How to measure straightness on a HEX Long Bar
1
12kennedya
I am working to find a new way to measure the straightness of a hex bar 12' in length. Ive come across a couple different ideas but no really make since.
One critical item will be adequate support for the entire length, so straightness is not affected by gravity on unsupported sections. That support will also have to be 'straight'. You will also have to measure in such a way that any parallelism issues between the opposite surfaces do not show up in straightness. Or does this have to be measured in a free state?
1
12kennedya
Miner, No it does not have to be in a free state. We have a table we sent out to have flattened 100% by a machining company.
John Predmore
If you could hang the bar vertically by one end, gravity would not cause deflection from straight. Not the most practical solution, but novel and cheap. A plumb bob made of string and a weight can show where a surface deviates away from a vertical line, as long as you check all six sides. Laser pointers are also very inexpensive, if you fashioned a holder to clamp on the end of the bar so the beam projects parallel to the bar surface at a offset equal to your straightness tolerance. A little more involved would be to design a metal tube with inside dimension that will pass freely a straight bar, but a bar slightly bent will bind in the tube. This Go/NoGo tube idea will be checking size as well as straightness, but if the bar is drawn the size tolerance is very tight, so you can almost ignore variation in size.
CreativeQC
I truly have no idea what I'm doing half the time.
If you have a table that is getting flattened you could also lay a grid on it to see if there is any bending in the bar. You could have two employees check which line on each end of the table it lines up with and roll it to check all sides of the hex. If you wanted to get fancy you could also mount an overhead camera to drop labor costs.
1
12kennedya
All of these seem logical, I really like the GO/NoGo Tube Idea. If you guys come up with anything else let me know.
A Device to measure "Straightness & Deformation" of a metal that's under water Manufacturing and Related Processes 4
A Gage to Measure Wire Straightness needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
P How to Measure Straightness of Small Bars or Tubes (Long Length) Reliability Analysis - Predictions, Testing and Standards 30
M How to measure a plastic cap General Measurement Device and Calibration Topics 18
C First Article Inspections - 'how to measure' General Measurement Device and Calibration Topics 11
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
P How to measure DPPM in Chemical batch manufacturing Quality Tools, Improvement and Analysis 1
silentmonkey How to measure severity if my product is designed for emergency use and failure would result in death? ISO 14971 - Medical Device Risk Management 9
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
J Validity / outcomes measure for custom made medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
D Performance specification as a Risk Control Measure, EN 14971 ISO 14971 - Medical Device Risk Management 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
D Torque fractional unit of measure; cN-m or N-cm? General Measurement Device and Calibration Topics 2
qualprod ISO 9001 5.1.1 - How to measure System effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J How to measure a Critical Characteristic that is a Basic Dimension Misc. Quality Assurance and Business Systems Related Topics 6
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ron Rompen Measurement Method Challenge - Measure feature #91 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
G Measure 3 times, for calibration report? Customer Owned Reference Standard General Measurement Device and Calibration Topics 4
M Informational The ANSM decides, as a precautionary measure, to withdraw from the market macrotextured breast implants and breast implants with polyurethane-coated s Medical Device and FDA Regulations and Standards News 0
M Informational Health Canada advises Allergan of its intent to suspend its licences for Biocell breast implants as a precautionary measure Medical Device and FDA Regulations and Standards News 0
U SI 13 - Not Every Process Requires an Efficiency Measure IATF 16949 - Automotive Quality Systems Standard 1
P NPR Metric - What if Customer has relaxed measure? TL 9000 Telecommunications Standard and QuEST 1
T Tape Measure, the right device for 2 or 3 decimals accuracy on prints General Measurement Device and Calibration Topics 8
M How do we document and measure a service we do not provide? IATF 16949 - Automotive Quality Systems Standard 1
M For a Type 1 Gage R&R I want to use 1 unit and measure it 30 times Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
rob73 Advice/recommendations for equipment to measure a soft pvc tube - Optical Measuring? General Measurement Device and Calibration Topics 4
R Height gauge to measure short hard to access heights General Measurement Device and Calibration Topics 3
D Proper Tool to Measure Wall Thickness (ISO 3611 - Micrometers) Manufacturing and Related Processes 7
S Quality Measure for Engineering Services Misc. Quality Assurance and Business Systems Related Topics 1
A What are methods and tools to measure Workload analysis ? Human Factors and Ergonomics in Engineering 1
M How do I measure variation in my process ? Capability, Accuracy and Stability - Processes, Machines, etc. 3
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Micrometer Anvil Placement to measure the diameter of Steel Wires Measurement Uncertainty (MU) 6
S Where to Get SPC Training to Measure our Processes? Training - Internal, External, Online and Distance Learning 12
M A question on Measurement System Analysis - Stability to measure got Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Jim Wynne Measure Twice, Cut Once: The French Railroad Snafu World News 18
S Measure water activity for fresh raw chicken meat and giblets Food Safety - ISO 22000, HACCP (21 CFR 120) 1
O Metrology Devices to Measure the Basic Dimensions of Plastic Specimens General Measurement Device and Calibration Topics 6
L How to Measure Paint Thickness for an Enclosure Manufacturing and Related Processes 5
C Chamfer Measurements - Do you measure the height and width or the hypotenuse? Manufacturing and Related Processes 15
R Repeatability in MSA - Is repeatability a measure of Location Error Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
E How can I measure three true positions? GD&T basic question General Measurement Device and Calibration Topics 5
V How to use a Calibration Certificate in Uncertainty Calculation for a Test Measure Measurement Uncertainty (MU) 13
R How do companies measure QC Productivity? Quality Manager and Management Related Issues 3
V How to measure radius without radius gages APQP and PPAP 4
M How to measure effectiveness and efficiency of the established QMS as Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
