How to Measure Paint Thickness for an Enclosure
L
LesPiles
Hello everyone,
We produce electrical and electronic products and our client specifies a certain thickness of paint for the cabinets. However, it does not specify where to take these measures! Those who have already worked with painted metal products know that it is difficult to have a uniform thickness of paint. It is generally expected to have a different thickness at the bottom of doors, for example, and a fairly thick paint (or thin as applicable) on the sides.
Our products are inspected by a representative of the client. He wants to inspect the bottom and sides. Our Production Manager meanwhile recommends a measurement at CENTER of the door.
The question is: "Who is right?" And ... what would be the sustaining explanations for your answer?
Obviously, the discovery of non-conformance has important economic consequences, as you might expect.
Thank you in advance for your help.
Re: How to measure paint thickness for an enclosure ?
Hello everyone,
Although it's a little bit late in the game to be asking this type of question (as I'm sure you're aware), ususally the best approach is to take a few typical parts and measure them in various places and find out what you actually have for overall film build. Share this information with the customer, and tell them what the limitations are. If you're doing powder coating, for example, thickness might be greater near edges and more uniform across a broad, flat surface. The thickness is not likely to be the same all over the part. Make sure your customer understands the limitations of the process, and that if a given thickness is required in a certain area, the thickness in other places on the part will be different.
t.PoN
I agree with above to consider the process.
Paints on metal are used to protect from corrosion.
Hence, You need to answer two main questions:
The first Question: What surface is more effected by the environment. this is the surface you need to consider.
the second question; what type of surfaces design you have: welded parts, edges, bolts ...etc. this is the second criteria
Paint on metal is sometimes used primarily for cosmetic/decorative purposes and corrosion resistance might be a secondary consideration, if it's considered at all. Consider paint on aluminum, for example.
t.PoN
oh.... u r right lol.
u know what they say, if u assume, u make .... :p my fault
I just had a similar experience and the thickness was only considered because of corrsoison and durability issues. and recalling the event, the used paint was the major issue rather than the coating thickness.
even though never thought of anybody asking to measure thickness for decorative purposes.
but it would be interesting to know what is the purpose of testing the thickness.
W
Wilderness Woody
Who do you think is right?! Hmmm... the customer always say they are right :notme:
Working out what to measure and how to measure should include reasonable input from the customer. There may be historical standards and industry standards to use as a guide.
Check out these links:
http://www.defelsko.com/applications/powdercoating/powdercoating.htm
http://www.defelsko.com/technotes/coating-thickness/coating-thickness-measurement.htm
Planned sample locations agreed upon by all parties is the way to go for consistency in measurement and to address known weaknesses in painting/coating processes.
M How to measure a plastic cap General Measurement Device and Calibration Topics 10
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
qualprod ISO 9001 5.1.1 - How to measure System effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
1 How to measure straightness on a HEX Long Bar Manufacturing and Related Processes 7
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
M Informational The ANSM decides, as a precautionary measure, to withdraw from the market macrotextured breast implants and breast implants with polyurethane-coated s Medical Device and FDA Regulations and Standards News 0
M Informational Health Canada advises Allergan of its intent to suspend its licences for Biocell breast implants as a precautionary measure Medical Device and FDA Regulations and Standards News 0
U SI 13 - Not Every Process Requires an Efficiency Measure IATF 16949 - Automotive Quality Systems Standard 1
P NPR Metric - What if Customer has relaxed measure? TL 9000 Telecommunications Standard and QuEST 1
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
M How do we document and measure a service we do not provide? IATF 16949 - Automotive Quality Systems Standard 1
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
D Proper Tool to Measure Wall Thickness (ISO 3611 - Micrometers) Manufacturing and Related Processes 7
S Quality Measure for Engineering Services Misc. Quality Assurance and Business Systems Related Topics 1
A What are methods and tools to measure Workload analysis ? Human Factors and Ergonomics in Engineering 1
M How do I measure variation in my process ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Jim Wynne Measure Twice, Cut Once: The French Railroad Snafu World News 18
S Measure water activity for fresh raw chicken meat and giblets Food Safety - ISO 22000, HACCP (21 CFR 120) 1
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
R Repeatability in MSA - Is repeatability a measure of Location Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
R How do companies measure QC Productivity? Quality Manager and Management Related Issues 3
V How to measure radius without radius gages APQP and PPAP 4
A Device to measure "Straightness & Deformation" of a metal that's under water Manufacturing and Related Processes 4
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
F Specification for how to measure lengths of hose assemblies Various Other Specifications, Standards, and related Requirements 1
P MSA requirements for Systems that Measure Process Parameters Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
