How to perform Process Capability for true position
QE1993
The nominal for true position is 0. The print will call out a GD&T true position and allow you to go up to, let's say, .003. In cpk software, how do you reconcile this? If we put our LSL as 0 and our USL as .003, we don't get accurate results, because the LSL is NOT 0 - 0 is the nom.
Is there a way to 'obsolete' the LSL and just focus on the USL when it comes to true position?
By the way, I am using Minitab to do my capability studies.
Stijloor
This question has come up a few times.
If you scroll down, you'll find a few interesting threads and responses.
The specific answer that you requested (i.e., 'obsolete' the LSL in Minitab) is straightforward. When you enter 0 as the LSL, check the box labeled 'Boundary'. This tells Minitab that 0 is a physical limit instead of a spec.
However, capability studies for GD&T are rarely straightforward. Since position tolerances convert Cartesian coordinates into partial Polar coordinates, you will often end up with skewed (non-normal) distributions. If you add in MMC modifiers, you no longer have a fixed tolerance either.
QE1993
I believe our CMM program accounts for the bonus tolerances due to the MMC modifiers.
Can you please explain a little further what you mean by "Since position tolerances convert Cartesian coordinates into partial Polar coordinates?"
How do you combat this in a cpl study?
Let's use an example of a square block with a hole drilled into it. For simplicity, I am using only the X & Y coordinates. One corner of the block is the 0, 0 datum, and the hole is drilled at coordinates 1, 1. This is a Cartesian coordinate system. This is the system in which a CMM operates and usually reports data in an x, y, z format.
Therefore, the hole location has an x coordinate and a y coordinate. It may vary less than 1 or greater than one. If you were to analyze the x or the y results individually, chances are good that you would see a normal distribution in each axis.
However, Position results convert the separate x, y coordinates into part of a quasi Polar coordinate system. A true Polar coordinate system would provide both a radial distance and a polar angle for each measurement. Position results consider only the diametrical distance regardless of the angle. Therefore, a hole at (0.9, 0), (1.1, 0), (0, 0.9), or (0, 1.1) are all considered to have the same Position despite the fact that they are off location in four different directions. This usually results in a right skewed distribution.
Not only do you have to either perform a non-normal capability analysis, or transform the data to normal (not recommended), but you do not have the necessary information to improve the capability. To get that information, you have to study the x and y results separately in order to move the hole onto target.
It does when reporting whether an individual result in in/out of tolerance. However, when you combine 100 of these into a capability study, you end up with 100 different bonus tolerances.
QE1993
Thank you for replying to me. I'm afraid I have some more questions, but feel free to ignore them if you don't have the time.
So, I can determine the distribution of my data and then perform the capability study based off of that model?
When you say that I have to study the X and Y coordinates separately, do you mean I should determine the capability of each coordinate individually? Can you help me understand how that would help me improve the overall capability of my process?
I guess all my questions really boil down to, what is the most accurate (if any) cpk results for a GD&T dimension? And how can I obtain those cpk results?
The standard capability study assumes that the process is stable and the distribution of the process is normal. Therefore, you must collect data in time sequence, plot it on a control chart to verify that it is stable, then verify that it is normally distributed. If the process is stable, but is not normally distributed AND there is a rational reason for it to be non-normally distributed, you can perform a non-normal capability analysis (recommended) or you can transform the data into a normal distribution (not recommended).
Take a scenario where you have a Cp = 2 and a Cpk = 0.8. Obviously, you need to reduce the average Position by moving the feature closer to target, but how? Is the feature off in one axis? Both axes? Do you need to reduce the dimension or increase the dimension? The only way to tell is to evaluate the capability for each axis.
V Is it required to perform Process Validation for food or dietary supplements? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
S Do HF Accessories need to perform a Risk Management Process of 60601-1:2005? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
H AS9100C - Do Quality personnel have to perform the In-Process and Final Inspections? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
V When to perform Process FMEA? FMEA and Control Plans 8
H How to perform interesting PFMEA (Process FMEA) Training Training - Internal, External, Online and Distance Learning 6
M Customer is also my supplier - Should I perform an audit to his process? IATF 16949 - Automotive Quality Systems Standard 6
A Internal Audits - Can we to perform audit just using process maps? Process Maps, Process Mapping and Turtle Diagrams 19
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 2
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 3
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H Do you have to perform an full internal prior to IATF 16949 audit? IATF 16949 - Automotive Quality Systems Standard 21
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
S When will notified bodies be ready to perform audit to the MDR? EU Medical Device Regulations 1
chris1price Is there a regulatory (MDD, MDR, FDA, ISO, etc) requirement to perform a mock recall? CE Marking (Conformité Européene) / CB Scheme 4
P Can CEO perform internal audit Internal Auditing 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W How to perform validation for an epoxy curing station Manufacturing and Related Processes 3
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E How do you perform a GR&R for system software generated values? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 105
M How to perform Chelex DNA Method Verification in the lab General Measurement Device and Calibration Topics 2
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
R How do you perform verification of a NCR (Nonconformance)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Hiring an External Auditor to perform our AS9100 Compliance Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 2
A Do we need to perform Qualification and Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Do we need to perform Analytical Method Validation upon Relocation? General Measurement Device and Calibration Topics 5
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Looking for service provider to perform residual dirt test, GME7061 General Measurement Device and Calibration Topics 2
J Is MS Outlook a sufficient reminder to perform yearly supplier evaluations? Quality Manager and Management Related Issues 10
