Most shops use a CMM to measure straightness. Depending on the feature of interest, a CMM uses a different approach than an open set up would.
Straightness is a feature that is checked against itself; deviation of a straight line from a theoretical perfect straight line. (It is sometimes confused with flatness, but the principle is the same).
A CMM will have a more difficult time checking axial straightness than surface straightness, because the variation in the diameters will go along for a ride when the former is the objective. Surface will only tell you that it is straight along the line checked....not at place about the entire diameter.
If an open setup is used, a precision collet could be employed to check the axis, yet size lengths will limit your ability. If the surface is in question, flatness is checked with an indicator running through the table, from underneath, and the item is then dragged across the nib.
It sounds to me that a designer may want to controll a feature other than straightness, but is calling this feature as a control item. For example, if the designer desires to maintain a constant force application to limit buckling, then it may be of more benefit to control axial runout at each end and several places along the lenght especially if the item is not supported in the mid sections.
