to be concerned about our interaction with the consultant (as we sent him all the documents through email and he sent us all the reviews through email).
Thanks so much for your time and prompt response. I look forward to your input.
simonyeeklang
Perhaps you can get a photostat machine that will scan and email directly after the signature have been sent.
E
Elynn
There are softwares that replace ink signatures with digital signature or electronic signature which should meet your need... Google will provide you with some software available in the market...
simonyeeklang
Perhaps those lawyer also wants a hard copy instead of softcopy but I think both hard copy and soft copy is important.
yodon
Audit trails (my understanding, at least) are not "conducted." Audit trails are data collected about documents (who changed, when changed, etc.). Audit trails cannot prevent unauthorized (or unauthenticated) changes. That's a security function.
Maybe it's due to being Monday or just me being dense, but I still don't see how a "wet ink" signature can be linked to an electronic record. It's too easy to manipulate all the elements you mention above.
There are no requirements for audit trails to be signed. I think you're way over-complicating matters here. Audit trails do need to be validated. A hardcopy of an audit trail is, IMO, not worth anything.
First off, what do your procedures say? If the consultant is not required by your procedures to sign then don't do it. We (as consultants) often don't sign documents for our clients despite involvement we have on them.
So my suggestion is to first see what you can do to simplify the process. Look at the regs and look at your procedures and determine just what's necessary. Then, if you want to stick with manual signatures, device a process to capture those in hardcopy. If you want to go all electronic, there are plenty of systems, as Elynn notes, that can be fully compliant with the regulations (of course, you have to use them in a compliant manner and validate them as such).
The Specialist
The easiest way to handle this situation would be to have all of the document reviewers/approvers in the same place.
The 'wet signature' document, when operating a hybrid system becomes the 'master' document and must be treated as such, so I am not fully sure what you are trying to do with "linking to electronic records".
Of course, if you need to have multiple sigatories in multiple geographic areas , then moving to a 21 CFR pt11 compliant electronic system is the best way.
You will not have any more of these issues then!
Jennifer27
I'm learning about FDA and compliance please excuse my mistakes. I think with the input given by all the experts I'm now able to understand the process of compliance. Thanks Yodon, Specialist, Elynn and Simonfor the input,Kindly have a look at the following:
We actually have all our reviewers/approvers in the same country B (we will skip the consultant).
So, we have all the people working on the documents in the same geographic location i.e. country B, they will prepare records electronically, take print outs of the electronic records and after signing, treat the records as master records or master plans which can be executed. They will exercise control on the documents, by limiting the access to the system, where all the documents are stored, only to authorized individuals. They will demonstrate that the print out (which has been signed and used as master records) is the exact representation of the electronic document on system.
Finally, all these signed hardcopies will be sent to us in USA (on our mailing address), in a controlled manner, and we will simply submit it to the FDA.
Is this method right?
The Specialist
That sounds perfect!
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Link GMDN code and FDA product code US Medical Device Regulations 5
S Link Between Essential Performance Requirements and Essential Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 20
dgrainger Medical Device News MDR postponed - link to Official Journal of the European Union (24-4-2020) EU Medical Device Regulations 2
dgrainger Informational Corrigendum 2 OJ link Medical Device and FDA Regulations and Standards News 0
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
FoGia IMDRF opened a Consultation on Annex E & F and the link to ISO 14971 ISO 14971 - Medical Device Risk Management 4
Q Do we have to prove a link between the mill and our raw material supplier? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S FEE Registration LINK - EU Medical Device CE Marking (Conformité Européene) / CB Scheme 6
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
J Macro Question: Get Column Name by Column Number / or Use Text constant to link on a Using Minitab Software 1
K How to setup DDEs in Minitab to link a project to an Excel workbook Quality Tools, Improvement and Analysis 2
V The best practice to maintain & link Design and Process FMEAs FMEA and Control Plans 8
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
somashekar Link to important websites within the Cove Book, Video, Blog and Web Site Reviews and Recommendations 1
M Food Transportation the Weakest Link? Mixing cargo in food trucks Food Safety - ISO 22000, HACCP (21 CFR 120) 0
A SPC Software Packages - Real Time and can link to Databases including Oracle Statistical Analysis Tools, Techniques and SPC 7
T Dock to Stock Approval form, link or information Document Control Systems, Procedures, Forms and Templates 3
AnaMariaVR2 Link between failure to comply w/ Lab PPE standards & ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Link between Risk Management, Usability Engineering and R&D in Medical Devices ISO 14971 - Medical Device Risk Management 2
S Help needed to link accounting and ISO procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J0anne Link to find 502 (f)(1) which is quoted several times in 21 CFR 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S Quality Manual Review - Should the manual link all procedures Quality Management System (QMS) Manuals 5
Hershal Social groups...... See link at the top of the page Coffee Break and Water Cooler Discussions 1
L ISO 9001:2008 - What will it mean? An Article link ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Money available - but I need to link to 5s Lean in Manufacturing and Service Industries 5
M ISO 22000 and HACCP - Their link and basic steps in implementation Food Safety - ISO 22000, HACCP (21 CFR 120) 1
H Quality Control for Rubber Mixing and/or link to related forum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
N Fuel Prices Link To The Oil Market - The Oil Tree World News 4
Fexjo How to Link Quality Management System, Manufacturing and Product Audits IATF 16949 - Automotive Quality Systems Standard 1
G What is the link between FDA and US Pharmacopeia? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J The real Link between a PFMEA (Process FMEA) and the Control Plan FMEA and Control Plans 19
R Looking for a link to a story - Because Nobody did it, the project didn't get done Coffee Break and Water Cooler Discussions 4
J Link to a vitual MBA Managers skills course pdf file Book, Video, Blog and Web Site Reviews and Recommendations 0
A e System - Planning to computerize and link the systems IATF 16949 - Automotive Quality Systems Standard 1
I Need link to PDF file ISO TC/176/SC2 Home Page ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Are you looking for a plant link in Europe? Career and Occupation Discussions 1
W Need a link to a thread here - Discussed the difference between lean and six sigma Registered Visitor Articles Archive 9
Marc Elsmar Cove Forums Link Listed in Wikipedia.org Coffee Break and Water Cooler Discussions 6
B Quality and Health & Safety. How close is this link? Document Control Systems, Procedures, Forms and Templates 8
L Link to an example of a full 19 element PPAP example - Seeking APQP and PPAP 5
C How to "link" normal process variation and "triggers" for Internal CAs? Nonconformance and Corrective Action 6
A Folks take your time & rate your boss - A link to a 'test' on another site Coffee Break and Water Cooler Discussions 2
J Seeking: Process Link Chart example IATF 16949 - Automotive Quality Systems Standard 1
